Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > Showoffs/Pictures
Old 04-28-2008, 09:12 AM   #1 (permalink)
Member Number: 33203
Trader Rating: (18)
Default Had an extra headlight...
So I made a light for the track that I'll be able to connect to the 4" intake so its straight to the turbo. I've saw some cobra guys claim to pick up 2-3 mph by removing their headlight without having any kind of duct work so we'll see if this makes a difference or not. I went over it with a coat of spot putty to smooth out the taper around the pipe, after its dry I'll sand it down and spray it black.
turbojonsrt4 is offline   Reply With Quote
Old 04-28-2008, 09:17 AM   #2 (permalink)
rcshaggy169's Avatar
Member Number: 30300
Nice! what did you use for the tube inside the light? pvc pipe? post a pic or two of the finished product! it looks awesome
rcshaggy169 is offline   Reply With Quote
Old 04-28-2008, 09:21 AM   #3 (permalink)
Trader Rating: (18)
I used a piece of 4" aluminized pipe. PVC would have worked too but I want this to be the same stuff I used for my intake so that it would all fit up good. Thanks, I may have some finished pics later today.
Old 04-28-2008, 10:36 AM   #4 (permalink)
Main_Event's Avatar
Member Number: 12790
very crafty
+1 for finish pics
SonyAlpha
Main_Event is offline   Reply With Quote
Old 04-28-2008, 11:11 AM   #5 (permalink)
mikeh6's Avatar
Member Number: 14199
Trader Rating: (28)
also interested in finished pics! nice work
mikeh6 is offline   Reply With Quote
Old 04-28-2008, 11:16 AM   #6 (permalink)
Trev_Masta's Avatar
Member Number: 31571
pretty nice. are you going to be painting the headlight to color match the car?
-trev
http://forums.neons.org/viewtopic.php?t=303853 Built 2.0 Turbo w/Mega Squirt (IN PROGRESS)
Trev_Masta is offline   Reply With Quote
Old 04-28-2008, 12:28 PM   #7 (permalink)
Trader Rating: (18)
Nah it will be black when its done. That will match the other headlight better than red since I have black housing headlights and also a cf hood that would probably clash pretty bad with a red painted light, but I doubt this will get used enough to really worry that much about the looks anyway.
Old 04-28-2008, 12:30 PM   #8 (permalink)
Straight Boostinn's Avatar
Member Number: 53071
werd...i did this to my honda but not yet to the srt....wasnt sure how to take on doing it but it looks awsome....
looks 10x better then my 3in pipe i made to just sit there with the headlight removed....
Straight Boostinn is offline   Reply With Quote
Old 04-28-2008, 03:01 PM   #9 (permalink)
Wizardsrt-4's Avatar
Member Number: 44379
Its gonna look sic bro! Can't wait to see. Maybe if it really works you could make them in quanities and sell these bishes
Wizardsrt-4 is offline   Reply With Quote
Old 04-28-2008, 03:06 PM   #10 (permalink)
Member Number: 52518
Instead of making it round like the stock headlight would making it like a dish help more, so it catches more air?
boorahdurukan is offline   Reply With Quote
Old 04-28-2008, 03:39 PM   #11 (permalink)
SRThore's Avatar
Member Number: 49489
ive seen many hondas run this setup for the track, and a good buddy of mine with a gt says that its common for the stang owners to remove there passenger side light for the intake aswell.... post those pics!!!
SRThore is offline   Reply With Quote
Old 04-28-2008, 05:54 PM   #12 (permalink)
Trader Rating: (18)
If I didnt plan on running my 4" intake directly from the headlight to the turbo, your idea would be good, but I did it this way because the 4" pipe for the intake will fit right to it. I looked at ams's evo headlight after starting this and thought about doing something similar instead. I still dunno if Ima run into any clearance issues with running the pipe through the radiator support, if I do, I'll prolly redo it with a more open design like they did their evo headlight and do away with the piping to the headlight, but I really want it to be direct opposed to just letting air go everywhere instead of directly to the turbo.
Old 04-28-2008, 07:12 PM   #13 (permalink)
so did you extend the tube out the back of the headlight? sounds like this is going to turn out very nice
Old 04-28-2008, 08:15 PM   #14 (permalink)
Trader Rating: (18)
The pipe inside of the headlight is about 5-6" in length and the inside end is extruded so that a 4" pipe actualy slides into it, much like exhaust piping does. I'll hafta make an extra section to go from my intake to the headlight but I'll figure that part out once I see how well everythings gonna fit through the radiator support.
Old 04-29-2008, 03:36 AM   #15 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (28)
nice!!
Page generated in 0.21125 seconds with 11 queries
