LinkLow November ROTM Thread - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > SRT Showoffs/Pictures
Old 10-26-2012, 04:31 PM   #1 (permalink)
LinkLow's Avatar
Member Number: 75469
Default LinkLow November ROTM Thread
First and foremost, thanks to everyone who nominated me...I appreciate it
This is pretty short notice for me, so I'm having to use a few old and low qulity photos of the exterior. Engine bay pics are semi-current and the videos are from a few days ago so they are current as well. The current exterior of the car can be seen in the first video
I bought this particular car in 2008 with 31,xxx miles as the second owner and it's been under the knife on and off since then.
On to the mod list...
Engine/Turbo/Performance:
2.8L stroker
Custom Darton Dry sleeves
Custom Crower long rods (thanks to David Crower)
Custom JE pistons
Custom Crank
DCR "Eraser" Pro Outlaw cylinder head
Crower stg 3 intake cam, custom grind Crower exhaust cam
DCR head gasket
DCR Head studs, nuts, and washers
DCR Big filter kit
DCR Crank straps and windage tray
Full DCR valvetrain (+2/+3mm oversized valves)
Custom RTErnies Tubular exhaust manifold
Precision 6262 with .82a/r turbine housing (ported hotside)
Custom aluminum 4" dumped exhaust
Custom 3" intercooler piping
CCA 4" core intercooler
JMF Intake manifold
Boomba 70mm throttle body
N2MB WOT BOX
N2MB 2 step
N2MB Boost Box
Stock coilpack
Granatelli Wires
NGK 3 step colder plugs
Drivetrain:
ACT Twin disc
Rage-Tek accelerator shaft
Rage-Tek clutch pivot
Stock gears
Stock synchros
Stock selector
Stock forks
Never had one problem
Fueling:
E85
FIC 2150cc injectors
Magnafuel 4303 Pro Tuner fuel pump (inline)
Walbro 255 (intank, supplying surge tank)
-10an feed line
-8 return line
Boomba fuel rail
Magnafuel Prostar FPR
CX Racing 2 liter surge tank
Suspension/traction:
BC Inverted Coilovers
Motegi FF7 wheels (street)
26x9.5x15 Hoosier QTP Drag radials (street)
Kosei K1 wheels (track)
M&H 24.5x8.5x15 (track)
Suspension has been set up to a 60/40 weight split between the front and rear
Car is weighted down an extra 210lbs in the front for traction purposes on the street and the weight is removed for track outings.
Custom suspension travel limiters
Tune:
Stock '05 PCM
Diablosport Predator with CMR tune by Brian McMahan and myself
Thanks to the guys who have helped me along the way (in no particular order)
Brian McMahan
Darrell Cox
Michael Santiago (formerly known as DRASTIC.) For bouncing ideas around with me for several months
Cory @ Modern Performance
Dave @ ACT Clutches
Nemo Foss @ Rage-Tek
Bad98rt for selling me a few of his own parts for stupid cheap
Video of idle
LinkLow is offline   Reply With Quote
Old 10-26-2012, 05:17 PM   #2 (permalink)
Nafter's Avatar
Member Number: 85296
Omg.... 8==D
Very nice setup
Engine Under Construction
Nafter is offline   Reply With Quote
Old 10-26-2012, 05:18 PM   #3 (permalink)
Creamer03's Avatar
Member Number: 62203
Got my vote! :thumbup:
Going for a Texas Top 10 1/4 mile spot...
Baby snail and E85...
Creamer03 is offline   Reply With Quote
Old 10-26-2012, 05:31 PM   #4 (permalink)
SRTFORUM Moderator
Advans's Avatar
Member Number: 12791
Shared your vid on my FB.
DAT comments!
Advans is offline   Reply With Quote
Old 10-26-2012, 05:36 PM   #5 (permalink)
jay05acr's Avatar
Member Number: 37744
Only thing I don't like are the seats... Other than that very nice
Go to wikyd-performance.com for all of your srt4 performance needs. Contact jtm0n3y or wonderer86 for more info
http://www.srtforums.com/forums/f416...-parts-639326/ my for sale thread
jay05acr is offline   Reply With Quote
Old 10-26-2012, 05:42 PM   #6 (permalink)
SRT of the Month
underSRTarmor's Avatar
Member Number: 32888
Ur car is sick!!!!! Link, nice.
Old 10-26-2012, 10:13 PM   #7 (permalink)
smctoy's Avatar
Member Number: 62758
sic ride!
smctoy is offline   Reply With Quote
Old 10-27-2012, 01:28 AM   #8 (permalink)
ares559's Avatar
Member Number: 81082
You'll have my vote as well sir
SRT: AGP .50 trim
Tuning on E85.
Tuned by Mindmelt101
ares559 is offline   Reply With Quote
Old 10-27-2012, 01:48 AM   #9 (permalink)
edub20's Avatar
Member Number: 65499
any numbers?
Evan
2004 dodge srt-4 (stockish)
1997 dodge neon (srt swap)
edub20 is online now   Reply With Quote
Old 10-27-2012, 12:13 PM   #10 (permalink)
LinkLow's Avatar
Quote: Originally Posted by edub20 View Post
any numbers?
It was dynoed long before it was ever turned up. Don't really care what it makes honestly. It does exactly what I built it to do so I'm happy
Old 10-27-2012, 12:40 PM   #11 (permalink)
SIX-SIX-SIX'ONE'NINE's Avatar
Member Number: 86743
And that my friend ^^^^, is how it should be done...got my vote good sir.
E85 is one hell of a drug.
[IMG][/IMG]
SIX-SIX-SIX'ONE'NINE is offline   Reply With Quote
Old 10-27-2012, 01:04 PM   #12 (permalink)
SRT of the Month
Got my vote.
Old 10-27-2012, 03:13 PM   #13 (permalink)
LinkLow's Avatar
Thanks
Old 10-27-2012, 03:39 PM   #14 (permalink)
comatoast's Avatar
Member Number: 85196
Numbers at the track
Turbo / TB - AGP Zeta 3.0 / 28 psi , AGP bfmic, Boomba 70mm tb Engine - Wiseco 8.8:1 pistons .020 over , eagle h-beam rods , king main and rod bearings , DCR crank strap kit, Head - FnF race ported exh ports , +2mm rev exh valves , BC springs and Ti retianers , BC stage 4 cams (280*s) , Boomba cam gears,
Fuel - , 900cc fic inj , -6an feed and return lines , fuel pump rewire , bottle neck fix , Bosch 044 intank , aeromotive rrfpr , E85..
comatoast is offline   Reply With Quote
Old 10-27-2012, 03:46 PM   #15 (permalink)
edub20's Avatar
you can PM me info if you want
Evan
