Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > Showoffs/Pictures
Old 03-23-2008, 07:37 AM   #1 (permalink)
shadydvh's Avatar
Member Number: 23154
Default Just added some more C/F
Hey guys, nothing you guys haven't seen before on other silvers, carbon fiber trunk with the new srt badge, but i still wanted to show it off cuz its mine..lol, I will add though, thats about it for C/F and I'm looking at doing something different to separate from the pack, anyways, thanx for looking
Derek Van Horne
Often Imitated, Never duplicated
Car Domain Web page
shadydvh is offline   Reply With Quote
Old 03-23-2008, 08:49 AM   #2 (permalink)
srtnate89's Avatar
Member Number: 59975
looks sick, is it from carbon by design?
2004 Flame Red
Stg 1, etc. + more to come
srtnate89 is offline   Reply With Quote
Old 03-23-2008, 08:53 AM   #3 (permalink)
2005 RED SRT-4's Avatar
Member Number: 35073
Trader Rating: (37)
That does look sick. I like the carbon trunk with the new badge and LEDs.
2005 RED SRT-4 is offline   Reply With Quote
Old 03-23-2008, 09:04 AM   #4 (permalink)
2Spools's Avatar
Member Number: 18960
Trader Rating: (17)
Put some Nightshades on the third brake light. Other then that I'd rock it.
Stage3 turbo/Stock pcm 11.58@124 JANNETTY RACING SCT TUNED
www.turboaddictionparts.com
2Spools is offline   Reply With Quote
Old 03-23-2008, 09:07 AM   #5 (permalink)
all motor's Avatar
Member Number: 56445
looks good, which one is it?
all motor is offline   Reply With Quote
Old 03-23-2008, 09:34 AM   #6 (permalink)
Member Number: 62678
Excuse my ignorance but what is c/f and why is your trunk black or grey? Is that primer?
Mr. potato head is offline   Reply With Quote
Old 03-23-2008, 09:52 AM   #7 (permalink)
04_EBlue_SRT4's Avatar
Member Number: 47348
Trader Rating: (15)
wow dude you need to read read and more read type in carbon fiber on the SEARCH BAR on the top left and read the stickies in the sections to learn more about your new srt
oh and C/F stands for carbon fiber a material that is more the half the weight of a factory hood/trunk
Sorry to break it to you, but my SRT-4 is faster than a viper! I can break the tires loose in first gear WITH the factory TCS.
04_EBlue_SRT4 is offline   Reply With Quote
Old 03-23-2008, 10:00 AM   #8 (permalink)
how am I supposed to search for "carton fiber" if i don't know it's carton fiber? I had no clue what c/f was until now. Is that primer on the c/f trunk?
Old 03-23-2008, 10:09 AM   #9 (permalink)
SRT4BTU's Avatar
Member Number: 32532
Carbon fiber or carbon fibre (also sometimes called graphite fiber) is a material consisting of long thin sheets of graphite-like carbon, packed to form a fiber. It is commonly used in composite materials such as carbon fiber reinforced plastic (which is often also called carbon fiber). It has the highest specific tensile strength of all the reinforced materials (composite materials), and it has a high strength to weight ratio and low coefficient of thermal expansion. The density of carbon fiber is also much much lower than the density of steel. [1] Carbon fiber takes the form of several thousand long, thin strands of material which are mostly composed of carbon atoms.[2]
History of Carbon Fibre
In 1958, Dr. Roger Bacon created the first high performance carbon fibers at the Parma Technical Center outside of Cleveland, OH. Bacon's carbon fibers were mainly graphite whiskers that were sheets of graphite rolled into scrolls; they contained graphite sheets that were continuous over the entire length of the graphite filament. After the development of carbon fiber, Bacon had estimated the cost to make high performance carbon fiber at "$10 million per pound." Bacon's development was a remarkable achievement at the time, and scientists and manufacturers were determined to find a cheaper and efficient way of producing the fibers. [3]
On the 14th January 1969, Carr Reinforcements wove the first ever Carbon fibre fabric in the world.[4]
Carbon fibers are the closest to asbestos in a number of properties.[5] Each carbon filament thread is a bundle of many thousand carbon filaments. A single such filament is a thin tube with a diameter of 5–8 micrometers and consists almost exclusively of carbon.
Structure and properties
The atomic structure of carbon fiber is similar to that of graphite, consisting of sheets of carbon atoms (graphene sheets) arranged in a regular hexagonal pattern. The difference lies in the way these sheets interlock. Graphite is a crystalline material in which the sheets are stacked parallel to one another in regular fashion. The chemical bonds between the sheets are relatively weak Van der Waals forces, giving graphite its soft and brittle characteristics. Depending upon the precursor to make the fiber, carbon fiber may be turbostratic or graphitic, or have a hybrid structure with both graphitic and turbostratic parts present. In turbostratic carbon fiber the sheets of carbon atoms are haphazardly folded, or crumpled, together. Carbon fibers derived from Polyacrylonitrile (PAN) are turbostratic, whereas carbon fibers derived from mesophase pitch are graphitic after heat treatment at temperatures exceeding 2200 C. Turbostratic carbon fibers tend to have high tensile strength, wheresas heat-treated mesophase-pitch-derived carbon fibers have high Young's modulus and high thermal conductivity.
