» Tire Upgrade Garage
Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > Showoffs/Pictures
Old 02-22-2006, 07:56 AM   #151 (permalink)
srtwannabee's Avatar
Member Number: 5866
Quote: Originally Posted by 2.4TURBOMAN
Here is mine.
how did u paint ur caps and ur oil dipstick handle???
1 of 1,067 Silver 05's
CSC member # 58
srtwannabee is offline   Reply With Quote
Old 02-22-2006, 12:29 PM   #152 (permalink)
SRT623's Avatar
Member Number: 26778
do you guys ever drive your cars?? lol
SRT623 is offline   Reply With Quote
Old 02-24-2006, 11:35 AM   #153 (permalink)
Member Number: 13362
Trader Rating: (109)
I used engine paint .
2.4TURBOMAN is offline   Reply With Quote
Old 02-24-2006, 11:49 AM   #154 (permalink)
Mr.Neon's Avatar
Member Number: 21573
Mr.Neon is offline   Reply With Quote
Old 02-26-2006, 01:48 PM   #155 (permalink)
jmduke3's Avatar
Member Number: 11611
Where do you pick up the part that is covering up the tranny? I have the Injen SRI and just looking at that tranny ugly as hell staring back at me
jmduke3 is offline   Reply With Quote
Old 02-26-2006, 02:04 PM   #156 (permalink)
Falbz's Avatar
Member Number: 22294
Trader Rating: (55)
http://www.jmbperformance.com/transcover.htm
To make a purchase please go to http://www.pt-performance.com/
Falbz is online now   Reply With Quote
Old 02-26-2006, 02:15 PM   #157 (permalink)
Member Number: 17858
[IMG]http://www.****************/attachment.php?attachmentid=488&d=1140295815[/IMG]
[IMG]http://www.****************/attachment.php?attachmentid=487&d=1140295802[/IMG]
[IMG]http://www.****************/attachment.php?attachmentid=133&d=1132698766[/IMG]
Grifter is offline   Reply With Quote
Old 03-01-2006, 09:49 AM   #158 (permalink)
SRToc Member
manic_mopar's Avatar
Member Number: 25488
Trader Rating: (31)
still a work in progress.
L3TZ xXx HUGx3: are u a rapist too
HoTSaUZe310: im a jack of all trades
L3TZ xXx HUGx3: i got to go peace
Pablo Tuned
298WHP/354WTQ I'm a meth addict...
...you know you want to hear them....
manic_mopar is offline   Reply With Quote
Old 03-01-2006, 11:04 AM   #159 (permalink)
SRT-4 Technical Disscussion Moderator
Shifty's Avatar
Member Number: 19343
Trader Rating: (54)
Here is mine.
there's a finger print on ur intake manifold , u might want to get that fixed
T1 Race Development
Tuned By Tony Palo
Shifty is offline   Reply With Quote
Old 03-01-2006, 11:19 AM   #160 (permalink)
Supporting Vendor (Bronze)
SRT4_Night_Rider's Avatar
Member Number: 28848
Its a bad pic and a few things have changed since the pic, like a moved the catch can and got new hoses for it. but here it is.
STAY TUNED TO SEE WHAT HAPPENS TO THE LOOK MY CAR
Garret 60-1
XtremeBoost Manifold
STS 60mm TB
Ported TB Spacer
RC 750 Injectors
PTP 80psi FPR Mod
180 T-stat
Walbro 255 Fuel Pump
Mopar STS
Mopar Stage 1
8.5 Plug Wires
3" Downpipe
Fighters Grarage Hardpipes W/Greddy typeS
ARP Head Bolts
QuickWhips Intercooler
Dogbone Motor Mounts
SAFC & AEM Wideband
SRT4_Night_Rider is offline   Reply With Quote
Old 03-08-2006, 07:20 AM   #161 (permalink)
Wheat_Burner's Avatar
Member Number: 12004
Trader Rating: (115)
Here is mine.
That looks really good. You're like me, you need to do something with your t-stat housing.
