Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Chrysler/Dodge Garage > Dodge Vehicles > Dakota Discussion
Old 02-03-2004, 04:31 PM   #1 (permalink)
bjsmokey1980's Avatar
Member Number: 1123
Unhappy 1995 Dodge Dakota Won't Start... HELP
Is there anyone that can help me out on this? I have a 1995 Dodge Dakota 3.9L V6 Fuel Injected.
I was getting in the truck one morning and it started with no problem. As soon as a put the truck in reverse, it stalled and I tried to start it again with no luck. If I remember correctly, there was a faint electrical smell that was noticable for a few seconds then went away.
When I took a look under the hood and at the fuel pump relay socket, some of the plactic surrounding one of the connecters was burnt. However, I really didn't think that it was a electrical problem because the fuel pump is priming when I turn the key.
I played with it a liitle more and tried to start it with the fuel pump relay out of the socket and the truck started for a few seconds then quit running again. So, I started it again with the fuel pump relay not installed and had a friend standing by to plug the relay in when the truck started again. Well, the truck started again and my buddy put the relay back in and I hit the gas and it continued to run. However, I had to keep my foot on the throttle to keep it from stalling and it smelled like it was running really rich. It sounded like it wasn't running on all the cylinders and was backfiring every few seconds.
Has anyone experienced this problem with their Dakota or another car. I find it very strange that it would start without the pump relay in the socket??
Any ideas... Thanks,
Brandon
2004 Black SRT-4
Mods: stg 2 w/toys(almost) + mp-bov + k&n drop
bjsmokey1980 is offline   Reply With Quote
Old 02-03-2004, 06:28 PM   #2 (permalink)
DODGE DRAGON's Avatar
Member Number: 1800
Go post this over at www.DakotaUSA.com......I'm sure someone can help you out......don't forget to post in the currect location.
Custom Daytona Blue Pearl
DODGE DRAGON is offline   Reply With Quote
Old 02-07-2004, 02:20 PM   #3 (permalink)
hemihunter's Avatar
Member Number: 6843
Thumbs up wont start?
Brandon
its hard to fix that without looking at it. but obviously you have a short going on there ,check your fuses ,grounds,and wires ,a wire could be rubbing on bare metal somewhere, with the insulation cracked or broken away. not seeing it first hand thats the best i can do, but thats where i would start. best of luck !!! hemihunter
hemihunter
hemihunter is offline   Reply With Quote
Old 02-08-2004, 02:47 PM   #4 (permalink)
Member Number: 5953
See if this helps:
http://faq.dakota-truck.net/Electron..._stalling.html
If not, ask the list, there are many, many knowledgeable Dakota people there.
MrSpeed is offline   Reply With Quote
Page generated in 0.22429 seconds with 11 queries
