Old 06-07-2009, 09:57 PM   #1 (permalink)
Member Number: 24832
Default Is this good or bad?
r/t....213
60.. 2.339
330...9.232
mph...80.70mph
1000..11.874
1/4... 14.135
mph... 98.31mph
next best
r/t....283
60... 2.357
330..6.169
1/8..9.246
mph..80.12mph
1000..11.905
1/4..14.178
mph..97.74
elevation was 2500ft and temp was 65
I think i have a gap problem i should be trapping higher than what i am. i ahve stage 1, agp wga @ 17, plugs at .44 should they be gappe at .35
05 srt-4
mods: stg 1, agp wga 17.5psi
track: Bristol
Best 1/8: 8.81
Best mph 80.7mph
Best 1/4: 13.71 (1.98) 60ft
Best mph 101
04BlueSrt-4 is offline   Reply With Quote
Old 06-07-2009, 09:58 PM   #2 (permalink)
trying to make 13.9 on what I have at over 100mph
Old 06-08-2009, 09:00 AM   #3 (permalink)
bluebeast's Avatar
Member Number: 39695
Well it's average. Your sixty needs improving. You should be able to cut that down to a 2.1 on street tires and a 1.8 if you swap to DRs. Your MPH is also down for your mods. You should be in the 102 to 104 MPH range. The E/T is pretty good considering DA you were at.
ROLL RACING isn't racing. It's just 2 homos speeding next to each other!
11.79 @ 118.53 S3 + bolt-on car!
BEST 60 1.68
bluebeast is offline   Reply With Quote
Old 06-08-2009, 12:19 PM   #4 (permalink)
Neon Nick's Avatar
Member Number: 18097
Like bluebeast said, just improve your 60ft's a little more and you should be high 13s. If you get slicks then you're looking at mid-13s. I agree your mph is down, try gapping the plugs to 35 like you said and see if that helps. I know 44 is too much, I had problems with mine because they got "out of gap" and were in 45+ range, I re-gapped to around 30 and now I'm good! Other than that, just practice and have fun
Boosted Fools Racing - Forums
'04 Dodge Neon SRT-4 - 12.83 @ 103mph
Mods: 3" Needswings y-pipe, Stage 1 PCM,
AGP MMs, AGP WGA, M&H 24.5x8.5x15 slicks
'95 Dodge Neon SOHC Turbo - 14.45 @ 97mph
Neon Nick is offline   Reply With Quote
Old 06-08-2009, 01:05 PM   #5 (permalink)
will plugs kill it that bad and would a exhaust leak hurt a car.
06 gto 12.01@Darlington-12.51@Bristol
05 gto 12.15@Darlington-12.61@Bristol This car added 20hp since Darlington.
they have heads cams and all bolt on its about .4-.5 diff in the tracks
Old 06-08-2009, 01:18 PM   #6 (permalink)
bluebeast's Avatar
You'll know if your getting spark blowout. You'll feel the car stumble. .30 to .35 is a good place for boosted cars to be for the gap. And yes leaks will kill your power. I'm not sure what your talking about exhaust leaks? Do you mean your turbo manifold is leaking? Bad Gasket? If your refering to boost leaks they'll steal a ton of power. Boost leak test and get some T-bar clamps will help alot with the boost leaks.
Old 06-08-2009, 04:05 PM   #7 (permalink)
Member Number: 60592
deffently regap the plugs. i have mine gaped at .32
stock pcm with bolt ons 13.49@103.89
05 Commemorative Edition
PW1 ACC,ARL,GWA #74/200
SRT_PAPA is offline   Reply With Quote
Old 06-08-2009, 04:36 PM   #8 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (30)
Gap the plugs @.035, and work on the 60'
Old 06-08-2009, 05:40 PM   #9 (permalink)
Rhunter's Avatar
Member Number: 36794
I'm just learning myself, but like beast and the other guys said, gotta get that 60' down. I just started cutting 2.0's on 225/45/17 DR's at Mason Dixon. yeah I know, not great, but that would probably be 1.9 at a track that actually preps.
I did not see what othe mods you have. What are you doing for exhaust? Check for boost leaks and the next mod I recommend it the diablo. I Just got one, flashed the canned 93 tune and the car hauls buns!!
Old 06-09-2009, 07:47 PM   #10 (permalink)
IM running on street tires with agp wga @ 17 and stg 1 and for suspension i and have mopar stg 1 springs which i would love to sell and plugs gapped at .44 . Thinking about plugs gapeddbumping it to 18 max
Old 06-09-2009, 07:59 PM   #11 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
x3984723
regap plugs and work on 60'
Page generated in 0.16603 seconds with 13 queries
