Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > Parts/Shops/Tuner Reviews
Old 08-08-2009, 05:25 PM   #1 (permalink)
Member Number: 31376
Trader Rating: (12)
Default N2MB produces the best boost controller hands down!!
If you want rock solid boost control with absolutley NO PTB, then head over to N2MB (Never 2 much boost) and check out their newest creation... the boost box. These guys are just crazy when it comes to perfecting their products and won't stop until all kinks are worked out. I have their boost box on a stock turbo/WG and can hold 18 psi with NO SPIKES WHATSOEVER! The boost comes on instantly and holds perfectly. This gizmo allows you to set different boost levels in each gear. Can you say no more wheel spin! Set 1st gear to 5 psi, and launch as hard as you want. Jon and Jay will always treat you right and stand by their products..
[x] MSD wires
[x] MBV
[X] Eibach pro kit
[ ] FM Wastegate (hit me up if your selling)
[X] N2MB boost box (you guys need this!)
I've modded/demodded this car twice in an attempt to sell her but just couldn't do it. 3X a charm???
allaboutboost is offline   Reply With Quote
Old 08-08-2009, 06:14 PM   #2 (permalink)
SonnySrt-4's Avatar
Member Number: 34315
Trader Rating: (10)
Link to said product....and can wot feature be added?
Edited by Inzanesrt4
Agp s3d-44lb turbo kit
38mm TurboSmart Wga
3inch bdj's catless down pipe dumped exhaust
BFMIC
N2MB Boost box (GET ONE!!!)
D/O Meth/Alchy injection m5
DSP tuner
800cc injectors
HKS bov and hard pipe
SonnySrt-4 is online now   Reply With Quote
Old 08-08-2009, 06:29 PM   #3 (permalink)
xzero's Avatar
Member Number: 50867
Trader Rating: (17)
N2MB Racing both can be used but you must have both boxes but you can switch your wot box into a boost box by dowloading firmware and rewiring. But both are compatible with each other you just need 2 boxes to have them at the same time.
03 SRT-4
xzero is offline   Reply With Quote
Old 08-08-2009, 06:34 PM   #4 (permalink)
SonnySrt-4's Avatar
Trader Rating: (10)
Does this work the same on big turbo/external wga setup as it would on a stock turbo setup?
Old 08-08-2009, 11:22 PM   #5 (permalink)
xzero's Avatar
Trader Rating: (17)
They are currently coming with a way to work with the external wastegates its not perfect yet though but it will be
Old 08-10-2009, 08:52 PM   #6 (permalink)
Trader Rating: (12)
I think they now have a car running big turbo/ex.wg and have worked the kinks out. Here is a link to the thread discussing it.
http://www.srtforums.com/forums/f245...ftware-525964/
Page generated in 0.15832 seconds with 13 queries
