Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > Showoffs/Pictures
Old 04-17-2008, 06:36 PM   #1036 (permalink)
BoostLee's Avatar
Member Number: 26266
Trader Rating: (99)
Mani problems?
Dealer for Aaronneon Owner of Real Tune Performance.
Contact Me For AGP/RAGETEK/REALTUNE/MAXXFAB/DO H20 INJ./AEROFORCE/FORWARD MOTION PARTS
11 Second Club GT35R, 28PSI, AEM EMS
BoostLee is offline   Reply With Quote
Old 04-17-2008, 06:55 PM   #1037 (permalink)
bpsrt4's Avatar
Member Number: 40796
Trader Rating: (24)
Quote: Originally Posted by BoostLee View Post
Mani problems?
Not really anymore...I had a clearance issue w/ the shift cables and compressor housing but that isn't a problem anymore. I think I've got it figured out.
Now I'm just waiting on a new compressor housing w/o the elbow on it. Then ya'll can have some pics
After I get the fenders rolled to..I had to raise the car up cause there were some "clearance issues" there to
bpsrt4 is offline   Reply With Quote
Old 04-17-2008, 07:04 PM   #1038 (permalink)
VanillaXtract's Avatar
Member Number: 27205
Quote: Originally Posted by 90VNT View Post
Think I am finally done.
Why not pc the thermostat housing and the block for the upper MM?
VanillaXtract is online now   Reply With Quote
Old 04-17-2008, 07:20 PM   #1039 (permalink)
BoostLee's Avatar
Trader Rating: (99)
Me <3 Darksyde
Old 04-17-2008, 07:22 PM   #1040 (permalink)
bpsrt4's Avatar
Trader Rating: (24)
Me <3 Darksyde
OOOO AAAAAAHHHHHH
Old 04-17-2008, 07:27 PM   #1041 (permalink)
SRTforums Veteran²
onthedwnlow's Avatar
Member Number: 27125
Trader Rating: (43)
what happened to go low or go home?
11.95 at 115.....Your local aflac representative pm me for more info
onthedwnlow is online now   Reply With Quote
Old 04-18-2008, 01:15 PM   #1042 (permalink)
bpsrt4's Avatar
Trader Rating: (24)
I'm getting them rolled then its going back down...I put the car on the ground and the fender was sitting on the tire
Nothing a little negative camber can't fix
Old 04-20-2008, 02:26 PM   #1043 (permalink)
infernosrt59's Avatar
Member Number: 41823
is that cf shield over your tranny a one off piece i could really use on e of those it is hot
hahn s20g+bolt ons=
infernosrt59 is offline   Reply With Quote
Old 04-21-2008, 05:06 PM   #1044 (permalink)
05moparsrt-4's Avatar
Member Number: 52352
Quote: Originally Posted by Network13 View Post
The catch can DOES NOT go in between the breather and the valve cover. Please be careful telling newbs incorrect information. Doing as suggested and not getting results is discouraging and damaging to the hobby. The reason yours is dirty is because you need a PCV Check valve, your leaking boost in to your valve cover through your PCV valve, pressurizing the valve cover, and blowing oil out the breather. I've had my set up for several months now and not a drop of oil in the breather element. Get plenty in the catch can though.
It should go from the throttle body to a check valve, from the check valve to a catch can, then from the catch can to the PCV valve.
on the box it says run the tube from valve cover to the catch can, and the another tube from the catch can to the intake???? whats the difference if you do it that way or to the pcv valve/throttle body???????????
red is the fastest.....
05moparsrt-4 is offline   Reply With Quote
Old 04-21-2008, 08:21 PM   #1045 (permalink)
SRTforums Veteran²
Trader Rating: (43)
because at idle there is not much vac in the intake but the intake mani has alot.....so the line from the pvc to the intake helps pull the vapors from the crankcase at idle and the line from the valve cover to the intake will help pull the vapors out under boost.....it keeps a free floating crankcase and should help gain some extra ponies and make the motor last longer
Old 04-21-2008, 08:57 PM   #1046 (permalink)
icic but would it hurt to do it the other way?
Old 04-22-2008, 01:02 AM   #1047 (permalink)
JesseL's Avatar
Member Number: 51882
Trader Rating: (21)
Installed the AEM, didn't like how they wanted me to mount the stock ECU... (ok ok, didn't wanna figure it out, easier to make my own brackets)
JesseL is offline   Reply With Quote
Old 04-22-2008, 11:20 AM   #1048 (permalink)
SRTforums Veteran²
Trader Rating: (43)
what other way?.......the way i described should be the only way
Old 04-22-2008, 03:19 PM   #1049 (permalink)
like i said, in the directions it says to connect tube from drivers side of vc to cc, then the other tube from cc to intake, but most people here are going cc to tb then cc to pcv......
Old 04-22-2008, 07:57 PM   #1050 (permalink)
SRTforums Veteran²
Trader Rating: (43)
the directions prob say intake mani not intake.....if you did it the way you decribe you would have one hell of a boost leak and it would do absolutly nothing
