The build - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > General Car Discussion > Build Threads
Old 11-07-2011, 09:28 PM   #1 (permalink)
SRT of the Month
turbo666's Avatar
Member Number: 25206
Default The build
I'm hesitant to even post a thread due to being another extreme SRT-4 build that turns out to be nothing more then a bunch of expensive parts with no real result due to some issue whether it's money, problems, or personal issues. But shit happens so at this point I'm going to be optimistic and just say it'll be a nasty car. That's how I justify the money/time. lol.
The car was VERY streetable with the last setup and with the 4" aluminum Vibrant muffler it was actually pretty quite. I enjoyed driving it around town and making the occasional pull through 1-3rd, and occasionally 4th. But I haven't actually street raced this car in almost 2 years (just guessing, don't remember exactly). But the temptation to rip the heads off the local retards is always there. But getting caught won't do a lot for me so why risk it?
That's why I decided to pull the trigger an make the car very track oriented. How? Well here is a list of what I can remember I removed:
-HVAC box and all HVAC tubing behind dash
-radio
-HVAC control box (but buttons are glued on the plastic cover)
-E-brake handle and all cables, brackets, and shoes related to it
-All speakers
-Padding on fire wall
-Airbag control box
-brake, ABS, SRS bulb
-ABS control module in engine bay
-All ABS sensors and wiring related to ABS
All of that together was 80lbs or so.
Car already had p/s, a/c, sound deadening, trunk was stripped, and carpet insulation removed.
I'm probably going to remove rear seats and carpet also. Driver seat is being replaced with a Kirkey and eventually passenger too. Car will have harness's installed along with 10 point Chromoly cage with chute mount.
Old setup:
-stock bottom
-AMM Race head
-Crane 18's
-Stock Taco mile ported I/M
-Stock T/B
-DCR oil kit
-Full Blown Rail
-Low Z Ford Racing 1680cc injectors
-Borg Warner 91-79 (66mm) twin scroll turbo
-Custom local made twin scroll manifold
-Twin Tial 38 MVS gates
-3.5" downpipe to 4" "cat" back
-tunergeeks CX Racing FMIC
-Stock 1st gen steel tank with sump
-Magna Fuel 750 pump
- -10an fitting and -8 return
-Aeromotive regulator
-MSD wires
-NGK 4306 plugs
-ACT Twin Disc
-Rage Acc. Shaft
-DCR 3/4 modified 3/4 setup
-Rage 3/4 fork
-DCR modified selector housing
-Rage Solid bushing in shifter
-Psi Fi solid engine mounts
-solid trans mount
-ARP head studs with DCR nuts and washers
-N2MB boost box and WOT box
Of course still no EMS!
New setup:
-Borg Warner S400 67mm billet wheel with 1.25 a/r housing (ordered)
-new manifold built by me (soon to be in the works)
-4" downpipe by me (soon to be in the works)
-FM long rod freshened up by me (done)
-Kevin Warren crank strap (have)
-Kevin Warren Ion treated crank (have)
-Same AMM head
-Same ARP studs with DCR nuts and washers
-FM 5 layer headgasket (have)
-DCR Custom center feed I/M (in the works)
-DCR mount relocate kit with aluminum side plate (in the works)
-DCR oil system (have)
-FIC 2150cc injectors (have)
-Same fuel tank with 750 pump and Full Blown rail
-NEW tunergeeks FMIC with Garrett core (have)
-sameTial 38 MVS gates
-Mole billet tone wheel (have)
-billet oil pump gears (have)
-ATI damper (have)
-3" IC piping all made by me (soon to be in the works)
-ACT twin with re lined disc (in the works)
-DCR 3/4 gear setup (same one)
-Kevin Warren input shaft with 1st and 2nd (in the works)
-DCR 3/4 fork (have)
-Same DCR modified selector setup
-SS clutch line with Tilton flow control valve
That's all I can think of at the moment engine wise. lol.
Car also now has a CNC brake staging brake now. ExoSpeed 3 piece front end is about to be fitted up.
Suspension is still the same as it's been:
-BC Coilovers
-Hotchkis sway bars
-Full Polyurethane bushing kit
-DCR rear control arms
Hoping to have a full drag brake kit all around. Rear wheel ARP studs are already done. Just need to put the ARP studs in the front once I take my regular neon spindles apart I have laying around. If money allows I'll consider DCR tubular K-member and front LCA's.
With ditching the ABS I did a 05 Neon w/o ABS and w/ rear disc master cylinder and it's factory lines
I spent around 10 hours thinning out the front factory harness, That didn't even save 3lbs. lol. But whatever. It all adds up.
I don't really have a whole lot of pics yet, usually when I get the chance to work on this thing it's late at night and the last thing I worry about it taking pics.
Anyways thanks for checking this out. I'm super busy right now so the car probably won't run again for a while. It's gotten cold a good bit quicker this year and honestly my car doesn't pay the bills so it's not a priority at the moment. lol. I plan to attend several events next year if all goes well.
