» Tire Upgrade Garage
Old 03-20-2008, 08:37 AM   #16 (permalink)
SRToc Member
Member Number: 38393
Ok my bad... abusing my trans, your right I am; it's called racing. If you think for one minute I'm going to argue with any of you, you couldn't be more wrong. Actually I was just making the suggestion to stay out of the the damn water unless you have slicks on the damn car, this was the driver mod. Some people don't think about that. You want an explanation on why you can't get a good burn out on slicks even you go through water. Well, only a few things I can think of, you haven't got enough power to spin your tires, you've got to much torque and your rims are spinning on your slicks or you just suck and don't know what you are doing. And it's not really abuse on anything when you just let your car rock backward and toss it in first, if you try reading this time I had said this was the trick I use just to get them spinning not a driver mod. If it doesn't make sense to you that's fine. Because your ignorant and daft attitude doesn't make sense to me. I was simply making a suggestion. For street tires and DR's only, nowhere did it say anything about slicks. And of course it's not very practical to burn out street tires, but it's just stupid to try and run slicks when you don't even have the torque to spin some street tires. I grew up racing jr. dragsters... You sir are absolutly right I'm a fucking retard. I've just spent my entire life around the tracks. You aren't even worth getting upset over. Go crash into a wall, just wishing you my best.
"Nightshade" Lorenz will forever be missed!
Mods: *Rage-Tek Tuning* 298hp 364ft lbs Stocker
Call Rage Technologies for all generation Neons! Check em' out on the supporting vendors. Tuning, Installs, Parts, Custom Fab. One of a kind friends!
ACRin954 is offline   Reply With Quote
Old 03-20-2008, 08:41 AM   #17 (permalink)
SRToc Member
And to man up... I agree adjusting your ebrake may help. Good idea. You're still a vag though!
Old 03-20-2008, 08:42 AM   #18 (permalink)
peteblksrt4's Avatar
Member Number: 43767
Trader Rating: (62)
wow hostile we are. damn dude.
http://groups.myspace.com/jacksonvillencsrt4s join if u are in jacksonville, nc area only
Best Trap - 1.79 60 FT 12.3090 at 114.53[/font]
ported stock turbo
peteblksrt4 is offline   Reply With Quote
Old 03-20-2008, 09:40 AM   #19 (permalink)
SRToc Member
I don't appreciate being called a retard. Especially by someone older than I am. Simple as that.
Old 03-20-2008, 10:03 AM   #20 (permalink)
ritfordprobe's Avatar
Member Number: 53609
OMG, so much dumb information in this thread. Just dump your clutch and rev higher, what is the problem? You don't need to do a john force burnout with street tires, just spin them a little bit, and your set. Big burnouts for for slicks, in the water box.
'03 SRT4 - 12.096 @ 119.37 on pump gas and DOT tires
ritfordprobe is offline   Reply With Quote
Old 03-20-2008, 11:34 AM   #21 (permalink)
Member Number: 37196
well if you go back and READ what i said . i said that is retarded i never called you a retard you illiterate prick.
look here son im glad you have been racing since jr drag it nice to see that your grown up now.. the point i was making was your puitting your car threw enough abuse rockin back and forth honestly not good for tranny axles ect. im trying to save you some $$$$$. your car has enoug power to spin the tires without rockin it. if you grew up aroud a track you would know that
12.50@110mph thats the time i let everyone see but what does it really run.
smokd u2 is offline   Reply With Quote
Old 03-20-2008, 09:37 PM   #22 (permalink)
Member Number: 56991
wow this thread had gone to craps lol. I'm on slicks and Im just having troubles gettign the car to stay put while I spin tires it drags the entire back end but I guess its practice
::Stg 1 PCM::AEM S.R.I::Hallman MBC::Borla Dual Exhaust::NeedsWing v5 3" DP/Cuttout::Turbonetics Cold Side Pipe w/ Greddy Type S.BOV::Mpx Front Mount Intercooler::Tein-S Springs::AEM EUGO,OIL Pressure,Volts::Apexii TT::Apexii Neo/MSD Tach::Bwoody Motor Mounts::IP2 CF Hood::Carbon By Design Eyelids & Radiator Shroud::AGP Return Line::AGPBB50trim::RC750cc::Walbro255
13.0@108 1.86-60/ft (On Stock Turbo)
12.8@112 2.2-60/ft (50trim Stock Clutch)
RaiedZ is offline   Reply With Quote
Old 03-20-2008, 09:55 PM   #23 (permalink)
contraption22's Avatar
Member Number: 8377
Here is what I do....
