Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Racing Wheels and Tires
Old 10-09-2009, 02:23 PM   #1 (permalink)
04blusrt_4's Avatar
Member Number: 60369
Default Biggest Tire on 15x7 Tire stock struts?
All stock suspension, have 15x7 rims that are 35mm offset, but still need a 5mm spacer to clear the brake calipers. So I would be running those spacers with the rims.
Looking for a drag radial that would fit, can you guys help me out?
*NE 400 Club*
Old 10-09-2009, 02:36 PM   #2 (permalink)
srtstan's Avatar
Member Number: 62363
235/60r15 they are mb racing rims. pretty sure they are 35mm offset and i used a gold spacer ring that pops inside the rim.they are M&H racemaster tires. i have no problems with fitment
S0, FM WGA, AGP return line kit, walbro 255, ATP Hard pipe and HKS BOV,perrin sri, custom 3in downpipe and O2 housing,Mopar cat-back, MPX Big fmic, AGP Dog bones, AGP catchcan, msd coil and wires, mopar sts, gold-line, LCA bushings, Act HDSS, AEM wideband, DSP, own injection . but still too slow....for now
srtstan is offline   Reply With Quote
Old 10-09-2009, 02:37 PM   #3 (permalink)
04blusrt_4's Avatar
Thx, anyone run any bigger? Maybe a 245/60r15?
Old 10-09-2009, 03:51 PM   #4 (permalink)
SRTforums Admin
stowaway's Avatar
Member Number: 3286
the M&H is the only 235/60-15 that fits reliably on stock suspension. Most are too tall. You need to pull the actual dimensions to see what fits. 25.6" tall is really the maximum you can use.
Old 10-09-2009, 08:04 PM   #5 (permalink)
Member Number: 10255
Trader Rating: (54)
235 would be it. Thanks Guys
SlicksMH
Give us a call @ the M&H Warehouse 661.324.4773
mandhtires
SlicksMH is offline   Reply With Quote
Old 10-11-2009, 08:06 AM   #6 (permalink)
Member Number: 33203
Trader Rating: (27)
I ran the mickey thompson et streets in 235/60/15 on stock struts with a 2" drop, if not more. They're 26.1" tall and they fit. I used 15x7 kosei k1's.
I'm pretty sure my next tire will be 26x10.5x15 or 16. I do have coilovers now.
stock
I<3 Haters.
Contact Turbo666/TDSaaron for your tuning needs.
WTB: Dual function wot box! PM me!
turbojonsrt4 is online now   Reply With Quote
Old 10-12-2009, 06:52 AM   #7 (permalink)
04blusrt_4's Avatar
How did those hook?? Did you run them just on the street or the track?
Old 10-13-2009, 07:25 PM   #8 (permalink)
Trader Rating: (27)
More street than anything but I made a few passes at the track on them. They're far better than a street tire or a bfg drag radial. I still spun them from a 2nd gear roll but that was making over 400whp. If you want the best traction, you're gonna want a bias ply tire which is why I'm planning to do 26x10.5 bias ply et streets or m&h's soon.
Old 10-14-2009, 06:12 AM   #9 (permalink)
04blusrt_4's Avatar
how do bias handle for daily driving? I assume they are a bit sloppier cornering and have a harder overall ride, no?
Old 10-14-2009, 08:21 AM   #10 (permalink)
Trader Rating: (27)
It would be a mix between a slick and a radial. I wouldn't say the ride would be hard, considering its a soft tire with no steel belts, but yes the handling part would be affected a good bit considering they're basically a wrinkle wall slick. The et street would by far be the better if you're gonna drive it a lot, but if you can drive with caution, then the bias ply will be the way to go. I've driven on my 26x8.5 slicks and skinnies on the rear quit a few times. That can be a handfull to drive if you aren't careful, but with caution, it is controllable.
Old 10-14-2009, 02:19 PM   #11 (permalink)
04blusrt_4's Avatar
ET Streets come in bias and radial, so I suppose you would still recommend the ET Street radial?
Ive tried BFG and Nitto, both spun even on stock turbo in 2nd. I want a 2nd gear hook
Old 10-14-2009, 04:42 PM   #12 (permalink)
Trader Rating: (27)
Yeah the et streets I had were the radials. They handle great. With about 20psi in them, you forget they're even up there to be honest. You still need to drive with caution around turns obviously and do your best to stay out of rain, but overall they're a great mix between traction and drivability. My bfg drs spun all of second gear on stock turbo as well with a measly 240whp/280tq. I dunno how people hook on those but I had terrible luck with them. If you heat the et streets up good, run low air pressure, and have good suspension, you MAY get them to hook from a 2nd gear roll with 400+whp, but that's a maybe. I'll be happy with something that hooks in 3rd.