HUGE THANKS TO:
Fuel Injector Clinic
Diablo Sport
DCR
RealTune
Tunergeeks
Kevin Warren
TDS
Turbojonsrt4
dsmfan95
and many other's I'm too sleep to remember at the moment
Full Builds, Fab Work, Dyno Tuning and parts all available. Message me for any details!
9.74@146 on a DSP tune FIRST STOCK SRT-4 PCM TUNED CAR IN THE 9s!
Look no further for proven performance parts and tuning!
Nigel
http://www.brutalfab.com/store/
Old 11-07-2011, 09:28 PM   #2 (permalink)
SRT of the Month
turbo666's Avatar
Nigel
Old 11-07-2011, 09:29 PM   #3 (permalink)
SRT of the Month
turbo666's Avatar
Nigel
Old 11-07-2011, 09:30 PM   #4 (permalink)
SRT of the Month
turbo666's Avatar
reserved 3
Nigel
Old 11-07-2011, 09:31 PM   #5 (permalink)
SRT of the Month
turbo666's Avatar
reserved 4
Nigel
Old 11-07-2011, 09:33 PM   #6 (permalink)
turbo2oh's Avatar
Member Number: 50941
Badass! I cant wait to see progress and results!
2004 eblue neon srt4 Beast mode
2009 white/blue suzuki sfv650 lean machine
1990 honda accord go getter
2004 Subaru legacy wagon
turbo2oh is offline   Reply With Quote
Old 11-08-2011, 06:12 AM   #7 (permalink)
SRT of the Month
tunergeeks's Avatar
Member Number: 11549
Dont worry nigel...... yours just wont be another bad ass build thread with no results.... you will get it all lined out....
Look forward to racing with you next season!!!!
Getting armed to go hunting in 2012..... Hopefully better armed this time!!!!
tunergeeks is offline   Reply With Quote
Old 11-08-2011, 06:30 AM   #8 (permalink)
jvalisxxx's Avatar
Member Number: 71131
Off to a good start, subscribed for the never ending build
-Justin
NEW! 2010 Wicked White EVO X GSR
2003 Flame Red SRT4
(Gone)
Instagram/Twitter: jvalisxxx
Xbox GT: famous random
jvalisxxx is offline   Reply With Quote
Old 11-08-2011, 06:30 AM   #9 (permalink)
SRTotM Moderator
Dragoncustompc's Avatar
Member Number: 76531
Nice Nigel man. cant wait to see it all come together.
But it could use some more FM parts
Sales assistant for Forward Motion Inc<- Click link
email sales@forwardmotioninc.com
Phone (302)-658-2829
12.8 @108. 312hp/371trq on 93 pump gas. E1 turbo, FM manifold, FM intercooler, FM wastegate.
DynoTuned by Nigel, El Ralfo Racing driver
Dragoncustompc is offline   Reply With Quote
Old 11-08-2011, 06:44 AM   #10 (permalink)
SRTotM Moderator
Bad98rt's Avatar
Member Number: 78946
HAHAHAHA Nigel thinks he he wont have a fast car...
you went 10s on stock block .. knowing you Nigel you'll have hell of a car
Huge thanks to Chris, Bill, And Bob @MAPerformane for 95% of all my parts
Huge Thanks to Kevin Warren For.. Many many things
MAP EF4 stock block, stock head
452whp on EMS at 26 psi
100&92 octane mix
Fully built long block and big numbers coming!
Bad98rt is offline   Reply With Quote
Old 11-08-2011, 07:32 AM   #11 (permalink)
strokedracer05's Avatar
Member Number: 77818
nigel dont sweat it we all know this car will be badass rome wasnt built in a day and well stuff does come up as i know all too well but lets hope to see this beast up and running good luck!
strokedracer05 is offline   Reply With Quote
Old 11-08-2011, 10:20 AM   #12 (permalink)
SRT of the Month
turbo666's Avatar
Haha thanks guys. I don't doubt my ability to get it running. Hell a big turbo and built engine is really the easy part. It's when you start cutting out a lot of wires, changing up brake system, adding a roll cage that things become more time consuming.
Nigel
Old 11-08-2011, 10:30 AM   #13 (permalink)
NJ DSM's Avatar
Member Number: 46989
Bump for nigel. Good guy.
Oh and in for the perpetual benchracing
Quote: Originally Posted by turbojonsrt4 View Post
gtfo srsly
njdsm>joo
NJ DSM is offline   Reply With Quote
Old 11-08-2011, 04:19 PM   #14 (permalink)
edub20's Avatar
Member Number: 65499
subscribed, looks good nigel!!
Evan
2004 dodge srt-4 (stockish)
1997 dodge neon (srt swap)
edub20 is offline   Reply With Quote
Old 11-08-2011, 05:09 PM   #15 (permalink)
Member Number: 86456
looks good
dmilone34 is offline   Reply With Quote
