Quote: Originally Posted by beyondspexj
whats your mod list? nice custom radiator
Got time to read?
Interior:
* Sparco Torino II Front Seats and 4 Point Harnesses
* Sparco "Ring" Steering Wheel
* MOPAR Short Throw Shifter. Andrew's.
* DynoTune.Org Digital Boost/Fuel Pressure Gauge
* Turbosmart ?e-Boost 2? Programmable Boost Controller
* SPA Dual Oil Temp and Pressure Gauge
* NHRA Certified to 8.99sec. 10 Point Roll Cage with Swing outs (Race Car Builders)
* Zeitronix UEGO Controller. Displayed through Car Computer- EGT, Boost, RPM, TPS and Lambda
* Car Computer with 7? LCD Touch Screen and DVD burner (Enrique)
Exterior:
* SuperAutoShield 3M Clear Bra
* Custom 304SS 3.5? Exhaust with Dual In-Line Borla XR-1 inline mufflers (Billet Design)
Suspension, Brakes and Wheels:
* TCE Wilwood Big Brake Kits; Front- 13.0" x 1.10" rotors with FSL calipers and Rear- 12.2" x .81" rotors and special application billet DynaLite calipers.
* IPP 32 way adjustable Coilovers
* Ground Control Camber Plates
* Hotchkis Front and Rear Sway Bars
* OZ 17x8 Superleggera?s
* BFG g-Force T/A Drag Radials 225x45x17
* "Mr. Parker" Parking Brake Kit.
Drivetrain:
* DSS Stage 5 Axles
* Rage Tech Twin Disk Clutch and TOB with Fidanza Lightweight Flywheel
Engine:
* Engine Blueprinted and Balanced (TEC)
* Wiseco Pistons
* Crower Rods
* Ferrea SS Valves "Custom" (Inconel Exhaust) (Rage)
* "Electromotive" TEC3r Engine Management (Electromotive and Rage)
* Electromotive TEC4 DFU- Direct Fire Ignition Coils
* MSD Plug Wires and NGK Plugs
* Turbonetics Turbo (AGP) Custom Specs
* Turbonetics 38mm ?Evolution? Wastegate (AGP)
* TiAL 50mm Blow Off Valve (AGP)
* Custom fabricated Intercooler. (Bell Intercoolers, Rage Tech and Billet Design)
* Crank Scraper and Oil Pan Baffle (crank-scrapers.com)
* CNC Ported Head (Rage Tech)
* Unorthodox Racing Adjustable Cam Gears. (Rage)
* Crane Cams "Custom Grind" (Rage)
* Crane Valve Springs and Titanium Retainers
* Custom fabricated Intake manifold with 75mm Wilson TB. (Rage Tech and Billet)
* Custom fabricated Equal Length Tubular 321SS Turbo Exhaust Manifold (Rage and Billet)(icengineworks.com)
* DCR main bearing strap kit.
* DCR Oil Pump Gears.
* ARP Cam stud kit.
* AGP Motor and Transmission Mounts
* 5 BAR MAP Sensor
Fuel System:
* Custom Fuel System- Surge Tank, Dual External Walbro High Pressure 255s
* 1600cc Injectors
* Custom Fuel Rail and Aeromotive Fuel Pressure Regulator (Rage)
Sounds:
* "KICKER" Stereo Custom Sub-woofer rear strut tower brace
* XM Satellite.
* Rear Battery Mount with Cut Off Switch.
