Soooo. Just finished up with my engine build and thought I would share the events that I have went through.
Car was purchased from a local (a member here as well) back in March of 2011. I had watched the car appear on Craigslist in mid-2010 from a person in Suffolk who looked like he needed to dump the car quickly. Sadly it disappeared and I thought that my search for a CE was lost. The body looked ok other than it needed a side mirror like it was barely hit on that side?? Definitely fixable. It supposedly had mod x and mod z and had piqued my interest. Low and behold it appears again in late 2010 with a pricetag of $14K. I knew that the car sold for around $6-7K and probably less since the person in Suffolk seemed desperate. I watched the car fiercely hoping that the price would drop. I believe that the new owner wanted to quickly flip the car for almost twice for what he paid. Good strategy if you know what you are getting in to....
Problem 1: http://www.srtforums.com/forums/f189/new-meth-589406/
Ok not so bad...
Problem 2:
From:http://www.srtforums.com/forums/f25/rebuilt-motor-now-i-have-issues-593069/index5.html
Problem 3:
From: http://www.srtforums.com/forums/f347/fs-engine-transmission-mopar-plug-wires-594727/index2.html
Here is the history as far as I can trace it.
Date 05-03-2011
Now here is the ad that I made contact on from Craigslist:
2005 srt-4
Date: 2011-02-12, 11:06PM
i have a FULLY BUILT 2005 commemorative edition srt-4 only 200 were made...I have number 153 of 200 Car has 43k miles on it, motor has been rebuilt by brian cox from virginia speed 8k miles ago.. Car hasnt been tuned in a while so it needs a good tune right now car puts down around 350 whp, thats without any meth and stock aem ems base map tune. with a new tune and meth car will put down around 450WHP (or more until you max out injectors)...with bigger injectors..Car can handle over 600 WHP..Just inspected as of 12/5/10 and brand new tires were just put on as well as an altinator belt and power steering belt ..mods are as follows
Motor:
Wiseco 9:1 pistons
Eagle Rods
Clevite 77 bearing
Machine block
Polished and balance crank
ARP Head studs
Crower cams
stage III ACT clutch and flywheel
Port and polished head.
AEM Engine Management System (brand new)
880cc Injectors
AEM fuel rail
225 fuel pump
Garrett GT35r dual ball bearing turbo
Tubular EX manifold
3" downpipe
3" exhaust
2 1/2 hotpipe
alc injection kit
AEM boost cont
SOLID notormounts
D2 fully adjustible coilovers
New Starter
New Rebuilt transmission.
the Bad: The car has a rattle coming from the block, I have taken the car to 3 shops, it is not a rod or anything because the rattle is too inconsistent plus it wont do it at idle and it only starts above 2k rpms.... 2 out of the 3 shops said it is a broken wrist pin, along with a bunch of my budddies. The car drives fine besides the rattle
also have a DC strut bar i will throw in.
$7000 or best offer
the car has ALOT of money put in to it...I just need some money..
So I go and see it. 2-15-2011
I edited the previous owners screenname to xxx.
Ok not so bad...
Problem 2:
Hmmmmm.
Problem 3:
Ruh roh. Looking for a shortblock isn't good. Noted....
Date: 12-04-2010
Date: 03-26-2011
This one is hilarious! Posted after the car was in my hands for about 2 months. We'll see why later on.
Date 05-03-2011
Now there is a reason that I posted the dates for those two quotes as something happened when the PO purchased the vehicle and when I did as it appears that it was in the hands of the PO for approximately 3 months. Sad state of affairs.
2005 srt-4
Motor:
Wiseco 9:1 pistons
Eagle Rods
Clevite 77 bearing
Machine block
ARP Head studs
Crower cams
880cc Injectors
AEM fuel rail
225 fuel pump
Tubular EX manifold
3" downpipe
3" exhaust
2 1/2 hotpipe
alc injection kit
AEM boost cont
SOLID notormounts
New Starter
$7000 or best offer
