Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > Showoffs/Pictures
Old 08-26-2007, 12:17 PM   #1 (permalink)
T U N E !'s Avatar
Member Number: 20706
Default Home-Made Black Housing Headlights
Here are a few pictures of my stock headlights with the housings painted black. This was done by hacking apart the headlights according to Milkit18's how-to found here: How-To: Hack & Paint Stock Headlight Housings
I separated the headlight lense with a dremel tool and cutting wheel. Then I masked off the reflectors and sprayed high-temp black paint. The lights were then re-assembled using "plastic weld" glue and silicone. So far, no leaks after some heavy rain
Great how-to with nice results.
T U N E ! is offline   Reply With Quote
Old 08-26-2007, 12:34 PM   #2 (permalink)
contraption22's Avatar
Member Number: 8377
Nice crack!
2004 Neon SRT-4
S2/E1, Mopar Turbo-Back
Times to come.
1986 Plymouth Horizon "GLMF"
2.2 SOHC 8-Valve, Super-50 trim, Spearco, Menegon head. 60hp NOS.
NEW Best ET: 10.61
NEW BEST MPH: 130mph
contraption22 is offline   Reply With Quote
Old 08-26-2007, 12:38 PM   #3 (permalink)
Member Number: 18082
looks good.. so when you doin mine... lol
newbie is offline   Reply With Quote
Old 08-26-2007, 03:32 PM   #4 (permalink)
T U N E !'s Avatar
Quote: Originally Posted by contraption22
Nice crack!
LOL there's no crack, they came out looking absolutely mint. I think you are seeing a reflection of the clouds in the lens.
Easy there buddy....your intercooler install is on priority
Old 08-26-2007, 06:43 PM   #5 (permalink)
Member Number: 33203
Trader Rating: (27)
Nice crack!
or maybe hes retarded and is seeing the gap between the inside of the headlight and the housing, where the headlight itself adjusts, and doesnt realize that gap is supposed to be there...or I do see on the side where the clouds are reflecting on it.
btw looks awesome!
stock
I<3 Haters.
Contact Turbo666/TDSaaron for your tuning needs.
turbojonsrt4 is online now   Reply With Quote
Old 08-26-2007, 06:46 PM   #6 (permalink)
SRT of the Month
OrionR12's Avatar
Member Number: 21193
Trader Rating: (148)
Nice crack!
If that is a crack then EVERY SRT owner has one! Go look at your own lights and see!
Nice job by the way...looks real clean!
-ryan-
'04 eBlue SRT-4 (44lb SNL Shocker Stage 3 w/ toys)
DARKSYDE powdercoating FTW!
In memory of Steven Nightshade Lorenz
OrionR12 is offline   Reply With Quote
Old 08-26-2007, 08:56 PM   #7 (permalink)
fine, fine first intercooler then headlights.. and so on...
Old 08-28-2007, 07:55 PM   #8 (permalink)
cooper232's Avatar
Member Number: 12276
Trader Rating: (10)
anyone made some black ones for a solar yellow car yet? i want to see some pics. i want to do this too! car looks great bro!
car slowly coming together now
cooper232 is offline   Reply With Quote
Old 08-28-2007, 08:03 PM   #9 (permalink)
marshall_634's Avatar
Member Number: 46515
Trader Rating: (10)
that looks great, i want to do that to mine
Having NOS is like knowing a hot girl with an STD...You KNOW you wanna hit it, your just afraid of the outcome
marshall_634 is offline   Reply With Quote
Old 08-28-2007, 08:05 PM   #10 (permalink)
boostdacr's Avatar
Member Number: 42254
Trader Rating: (19)
Looks good, i was thinking about doing mine but not sure if i want to go through the trouble or just buy some off ebay
05 ACR
08 GCSRT8
07 R6
boostdacr is offline   Reply With Quote
Old 08-28-2007, 08:25 PM   #11 (permalink)
srtspoolin's Avatar
Member Number: 30815
Trader Rating: (60)
looks good what paint did you use
srtspoolin is offline   Reply With Quote
Old 08-28-2007, 08:25 PM   #12 (permalink)
SRT of the Month
bitts's Avatar
Member Number: 29842
Trader Rating: (113)
To Do List this weekend...
[x] Grocery shopping
[x] wash car
[x] Do black head light housing
Looks good man
Borg Warner S256 JJ&B
Quote: Originally Posted by kylejoseph426 View Post
yes the pcm has been reset everytime. yes the timing is set perfect we used the Bitts cam tool
bitts is offline   Reply With Quote
Old 08-28-2007, 10:25 PM   #13 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (27)
damn those look good. if i wasn't so afraid of screwing mine up i'd do it...
how long from start to finish did it take?
Old 08-29-2007, 07:28 AM   #14 (permalink)
pabulos's Avatar
Member Number: 40335
thank you.. you just convinced me to do this
pabulos is offline   Reply With Quote
Old 08-29-2007, 11:06 AM   #15 (permalink)
T U N E !'s Avatar
Thanks for the compliments.
I used a can of high-heat matte black spray paint.
This actually isn't difficult, however if it's your only set of headlights, you will want to take your time and be careful. I did this mod over 2 days, but it definately could be done in 1 day.
I've got a couple of tips for those of you who want to try this:
- Read the thread linked in the first post
- Use a dremel with a larger cutting wheel; I think my wheel was about 40mm diameter
- I did not dis-assemble the internal housing, I just masked off the reflectors. I think this is the best way.
- Buy a couple of the tubes of "plastic weld" mentioned in the how-to thread. This stuff works great.
- When re-assembling the headlight, get the lens into position first, then apply the plastic weld to a couple of points around the lens just to secure it. Once the glue sets, then you can use a generous amount of the plastic-weld to fill in the gap all around. After that, I applied some silicone just to be safe. Don't bother with the expanding foam.
