check valve.... need to repaint the engine bay areas when done again! lol.
[IMG]
[/IMG]
Fuel return kit mounted with bung in with no nitrous. Finishing that soon.
[IMG]
[/IMG]
vaccum line for tial
[IMG]
[/IMG]
MSD Tach adapters for the DIS-4 box...wasnt getting a strong enough intermediant signal. We are now, the spark is unreal loud sounds like an arck welder. haha or a small horn.
[IMG]
[/IMG]
[IMG]
[/IMG]
Vaccum lines fromt the wastegate coming through
[IMG]
[/IMG]
Top View, with the msd tach adapters and AEM boost silonoild mounted.
[IMG]
[/IMG]
I put msd quick disconnect water proof connecters on everything with all our problems and things comin off and on so many times.
[IMG]
[/IMG]
Cold side pressure pipe V-band connection
[IMG]
[/IMG]
Hampster wheel shot....
[IMG]
[/IMG]
Oil drain tube.... AN beybeby!
[IMG]
[/IMG]
over view shot...I like looking at the engine bay, we have put so much time into it. We have done alot of the work other then welding.. Almost all wiring, mouting and install.
[IMG]
[/IMG]
lol, wires for the fog light relays for HIDs and the headlight HIDs and the other stuff..lols of wires I know i tried to keep them nice tho with disconnects and tried to hide them...
[IMG]
[/IMG]
the intercooler with the sprayer bar attached.. with the quick push on fittings.. badass. Richard made the Sprayer bar by the way if your wondering...custom size and spray.
[IMG]
[/IMG]
[IMG]
[/IMG]
HID ballast for one fog light and one Headlight.
[IMG]
[/IMG]
The nice mounting nuts for the intercooler.
[IMG]
[/IMG]
Same deal Fog light ballast and Headlight ballast for HID lights.
[IMG]
[/IMG]
AEM Injector driver mounted on the Driver side...
[IMG]
[/IMG]
Stock silnds moved
[IMG]
[/IMG]
5 relays we made for , Fans, Nitrous Sprayer bar silnd, Left Headlight HID, Right Headlight HID, Fog lights.
[IMG]
[/IMG]
Dont Judge the wire mess right now, i keep making all the wires pretty and hiding them and then we would have to tear them apart to trouble shoot. GAY so they will be cleaned up when we get all the bugs out.
[IMG]
[/IMG]
See i keep the wires clean when i know im done with an area....
[IMG]
[/IMG]
Hot side pressure pipe connection shot..
[IMG]
[/IMG]
Coolant feed and oil feed...
[IMG]
[/IMG]
profile picture...
[IMG]
[/IMG]
Nitrous bottle number one.. Dont judge only sprayed it once so far and it needs to be sanded and sprayed again. Behind driver seat....
[IMG]
[/IMG]
[IMG]
[/IMG]
battery
[IMG]
[/IMG]
