ive said this a zillion times and ill say it again...if youre trying to get a low e.t. and youre not banging the 1-2 shift then pack up and go home! any good run is decided in the front half
slicks will put you deep into the 12's. not sure why NOBODY has mentioned this yet.
I think I did say borrow a set of slicks in my second post.
whats deep staging?
am using the 93 tune with some modifications, it made267hp 305tq before dsp/meth and s2 injectors.
Deep staging is when you stage your car at the line. As soon as the second yellow light goes on you get on th brakes. What it does is give you a slight rolling start before you break the timing beam. If your just out to beat the guy in the next lane you want to stage shallow. But for the best time slip the farther you are away from the timing beam the better time you'll get.
ROLL RACING isn't racing. It's just 2 homos speeding next to each other!
11.79 @ 118.53 S3 + bolt-on car!
BEST 60 1.68
BEST TRAP 120.60
just keep at it, with practice you'll be in the mid 12's before you know it.
Best run:12.167@113.93 mph with a 1.82 60'. same mods as below w/ 110octane on 24x8.5x15 MT drags.
Best Run on streets: 12.571@114.61 mph with a 2.0 60' on 18" all season tyres. mods=AGP WGA, S-AFC I, 750cc inj., HKS BOV on ATP UPP, Mopar sts, AGP dogbones, CCA FMIC, and 3" turboback no cat no mufflers.
Best MPH was 116.40 run with same mods as above!!!
Tuned by ME: 286whp 366wtq 22/13 FASTEST SRT-4 ON STREET TIRES, STOCK TURBO, OFF THE BOTTLE
You just need some practice. You are making 40 whp more than me, and i've ran a 12.9@113. You have a beast on your hands, now I really want DSP. Don't be a pu$$y and get slicks just to get in the 12's. Once you get 12's on street tires, get slicks and go for 11's on stock turbo
Good luck
Jason
Black 04 SRT-4
mopar BOV, Shortshifter, Progress springs, s1 ecu, agp wga, MaxxFab 3" o2 and Side Exit Exhaust w/no cat, AIS BFMIC and LFS 60mm tb,Dasmopar mapclamp, Injen SRI, 17"Motegi LC5's, PTP STG 3 Clutch
Best et 12.9 no traction
Best mph 113
270/330
ooorrr, since he doesnt have money to spend on slicks he can just practice.
only issue i see here is the MPH, why is it soooo low?
that much power you should be trapping 115+
your car has mid 12's in it as it sits, the driver mod is the only thing that can help you get faster cheap, and u can only get that from practicing. keep at it!