Drive around water..... stage... launch. No burnout. 1.7's every time on 23.5" slicks.
In my Horizon I have cut 1.6x's 60 ft times with no burnout.
2004 Neon SRT-4
Mods: #2 Extra Power Combo with Fries (S2 w/toys)
1986 Plymouth Horizon "GLMF"
Mods: Super-50 trim, Spearco, Menegon head.
NEW Best ET: 11.51
NEW MPH: 117mph
WWW.TURBO-MOPAR.COM
contraption22 is offline   Reply With Quote
Old 03-20-2008, 10:19 PM   #24 (permalink)
Boosted-srt's Avatar
Member Number: 21562
2nd gear, dropping the clutch at 5k+ rpms and your golden, stock clutch or not it will work, i've done it in many SRT-4's
Check it;
MySpaceTV Videos: SRT-4 Burnout by Kristian Hargett
GET REAL....GET MOPAR
'03 Black, S2/Toys, AGP 3" CAI, 3"DP/No CAT, 3" side exit, ATP cold side/Greddy TypeS, Lorenzo 60mm TB & Spacer, FBM P&P Intake Mani., MAD-DOG 50% STS, Booger Bushings, 18" TenzoR Mean6 w/245/40/18 Toyo T1R tires, Willwood Big Brake Kit/Red calipers/Cross drilled and slotted, Mopar Performance 4-Puck clutch/Fidanza Aluminum Flywheel, AIS BFMIC/black coating.
Boosted-srt is offline   Reply With Quote
Old 03-27-2008, 04:26 PM   #25 (permalink)
pumpkin05's Avatar
Member Number: 54667
Check it;
Now thats a burn out!
pumpkin05 is offline   Reply With Quote
Old 03-27-2008, 07:00 PM   #26 (permalink)
Pimpazzberetta's Avatar
Member Number: 29361
Trader Rating: (27)
Yep the problem you guys are having is to low of an rpm for doing the burn out. Tire is spinning less and actually gripping instead of doing a good burn out. Just like launching the car actually.. if you launch it lower it catches traction, if you dumped it at 4k and held wot.. the tires spin WAY more and you don't really go forward.
Mopar Stage 3R w Toys 388.8 WHP 425.5 WTQ
Mopar CAI,Mopar BOV,Mopar S1 Springs,AGP S3 WGA
SBC 5X,TC BFMIC / t bolt clamps, 55 mm TB, Maxxfab 3" o2,3" catless DP,Injen 3" catback, FBM intake mani
NGK 4306 @ .033, Devils Own W/I w controller
UEGO, Greddy TT, Ultra Lite II 30/30,Scan Gauge
DC Sports STB, MM inserts, Boomba trans mount
LCA, strut tension, Booger bushings,CV,18" Konig's,TCS, D/S Rotors
Pimpazzberetta is offline   Reply With Quote
Old 03-27-2008, 07:39 PM   #27 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (18)
I dump the clutch in 2nd at 5k, and it spins for a second, and pulls me right out of the box! I've tried feathering the gas, and also holding it. Either way it pulls me right out of the box.
12.25@111 1.70 60'
http://www.youtube.com/watch?v=2P0k3qWdpPw
23" slicks, RealTune Option A built motor, boltons, map clamp tuned! R.I.P. 4/5/08
http://www.cardomain.com/ride/2106154
Page generated in 0.20728 seconds with 11 queries
