Old 06-08-2009, 09:50 PM   #1 (permalink)
chrishna's Avatar
Member Number: 47605
Default help me hit 12s
ok, so i wanna hit 12s the next time i go to the tract(06-12-09)
last week i got 5 runs in, 2 was 13.212. the others 13.000.
2.012-60ft street tires at 23psi.
what can i do different to go just a bit faster with my current setup
399hp. 423tq stock turbo with 60 shot
chrishna is offline   Reply With Quote
Old 06-09-2009, 12:57 AM   #2 (permalink)
bluebeast's Avatar
Member Number: 39695
Powershift, remove the interior, deep stage the car at the starting line. thats just a few suggestions to get you a few tenths. Theres probably more.
ROLL RACING isn't racing. It's just 2 homos speeding next to each other!
11.79 @ 118.53 S3 + bolt-on car!
BEST 60 1.68
bluebeast is offline   Reply With Quote
Old 06-09-2009, 01:57 AM   #3 (permalink)
finfast srt4's Avatar
Member Number: 10147
I'm not sure what your using for your meth injection but if you go to a 10gph nozzle and run straight meth you can pull some fuel, it will raise your motor octane which will let you run more timing. seems how you have a dsp you can add timing. also a 3" 02 housing will help. if you want to really get crazy go buy a quart of 20% nitro rc car fule and mix it with 1 gallon of meth in a two gallon or larger can. this will get you a 3-5% nitro mix its completely safe and will gain up to 18hp from just running it it also drops your knock count ALLOT dcr seen huge gains from this. the things from the above post and what if stated should get you into consistent 12's depending on track conditions.
finfast srt4 is online now   Reply With Quote
Old 06-09-2009, 09:11 AM   #4 (permalink)
Lilone123's Avatar
Member Number: 43600
Funny you mention the nitro fuel. I was just thinking about this last night when I saw my RC Nitro fuel in my garage.
S3 w/o, MPx 3" TBE, catch can/checkvalve, Walbro 255, MM inserts, AEM SRI, AGP fmic, Meth, DSP Tuned
Lilone123 is offline   Reply With Quote
Old 06-09-2009, 09:49 AM   #5 (permalink)
milkman102299's Avatar
Member Number: 25193
Trader Rating: (15)
I am honestly suprised at your power level and those HP numbers you are not already in the 12's. when My car had similar mods I was able to get a 12.72 at 116. Had about the same HP as well. I would probably say its in your shifting. work on speeding up you ships along with power shifting and you should be where you want to be.
Wiseco 8.0-1 pistons over-eagle H beam rods
agp standard 50 trim
Greddy Profec B. SAFC II
PTP charge pipe
PTP 750cc-exhaust depot cold side pipe w/hks ssq
3inch intake-accel coil-stg 2 CPU
side exit
Boomba Fuel Rail/AGP return line
Walbro 255-Dynotune 105 shot.
DCR powershift 2-balance shafts removed
coolingmist meth kit. BC3 cams.
N2MB WOT BOX (BEST MOD SO FAR)
milkman102299 is offline   Reply With Quote
Old 06-09-2009, 10:55 AM   #6 (permalink)
chrishna's Avatar
the back seat is already out. i shift reg from 1-2 power shift the rest @6k rpm. i have the the cooling mist basic trunk mount w/i. i dont want to spent anymore money.
Old 06-09-2009, 11:41 AM   #7 (permalink)
Member Number: 48251
Have you tried messing around with slightly lower/higher shift points? My car seems to slow down a bit shifting over 5900.
fullyspooled is offline   Reply With Quote
Old 06-09-2009, 11:57 AM   #8 (permalink)
bluebeast's Avatar
Keep pealing weight. Passenger seat, floor mats, Etc. Also deep staging the car will help. If your cutting a 2.0 sixty your not going to improve much on your launch and if your powershifting already that covers the shifting. Are you shifting into 5th at the end of the track? If yes dont. Your coming up on the wrong time of year to speed things up. The hot weather isn't going to help your quest for 12s. I know you don't want to spend any more money but a N2MB toy box will get you a few tenths easily and their cheap. One more Idea is tofind another guy running a SRT-4 and borrow his slicks.
Old 06-09-2009, 12:15 PM   #9 (permalink)
Rhunter's Avatar
Member Number: 36794
Quote: Originally Posted by bluebeast View Post
One more Idea is to find another guy running a SRT-4 and borrow his slicks.
To the OP. Do you have a custom tune on your DSP? In other words did you modify the stock or 93 octane tune? Or are you running the canned 93 oct performance tune?
What was you HP prior to the DSP. Sorry to thread jack.
Old 06-09-2009, 01:43 PM   #10 (permalink)
Trader Rating: (15)
Post your dyno sheet and I will help you decide when to shift. You need to shift at the Rpm where your car starts to loose power.
Old 06-09-2009, 01:59 PM   #11 (permalink)
Member Number: 11681
Trader Rating: (96)
1-2 shift is the most important shift of the run you have the least amount of built up motion so the longer it takes the slower you go....
2nd Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
3147 7.49/102 11.51/124 so far 28psi
3147 7.26/100 22psi pump full int
Old 06-09-2009, 02:03 PM   #12 (permalink)
SRTDave05's Avatar
Member Number: 71897
I would say you need some seat time and some better tires i would'nt even change a bit of my setup if i was you with those Hp&Tq #'s you shouldnt have any difficulty breaking into the 12's. You should most def invest in some Drag radials.
-Dave
GoHardOrGoHomeRacing
Mods:BFMIC,MPx 3" O2 Housing,BBP 3" Downpipe Stock-Turbo
SRTDave05 is offline   Reply With Quote
Old 06-09-2009, 02:08 PM   #13 (permalink)
SRTDave05's Avatar
Agreed, I stopped producing power after 5,512 RPM
-Dave
Old 06-09-2009, 02:41 PM   #14 (permalink)
Rhunter's Avatar
Dan would a good WOT shift help at the 1 - 2?
do you WOT the 1 -2 shift?
Old 06-09-2009, 02:45 PM   #15 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (30)
Remove as much weight as you can, and borrow a set of slicks if you can!
Page generated in 0.18894 seconds with 13 queries