Info on the battery terminal covers/battery cable connectors would be appreciated.
Quote: Originally Posted by red_power
dale, for someone who sucks at driving like you you sure do talk alot of shit..noob
Wheat_Burner is offline   Reply With Quote
Old 03-08-2006, 10:55 PM   #162 (permalink)
04yellowsrt's Avatar
Member Number: 32684
Trader Rating: (20)
what kind of mini sideways mounted battery is that a lot of u have?
11.02@125
04yellowsrt is offline   Reply With Quote
Old 03-09-2006, 08:55 PM   #163 (permalink)
Probably from someone touching it at a car show , People love to walk up & touch all the carbon fiber & polished stuff for some reason .
Thanks , you can get the battery terminals at audio stereo stores .
Old 03-17-2006, 03:22 PM   #164 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
Quote: Originally Posted by 93TT
Yeah man, not really hard to do, just alot of manual labor.
Basically, this is how I did it. First you need to sand off all the rough casting, which is the texture created when the pieces were made. To do this I used 80 grit sand paper. Use a sanding disk with a drill on the easy parts, then switch to a dremel with a mini sanding disk for tighter areas. Then finally you'll have to sand by hand the really tight areas and corners. Also, I didn't sand the underside of the intake manifold as it would never be seen. During this stage I sanded off the "16 Valve Dual Cams" off the valve cover for a cleaner look, plus it would've been a pain to polish in between those small letters.
When you finish with this step, repeat everything with 120 grit paper/ disks.
The goal of each sanding step is to remove the scratches and lines from the last lower grit paper. This is the key to make it look really good. Don't move on to 320 grit paper until you have "erased" the 80 grit texture and replaced it with a 120 grit texture. Then, only move up to 400 grit when all the 120 has been changed to 320. You do this because it is very hard to remove heavy scratches with a fine paper.
Also, all grits finer then 120 were hand sanded because they don't sell fine grit sanding disks. I broke up the work to one grit per day, just so I would'nt rush it and leave scratches behind. After 320 grit I moved on to 400, 600, 800, 1000, 1500, 2000. I could've probably stop at 1500 or 1000, but I wanted a real shiney chrome-like look. 800 and up grit I wet-sanded.
At this stage the piece should be really, really smooth but not shiney, more like a dull grey, similar to anodized aluminum. Inspect it to make sure everything is sanded and no noticable deep scratches have been left behind. Once, your happy with it go have a beer, the hard work is done!
Polishing is alot easier, you'll be using both the drill as well as the dremel along with an asortment of polishing compounds and buffing wheels. Here's a link to where I bought mine if you don't have them:
http://www.hobbytool.com/polishing.htm
Use your drill on the big areas and use your dremel for tighter areas. You should be able to get every area using various shaped buffing attatchments. I used the black compound, then brown, finally the red. Each one the aluminum will get shinier and shinier. It'll blow you away when the first compound turns the dull metal to almost a mirror like finish! The final result is going to depend on how well and complete you sanded, so put in the work if you want it to look good! You could probably do one piece in a weekend if you do nothing else.
you write a how to in the how to section?
And transfer this to the detailing section also.
Own a Rear Wheel Drive Nissan/Datsun or Infiniti?
www.RWDNissan.com
SRTGURL's SRT-4 SIte:
www.srtgurl.com
Old 03-26-2006, 12:50 PM   #165 (permalink)
04PAcruz'n's Avatar
Member Number: 8512
finally got a chance to take some pics. e-blue with red.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Mods:
S2 w/o, JMB Ported IM+PTP 55mm TB, PTP charge pipe, Mopar TB Exhaust (cat-back+cat-delete), Mopar CAI, Spearco DF-IC, Samco IC hoses.
Mopar Stage 1 suspension (springs+sways), rear tension struts, Mopar front STB, Pwerks rear STB, mm inserts (street)
Mopar STS, Mopar BOV,4306 NGKs, JMB catchcan, Pwerks grounding kit, PTP check valve
04PAcruz'n is offline   Reply With Quote
