Post Build:
Video of first try startup IMG_1208.mp4 video by netnews - Photobucket
edit; 6/10/16 -- dynoed 453 ft-lbs & 405hp on e85, ran out of fuel.. more to come
Background:
Daily driver
Fast forward to Easter 2011, started using large amounts of oil -- no smoke
priced out a stock motor rebuild from motorworks, $4,000
Acquired a spare head ($250) and block ($500)
Searched others builds and this is the upgrade list I came up with after talking to MAP decided on
Feedback on MAP
communication = fair (oh it shipped, 10 days later-- still no gaskets)
price = good
shipping time = 6 weeks (paypal sent 6/9/11 gaskets received 7/20/11
If your car was DOWN like mine, I wouldn't recommend ordering from MAP
picked up a almost new southbend stage 3 clutch https://www.srtforums.com/forums/f213/hope-i-dont-regret-southbend-stage-3-clutch-612246/
slightly used struts
very used engine host and stand from craigslist
My all in ~$1500, considering i can resell my block head etc..
I found these rebuild links very helpful
https://www.srtforums.com/forums/f169/torque-spec-sheet-505635/
https://www.srtforums.com/forums/f75/how-remove-install-cylinder-head-421718/
https://www.srtforums.com/forums/f75/how-remove-engine-348916/
https://www.srtforums.com/forums/f169/wanna-build-your-own-direct-fit-strap-kit-608075/
https://www.srtforums.com/forums/f169/wanna-build-your-own-windage-tray-607397/
https://www.srtforums.com/forums/f24/crankshaft-sprocket-354735/
https://www.srtforums.com/forums/f75/how-renmove-oil-pan-622974/
https://www.srtforums.com/forums/f169/replacing-rods-pistons-motor-car-602544/index4.html
Link to my S3 w/Evo8 turbo install https://www.srtforums.com/forums/f169/my-install-s3-manifold-dcr-evo8-turbo-318192/ and muffler install https://www.srtforums.com/forums/f24/muffler-question-618698/#post9377890
https://www.srtforums.com/forums/f163/srt-4-suspension-faq-416630/
link to adding a camaro muffler to the rear exhaust section https://www.srtforums.com/forums/f24/muffler-question-618698/#post9377890
https://www.srtforums.com/forums/f169/will-re-building-my-motor-next-week-advice-605399/index7.html#post9135980
Not that i'm ever building again, but next time i would port the oil housing and go with 3 gaskets so i could run a big filter
Here are a few pictures of the build
td05hr upgrade from 16G to 20G compressor wheel
- Built motor, pistons (8.8:1 weisco) - cylinder honing is a must, rods (Eagle H), ARP head and Strap bolts
- my own strap kit, direct fit http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBoQFjAA&url=http%3A%2F%2Fwww.srtforums.com%2Fforums%2Ff169%2Fwanna-build-your-own-direct-fit-strap-kit-608075%2F&ei=6kt_TtHyI-nb0QHmvcD_Dw&usg=AFQjCNHDwcf-w67hK_Grjm9_uqvXMr1h5Q
- my own windage tray http://www.google.com/url?sa=t&source=web&cd=2&ved=0CCUQFjAB&url=http%3A%2F%2Fwww.srtforums.com%2Fforums%2Ff169%2Fwanna-build-your-own-windage-tray-607397%2F&ei=6kt_TtHyI-nb0QHmvcD_Dw&usg=AFQjCNHxllOUtp5sS1zf5Gldx52S_lHGLw
- https://www.srtforums.com/forums/f75/how-fuel-pump-rewire-more-reliable-simpler-cheaper-627811/
- my own lower torque arm pre-tensioner
- my own clutch pivot https://www.srtforums.com/forums/f75/how-build-clutch-pedal-pivot-5-a-644469/#post9852498
- LCA with spherical rear bushings from MOOG ($20 ea) https://www.srtforums.com/forums/f75/how-lca-spherical-rear-bushing-20-arm-677162/#post10387114
- Balance Shafts Removed
- EVO8 Turbo - td05hr-16g, upgraded to a 20G 47#
- Polished head
- EVO8 WGA
- BFMIC 4", CXRacing w/cast end caps
- 80# Seimens fuel injectors
- Walboro 255lph --- i've updated to a 450 here's the link https://www.srtforums.com/forums/f75/how-walbro-450-install-guide-782289/
- DSP w/custom rescale (much better than the SCT)
- opened up oil pickup
- SouthBend Stage 3 Clutch (hope i don't regret this), w/pivot,bearing, & fork
- replaced front and rear struts
- stock motor mounts filled with 3M window weld
- my own pre-tensioner
- opened up stock oil pickup
- UEGO
- Corvette rims w/ 275/40/17 w/ 2" spacers
- Prothane LCA
- Downpipe Needswing v5
- K&W air filter
- 255lph fuel pump rewire w/ more reliable & cheaper method https://www.srtforums.com/forums/f75/how-fuel-pump-rewire-more-reliable-simpler-cheaper-627811/
- big filter PH8a (w/3 spacers), https://www.srtforums.com/forums/f24/oil-adapter-version-delta-modification-626914/
- E85 conversion
- DCR lite weight rear adjustable Lower Control arms https://www.srtforums.com/forums/f258/dcr-lite-weight-rear-lcas-494560/#post7023990
- ToDo: water injection
- wanna build your own oil flow restrictors https://www.srtforums.com/forums/f169/wanna-build-your-own-oil-flow-restrictors-636872/#post9723083
- Prenco 36-1196 Ignition Coil
- Exhaust studs - Dorman Products - 03411B comes with 10 studs and nuts and is only 3mm longer than the factory studs, measure 55mm long factory is 52mm long -- RUN a tap through the nuts to remove the locking TABS!!!!
- IAT Gromit doorman 42058
Background:
Daily driver
- I don't have a lot of $$$ for this build
- I'm not a mechanic, prior to this build my big automotive project was installing stage 3
- ~70,000 miles (2006) upgraded to an s3 manifold (DCR ramp mod) with a evo8 td05rh-16 turbo https://www.srtforums.com/forums/f169/my-install-s3-manifold-dcr-evo8-turbo-318192/
- installed prothane LCA bushings
- Added a muffler https://www.srtforums.com/forums/f24/looking-quiet-down-muffler-537712/#post7950445
- CX Racing cast end BFMIC 4" https://www.srtforums.com/forums/f24/cx-racing-intercooler-questions-589949/#post8841712
- upgraded tires to 245/45/16 Corvette rims (and 275/40/17) https://www.srtforums.com/forums/f136/what-tire-pressure-275s-583665/
- needswing downpipe w/o cat
- don't use bosch 02, use ntg
- Plug NGK 4306, lztr5a-13 -- gap .040
- E85 link http://www.hotrod.com/articles/hrdp-0801-e85-ethanol-alternative-fuel/
- best friction material for brakes, rock auto, Posi Quiet Semi-Metallic, http://www.centricparts.com/products/brake-friction
- ebrake tighten adjustment drive=down, pass=up
- Mopar Top end gasket set: 60.00
- Mopar Lower end gasket set:35.00
- Mopar Water Pump:70.00
- Mopar Oil Pump:89.00
- Our crank strap bolts (ARP bolts) ~120
- King Main/ Rod Bearings: 38.00
- ARP head Studs: 115.00
- Eagle Rods, H w/ upgraded ARP 2000 bolts: 299.00
- Wiseco Pistons 8:8-1: 420.00
Feedback on MAP
price = good
