Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > Showoffs/Pictures
Old 09-30-2006, 05:22 PM   #271 (permalink)
WantToRaceANeon's Avatar
Member Number: 43990
here is mine, its not much but its getting there
mopar exhaust
mopar bov
mopar strut barces front and rear
mopar sts
mopar cold air intake
AGP WGA 18 psi spike 15 to redline
needs wings 3" catless dp with cutout
13.54 @ 96.99
14.16 @ 102 with cutout open
WantToRaceANeon is offline   Reply With Quote
Old 10-01-2006, 09:27 PM   #272 (permalink)
valeriekay_2000's Avatar
Member Number: 27795
Trader Rating: (26)
just out of curiosity, where is everyone hiding their vac lines at?
valeriekay_2000 is offline   Reply With Quote
Old 10-01-2006, 09:54 PM   #273 (permalink)
04yellowsrt's Avatar
Member Number: 32684
Trader Rating: (20)
Mine are completely gone, and I tucked the solenoids behind the headlight.
04yellowsrt is offline   Reply With Quote
Old 10-04-2006, 04:40 PM   #274 (permalink)
SRT-4 Technical Disscussion Moderator
Shifty's Avatar
Member Number: 19343
Trader Rating: (57)
T1 Race Development
Tuned By Tony Palo
Shifty is offline   Reply With Quote
Old 10-14-2006, 01:17 PM   #275 (permalink)
KeyboardCommando's Avatar
Member Number: 38988
hmmmmm im curious about that intake manifold......who makes it, and where can I get one
To all mods: These boards are overly cluster fucked. you hear me? theres too much bullshit on all the sides...
KeyboardCommando is offline   Reply With Quote
Old 10-14-2006, 07:48 PM   #276 (permalink)
Shifty's Avatar
Trader Rating: (57)
What intake ? Oh thats the agp 3inch intake
Old 10-14-2006, 08:36 PM   #277 (permalink)
rob1987's Avatar
Member Number: 14254
I wasnt aware that agp made INTAKE MANIFOLDS....i think thats what he was asking about, not ur intake. Unless u were being sarcastic.
rob1987 is offline   Reply With Quote
Old 10-16-2006, 03:16 PM   #278 (permalink)
JonnyBlaze's Avatar
Member Number: 37767
yeah i would like one of those too
JonnyBlaze is offline   Reply With Quote
Old 10-16-2006, 03:20 PM   #279 (permalink)
MySRT4IsFast's Avatar
Member Number: 22190
Trader Rating: (12)
wont happen guys, its been tried time and again
MySRT4IsFast is offline   Reply With Quote
Old 10-16-2006, 03:34 PM   #280 (permalink)
JonnyBlaze's Avatar
that makes me sad
Old 10-16-2006, 04:45 PM   #281 (permalink)
SRTforums Veteran²
onthedwnlow's Avatar
Member Number: 27125
Trader Rating: (43)
1.) the best way i have found to route the catch can is this......pvc valve to breather filter........opposite side to catch can to intake nipple.....still works like the factory designed but get rid of the boost leak related to it.....a+++ in my book
2.) if you run a staged computer with a aftermarket wg and bov you can get rid of all the lines running to the stock solnoids and just tuck them down in the whole behind the headlight...but be careful and make sure to keep the solnoids connected to the wires just not the vac lines because they will throw codes with out the wires connected
really cleansup that side of the engine bay...polishing the a/c lines is aso a plus to make it all clean...and all you relly need is a can of mothers polish and a buffer wheel on a drill and abut 30 minutes....looks awesome
11.95 at 115.....Your local aflac representative pm me for more info
onthedwnlow is online now   Reply With Quote
Old 10-17-2006, 03:25 PM   #282 (permalink)
Network13's Avatar
Member Number: 36188
Trader Rating: (42)
I'm not sure if you responded the the wrong thread or what but your shits hooked up all wrong.
The correct way to have a catch can is
PCV valve to--> catch can --> catch can to--> throttle body. If you have a PCV check valve it needs to go between the throttle body and catch can so as to prevent the catch can from ever beeing pressurised by boost, (they aint designed to do that) The breather element on drivers side of the valve cover is optional but must be able to breath in and out, weather its hooked to the stock air box foam element or an after market breather.
PCV stands for positive crank case ventillation, what part of your breather is providing the positive part of that equasion? You have a catch can hooked up to the drivers side of the valve cover?? That needs a breather but there is no need for a catch can, it shouldn't have anything to catch if you had the PCV system connected correctly. If it is collecting oil currently than thats your motors rings not sealing and you have blow by.
Lemme break it down for you.
Vacume from the intake pulls blow by vapors from the valve cover via the PCV system, hence why you end up with oil in the upper pipe, the motor is constantly pulling vapors from under the valve cover to the intake. There is a active vacume in the valve cover all the time unless your under boost. To solve this vacume from sucking oil to the throttle body, and ultimately in to the combustion chamber, you install a catch can that allows the oil to settle out before it reaches the throttle body.
The breather on the drivers side of the valve cover is just that, a breather so there is never a true vacume created in the valve cover and it equalises pressure and vacume in the valve cover. If you are getting oil out of the drivers side off the valve cove that means your PCV valve is leaking boost in to the valve cover and you sould invest in a PCV check valve, or in your case, there is blow by pressurising the valve cover and blowing oil out where the breather should be.
Guess again my foreign friend,
American Muscle will DO You IN!
South Florida SRT Owners Club
http://www.floridasrtoc.com/
Network13 is offline   Reply With Quote
Old 10-18-2006, 02:34 PM   #283 (permalink)
SRToc Member
quick4dr's Avatar
Member Number: 18686
04 Black SRT 12.7 @ 116 on Toyo proxies stock turbo R.I.P July 04 - Feb 08
quick4dr is offline   Reply With Quote
Old 10-18-2006, 02:39 PM   #284 (permalink)
SRToc Member
quick4dr's Avatar
Old 10-18-2006, 03:07 PM   #285 (permalink)
2kneon's Avatar
Member Number: 10846
Trader Rating: (31)
1993 Rx-7 Z06 corvette driveline with built valvetrain, and supporting mods, spray 500+ hp
Fully built suspension and the works. 10 sec. car
2004 Srt-4 50 trim and works at its prime 11.9 @ 121 mph
2kneon is offline   Reply With Quote
