Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Chrysler/Dodge Garage > Dodge Vehicles > Dakota Discussion
Old 08-28-2003, 08:07 AM   #1 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Default First Look: 2004 GMC Canyon-Dakota competition
This is why there is a early release of the 05 Dakota...Steve
Completely redesigned with some early input from Isuzu, the smaller pickup carries many styling cues from the full-size Silverado.
By Mark Williams
Photography by the manufacturer
Truck Trend, August 2003
The long-anticipated S-10/Sonoma replacement pickups from Chevrolet and GMC are almost here. While manufacturers like Ford and Dodge are slow to redesign their compact/midsize pickups, GM has jumped into the pool with both feet. Completely redesigned with some early input from Isuzu, the smaller pickups carry many styling cues, as predicted, from the full-size Silverado.
2004 GMC Canyon Specs:
Price range $15,000-$27,000
Vehicle layout Front engine, RWD, 4WD
Engines 2.8L/174-hp I-4, DOHC, 4-valves/cyl; 3.5L/220-hp I-5 DOHC 4-valves/cyl
0-60 mph, sec 9.2 I-4 (est); 8.6 I-5 (est)
Power options for the new midsize (Chevrolet doesn't classify these as compact pickups anymore, mainly because buyers want bigger small trucks) include two powerful engines (a Vortec 2800 I-4 and 3500 I-5), both based off the Vortec 4200 I-6. The two engines share about 75 percent of their components with the bigger 4200 and about 90 percent of their parts between each other.
Output is 174 horsepower and 185 lb-ft of torque for the 2.8-liter I-4, while the 3.5-liter I-5 offers 220 horses and 225 lb-ft of torque--considerably more than any other V-6s offered in the class. An engine first includes a cast-aluminum block, coil-on-plug ignition, variable valve timing, and electronic throttle control. In addition, Chevy expects its pickups to offer the best fuel-economy numbers in the category --- by a wide margin (to date, EPA numbers haven't been released, but we'd expect somewhere around 27 mpg for the I-4, 21 for the I-5).
Other highlights include standard rack-and-pinion steering, optional head and side airbags, oil-life and tire-pressure monitors, and a strengthened Hydra-Matic 4L60-E four-speed automatic transmission. Both engines will have a new five-speed manual transmission option, as well. Colorados and Canyons will be offered in Regular Cab, four-door (access doors) Extended Cab, and four-door Crew Cab body styles, with three (standard, sport, and off-road) suspension packages. In addition, each will be offered with a locking differential in either two- or four-wheel drive.
The midsize GM pickups will go on sale at the end of this year and will be produced out of GM Shreveport Truck Plant in Louisiana. Look for more details in an upcoming issue.
Reference: www.motortrend.com
hemidakota is offline   Reply With Quote
Old 08-28-2003, 02:53 PM   #2 (permalink)
DODGE DRAGON's Avatar
Member Number: 1800
Blah. It's a polished turd!
I-5? Come on now....decent HP ratings....but give me a 05 DAKOTA.....NOW...not now....NOW
Any exact dates on the Dak, HemiD?
Custom Daytona Blue Pearl
DODGE DRAGON is offline   Reply With Quote
Old 08-28-2003, 03:15 PM   #3 (permalink)
91na's Avatar
Member Number: 2517
Who in their right mind would put a I-4 in a truck! I dont care if it is a "compact" truck or not.
Also, is chevy using this I-5 in anything else, if they are not... that sounds pretty dumb too. Why make an odd ball engine that you can only use in 1 (2 if you count GMC and Chevy different) auto.
Black 2003 Mach I
5-speed w/IUP
Current Mods:
Magnaflow Catback
Diablo Predator (Performance Tune)
K&N Drop-in
Mods to be installed:
Mac O/R H pipe
Motive 4.10's
FRPP 31 Spline LSD
FRPP HD 31 Spline Axles
91na is offline   Reply With Quote
Old 08-28-2003, 03:33 PM   #4 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
According to Keith, it is a early release in the spring of 04. But I would wait for the Hemi R/T hit in the summer of 04.
However, things can change between now then.
Old 08-28-2003, 03:34 PM   #5 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
DCx is in the process of bringing back the slant 6.
Page generated in 0.15019 seconds with 11 queries
