Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > Parts/Shops/Tuner Reviews
Old 11-04-2009, 04:15 PM   #1 (permalink)
Member Number: 42413
Question DSS issues
Has anyone else on here had problems with there axles. I am about to send back my 4th one without ever getting to put more then like 10 miles on any of them. The first one was splined wrong, the next 2 were not tempered right and the ends came off, and this last one was milled off so it was leaking fluid from around the seal (it was about a 1/4" difference from stock and that was causing that problem and it to bottom out).
So I am going to hopefully be getting my 5th yes 5th axle from them in a week or so. I am just wondering if I am the only one that has had this much bad luck or if anyone else has had something happen like this.
By the way the passenger side has been fine through all this.
Just wanted to add that there service and wanting to help has been great though. No issues with getting stuff to them and back.
Member 685
RVDSRT4 is offline   Reply With Quote
Old 11-04-2009, 05:12 PM   #2 (permalink)
Member Number: 45174
i had a problem with them but i broke the welds inside the axle and trans fluid was leaking out. but other then that they are working just fine. they even warrantied it for me. they told me that this was the second time they had this problem but its fixed now.
i remember getting head on the bed because my wife just wanted to feel my dick in my mouth (pregnancy thing)
carlos nice
hshredder18 is offline   Reply With Quote
Old 11-04-2009, 08:31 PM   #3 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
stock axles ftw..
BIG TURBO!
Old 11-04-2009, 10:23 PM   #4 (permalink)
Member Number: 33203
Trader Rating: (25)
Quote: Originally Posted by Xx_R/T_xX View Post
stock axles ftw..
fo shizzle
Precision 6057@30psi on pump
8.50@87 on 10psi w/2.0 60 ft (wg pressure on 30 psi tune, no 2 step)
Contact Turbo666/TDSaaron for your tuning needs.
turbojonsrt4 is offline   Reply With Quote
Old 11-05-2009, 07:42 AM   #5 (permalink)
i went through 2 set of stock axles in 3 months. No more problems after the little leak on the DSS.
stock axles
Old 11-05-2009, 08:06 AM   #6 (permalink)
red04's Avatar
Member Number: 24993
Trader Rating: (49)
We have seen the driver's side axle be .004" to big so it won't slide all the way into the diff. We check everyone before we send them out.
Scott @ Forward Motion Inc.
302-658-2829
www.forwardmotioninc.com
Email: scott@forwardmotioninc.com
Paypal Address: scott@forwardmotioninc.com
Owner of FM's GT37R powered SRT4 513 whp 469 wtq pump gas (93 octane) @ 6,000 rpms
11.31 @ 131.74 mph w/ 1.90 60'
red04 is offline   Reply With Quote
Old 11-05-2009, 08:58 AM   #7 (permalink)
Trader Rating: (25)
stock axles
Theres a lot more things that kills axles than just power. Most people don't understand that.
Old 11-05-2009, 09:08 AM   #8 (permalink)
like wheel hop. i have the dog bones and trans mount and coilovers. my problem was power.
Old 11-05-2009, 10:37 AM   #9 (permalink)
Trader Rating: (25)
You forgot suspension geometry, which with coilovers, you definitely could have affected. Also you can easily break an axle with an improper burnout.
Regardless, I'd rather replace a $130 axle which is pie to change, than break something inside the tranny that will A) cost more, and B) be much more of a pain to fix.
My tranny should be pretty much bulletproof ( as much as possible anyway), still I'd rather have axles be the weak link because let's face it, no matter how much money you spend on aftermarket parts, there will always be a weak link somewhere.
Old 11-05-2009, 08:15 PM   #10 (permalink)
finfast srt4's Avatar
Member Number: 10147
Im also sending my axle in for the forth time today in fact. first axle was my fault but ever since i had the axle it wobbled and it was found to have the wrong length passenger side bar. the seconded was the transmission was leaking into the cv area and it has always fit way to hard into the diff. I got it back and within a month it did it again and within a month of getting it back guess what, it did it again and im sending it back once again for the same problem. i talked to a few different employs and they were all rude and ignored the problem. i finely go to talk to the owner and he is taking care of everything for me and was a big help. If it wasn't for the owner i would of never bought another product from DSS. The owner knows how to take care of his customers. if your having any problems i would call and ask to speak to frank.
finfast srt4 is offline   Reply With Quote
Old 11-05-2009, 08:29 PM   #11 (permalink)
Member Number: 9751
I will be testing a new style of dss axle here in the next few weeks look for a complete write up on them.
****Second street Srt-4 in the 9's 9.95@143****
Time to make some BIG power
kevinwarren240 is online now   Reply With Quote
Old 11-06-2009, 07:24 AM   #12 (permalink)
when i called DSS i never had a rude employee on the phone. I must have always talked to frank i guess. Whats new about the new style?
Old 11-07-2009, 12:00 AM   #13 (permalink)
Member Number: 9751
this just may be for the 1000hp axles but they use a 904 cv joint with chromoly cage for the balls instead of the tripod setup like the stock axles and 3-5 dss axles do.
Old 11-07-2009, 05:21 PM   #14 (permalink)
I was about to say new style you mean one that actually fit's the car
Old 11-08-2009, 02:03 AM   #15 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
But that will be for auto's only? Or for the stick cars as well? Have you had problems with your current axles?
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Page generated in 0.16788 seconds with 13 queries
