Ok, so here it is. I started out with a perfectly good brand new 2002 Camaro SS. I did a bunch of bolt ons, cam and then ended up with an STS turbo kit. I finally got it working right. Got one run in with a terrible launch...
Turbo 2002 Camaro 12.058 @120.3 mph. Spun a rod b - Car Videos on StreetFire
Clackety clack at the end of the track. Doh!
Surprise. Surprise. Turns out I had a broken number 7. Accidentally overboosted a few times...
So, the disassembly began...then the wife ran away with the kids...so it sat. Then a couple/three years ago after getting other things in order...
So I decided to heck with the rear mount set up and decided to do it right this time. So, I've been out getting parts and here is basically what I have...
- Moser 9" w/spool and 3.25 gears (low miles)
- BMR turbo k-member
- Kenny Brown double diamond SFCs
- QA1 adjustable shocks w/eibach springs
- Forged LS1 built by Larry's, Mahle pistons, scat rods, stock crank, 9.1:1
- 243 heads, valve job, new Lunati springs and retainers
- ARP Head Studs
- LS9 Head Gaskets
- New LS7 lifters
- New stock rockers with trunion upgrade
- New gaskets and seals from oil pan to headers, all of them
- Virginia Speed Turbo cam VTC-2
- New Poly motor and tranny mounts
- Truck manifold turbo kit, ST80 turbo
- Mccleod adjustable master cyl and gm slave
- UMI adjustable torque arm and crossmember
- New LS6 valley cover - for better PCV
- Edelbrock victor jr intake with proflow elbow
- The original transmission (T56)
I started assembling the motor the other day. I put an LS6 valley cover on for better PCV action. I had to do a little surgery to make it fit.
Short block
Surgery
Results
Ok, now put on the valley cover, lifters, heads, cam, timing chain, Doh!!!! Too much slack in timing chain. Waiting for parts...
- ARP Head Studs
- LS9 Head Gaskets
- New LS7 lifters
Short block
Surgery
Results