Applications
(For common applications, see Carbon fiber reinforced polymer or CFRP)
Carbon fiber is most notably used to reinforce composite materials, particularly the class of materials known as Carbon fiber or graphite reinforced polymers. Another utilization of Carbon Fiber is its added aesthetic value to various consumer products.
Carbon Fiber as a tough and lightweight material is applied in the production of watch cases and dials. In watchmaking the material is often combined with polymer to improve its strength.[6]
Non-polymer materials can also be used as the matrix for carbon fibres. Due to the formation of metal carbides (i.e., water-soluble AlC) and corrosion considerations, carbon has seen limited success in metal matrix composite applications. Reinforced carbon-carbon (RCC) consists of carbon fibre-reinforced graphite, and is used structurally in high-temperature applications. The fibre also finds use in filtration of high-temperature gases, as an electrode with high surface area and impeccable corrosion resistance, and as an anti-static component.
Carbon fiber is also used in compressed gas tanks, including compressed air tanks.
Synthesis
Each carbon filament is made out of long, thin filaments of carbon sometimes transformed to graphite. A common method of making carbon filaments is the oxidation and thermal pyrolysis of polyacrylonitrile (PAN), a polymer based on acrylonitrile used in the creation of synthetic materials. Like all polymers, polyacrylonitrile molecules are long chains, which are aligned in the process of drawing continuous filaments. A common method of manufacture involves heating the PAN to approximately 300 °C in air, which breaks many of the hydrogen bonds and oxidizes the material. The oxidized PAN is then placed into a furnace having an inert atmosphere of a gas such as argon, and heated to approximately 2000 °C, which induces graphitization of the material, changing the molecular bond structure. When heated in the correct conditions, these chains bond side-to-side (ladder polymers), forming narrow graphene sheets which eventually merge to form a single, jelly roll-shaped or round filament. The result is usually 93-95% carbon. Lower-quality fibre can be manufactured using pitch or rayon as the precursor instead of PAN. The carbon can become further enhanced, as high modulus, or high strength carbon, by heat treatment processes. Carbon heated in the range of 1500-2000 °C (carbonization) exhibits the highest tensile strength (820,000 psi or 5,650 MPa or 5,650 N/mm²), while carbon fibre heated from 2500 to 3000 °C (graphitizing) exhibits a higher modulus of elasticity (77,000,000 psi or 531 GPa or 531 kN/mm²).
Textile
There are several categories of carbon fibres: standard modulus (250 GPa) , intermediate modulus (300 GPa), and high modulus (> 300 GPa).[7] The tensile strength of different yarn types varies between 2000 and 7000 MPa. A typical density of carbon fiber is 1750 kg/m3.
Precursors for carbon fibres are PAN, rayon and pitch. Carbon fiber filament yarns are used in several processing techniques: the direct uses are for prepregging, filament winding, pultrusion, weaving, braiding etc. Carbon fiber yarn is rated by the linear density (weight per unit length = 1 g/1000 m = tex) or by number of filaments per yarn count, in thousands. For example, 200 tex for 3,000 filaments of carbon fiber is 3 times as strong as 1,000 carbon fibers but is also 3 times as heavy. This thread can then be used to weave a carbon fiber filament fabric or cloth. The appearance of this fabric generally depends on the linear density of the yarn and the weave chosen. Some commonly used types of weave are twill, satin and plain.
SRT4BTU is offline   Reply With Quote
Old 03-23-2008, 10:42 AM   #10 (permalink)
slickneon19's Avatar
Member Number: 29777
Trader Rating: (15)
dude how old are you? seriously.......who in the car world these days dont know what carbon fiber is.....or c/f lol....with every new post i am gettin dumber by them
2001 Dodge Neon
Nikon D60
slickneon19 is offline   Reply With Quote
Old 03-23-2008, 10:44 AM   #11 (permalink)
I'm 47 years old & this is my FIRST sports car. Before this I owned a 2000 neon & a 1994 Cavalier. Those were the only other 2 fast cars i have owned.
Old 03-23-2008, 10:47 AM   #12 (permalink)
Trader Rating: (15)
dude those aren't fast cars and the srt4 isnt a sports car. its a tuner. a vette or viper or somethin of that sort is a sports car. LMAO!!!!!
Old 03-23-2008, 10:48 AM   #13 (permalink)
Are you calling my car slow you son of a bitch!
Old 03-23-2008, 10:50 AM   #14 (permalink)
Trader Rating: (15)
what.....god can you read? we have a dee da dee on our hands..
Old 03-23-2008, 10:52 AM   #15 (permalink)
Trader Rating: (15)
here i will explain it in detail for you...the NEON and CAVALIER are NOT fast cars. AND the SRT4 IS NOT a SPORTS CAR! Its a TUNER!!!!
» Sponsor Links
»Garage Storage and Cabinets
