Old 05-19-2008, 04:17 PM   #1 (permalink)
chuck's_srt-4's Avatar
Member Number: 12569
Default 11.24 @ 129.77 MPH...Sweet!!!
Just thought I'd post up the most recent runs I made with the car. I was only able to get 2 passes in, broke an axle on the first attempt, and broke out of my dial on the third attempt.
I got my new best time on the last run, though! I was pretty excited, although I was hoping for a 10 second pass. Can't complain too much, though, seeing that I am still unable to shift above 6500 rpm, and I'm running a 1 year old set of 24.5 x 8.0 slicks. Oh, and the fact I'm still on a stock bottom end, and therefore unable to rev the car out to the turbo's happy place...LOL!
Anyway, enough of the excuses. On to videos!
11.47 @ 127.75 mph
...and the 11.24 @ 129.77 mph
Timeslip for the 11.24 pass, since it's impossible to see in the video...
So, no 10 second pass this time. But maybe next time! I hope to have about 4 changes made to the car before the next time it goes out. Those changes being: 26" slicks, Coilovers to fit said slicks, RageTek accelerator shaft, and a twin disc clutch. Then, maybe then, I'll get the elusive 10 second pass on the stock bottom end that we've all been waiting for!
2004 Solar Yellow SRT-4 - AEM EMS - AMS37R Turbo Kit - Custom fuel system - JMCylinderhead/Crower S2 cams - Stock bottom end...for now, anyway!
Best E.T. to date: 11.24
Best MPH to date: 129.77 MPH
Old 05-19-2008, 04:34 PM   #2 (permalink)
Canada Moderator
Pablo's Avatar
Member Number: 1081
Is this on the 600WHP tune? Good times but I would have thought the MPH would be a lot higher with 600WHP no?
Pablo is offline   Reply With Quote
Old 05-19-2008, 04:46 PM   #3 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (114)
Nice runs. Those 26 inch slicks are going to help you immensley.
12.0@120 on DRs and 93oct.
addictedtosin is offline   Reply With Quote
Old 05-19-2008, 05:15 PM   #4 (permalink)
909srt4's Avatar
Member Number: 17063
Great times
pablo,the high elavation isnt helping him
909srt4 is offline   Reply With Quote
Old 05-19-2008, 05:18 PM   #5 (permalink)
Yeah, 600 whp tune. One thing to remember, though. That was 600 WHP SAE corrected, which is going to inflate the numbers a bit. Actual power output without the correction is actually 550 WHP. So, with that said, the traps are better represented by the actual power output.
Also, the other thing that has an impact on the traps mis-representing the power is "POWER UNDER THE CURVE". The car makes awesome peak power, but it's all up top (high rpm). Being that I'm on a stock bottom end, I can't rev the motor out as high as is needed to get the best results. If I were able to bring the car to 8000+ rpm, the traps would increase significantly, without increasing boost pressures, because I would be keeping the car in it's powerband, and not shifting out of it just when the going gets good.
Old 05-19-2008, 05:30 PM   #6 (permalink)
One thing to remember when considering correction factors, is that on a turbo'd car, elevation doesn't make "AS" much of a difference as it does with a N/A car, unless you're running the turbo to it's maximum potential.
So taking this into account, 550 WHP uncorrected on a turbo'd car that isn't running close to it's max potential means that the SAE correction to 609 WHP is going to be greatly inflated.
A true correction factor that takes the turbo into account might add around 15 - 20 WHP, not 60 WHP.
At the time I posted the numbers of 609 WHP, I should have clarified this more. Although, I have to admit, at the time that we dyno'd, I didn't really think much about this little fact.
Old 05-19-2008, 05:33 PM   #7 (permalink)
Also remember, the car is pretty much full weight, whatever that amounts to with a 175 lbs. driver. Only form of weight reduction the car has is a carbon fiber hood, and no spare tire/jack.
Old 05-20-2008, 11:39 AM   #8 (permalink)
Canada Moderator
Pablo's Avatar
Member Number: 1081
Makes sense, either way, 10's look like they're just around the corner
Old 05-20-2008, 03:35 PM   #9 (permalink)
Member Number: 9751
awesome chuck finally i got to see the vid!
New custom s372r setup:
750hp, 560tq...26-27psi not spray
through dcr auto trans..
****Second street Srt-4 in the 9's 9.95@143****
old setup:
742hp, 650tq...35psi&90shot of spray from a 37r through a dcr auto trans..
**worlds Fastest Dot tire srt-4**
10.51@144
kevinwarren240 is offline   Reply With Quote
Old 05-20-2008, 03:41 PM   #10 (permalink)
jwesleyc3's Avatar
Member Number: 39793
Sweet deal man! I am happy for you man! Keep it up because 10's are right around the corner for ya.
"Courage is what it takes to stand up and speak; courage is also what it takes to sit down and listen."
Sir Winston Churchill
jwesleyc3 is offline   Reply With Quote
Old 05-20-2008, 03:46 PM   #11 (permalink)
quickshift's Avatar
Member Number: 55168
Trader Rating: (29)
: you will have no problem breaking 10's on the stock block!! nice runs
BEST ET: 12.68@110 stg 0, stock turbo, stock intercooler, pump gas, & no meth
MODS ADDED SINCE THIS RUN: AGP BB .50T with all supporting mods
quickshift is offline   Reply With Quote
Old 05-20-2008, 09:15 PM   #12 (permalink)
boostjunky's Avatar
Member Number: 15084
nice runs
boostjunky is offline   Reply With Quote
Old 05-20-2008, 09:37 PM   #13 (permalink)
cokey's Avatar
Member Number: 17219
damn nice man.. chuck, on a serious note... how of course a lot of people will say that your engine will blow soon enough since its stock.. what's your take on that? i'll be happy with a 10.99 run.. recently i just messed up the motor though, was running way too rich and washed out some stuff in there.. oil in 1 cylinder and coolant in another.. found a stock longblock for 600 but was thinking of just parking the car in a friends garage n taking it apart. then getting it built up some..
mike, itzcokey@aol.com
FS drive side head light $50 + shipp (obo); stock ic $60+ shipp; silver wing perf cond 100$ obo; crash bar 50 + shipp; stck cold side
makeover http://www.srtforums.com/forums/showthread.php?t=345296
cokey is offline   Reply With Quote
Old 05-21-2008, 06:14 AM   #14 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (23)
Nice runs, and videos! Bigger slicks are going to set you right into the 10s!
04 S3 11.90@114 Untuned PCM controlled!
Old 05-21-2008, 07:00 AM   #15 (permalink)
mmmmpsi's Avatar
Member Number: 61977
Great vid!! nicely done at elevation!
05 Silver - BB 50 Trim, SAFC II, PRoSpeC, B&B Exhaust, QW BFMIC, etc.. etc.. Big stereo.
04 Yellow Mustang GT - Novi 1000, Exhaust, Meth
mmmmpsi is offline   Reply With Quote
