Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Other Discussion > Showoffs/Pictures
Old 08-15-2009, 01:24 PM   #1 (permalink)
Green Machine's Avatar
Member Number: 58508
Default Amateur Porting Time!
Hey Folks, the weekend is here, and thought I would spend some quality time with the car. Anyways, what you are about to see is not professional by any means, and is almost as backyard as you can get without being in the backyard - lol.
I've been pondering the idea for awhile of trying to do some porting to my intake manifold, and throttle body. I just wanted to match it up to the block as best as I could, not just bore it out to it's maximum which really I don't think that necessary since the flow is restricted by the port holes on the engine block anyhow... This is by no means a how to, I probably did things that were not necessarily the proper way, but thought I'd share for fun anyhow.
BTW: If you ever do this, WEAR A DUST MASK an EYE PROTECTION - aluminum dust baaadd, mmmmkay?
Anyways, here we go...
1. Here are pics of the tools involved in this Friday night project... not shown in the picture are a air compressor, a good vice, and my slave monkeys.
2. Close up of carbide bits used for material removal. I used my rotozip, instead of using a airtool.
3. I just used a pencil and a piece of paper to take an imprint of the port holes on the block as a reference...
4. Here you can see the difference between the openings by the stencil. The holes are 1"3/4 on the manifold, and closer to 1"7/8 wide on the engine.
5. Here is the intake manifold in it's stock form.
6. Here you can see how the far left two holes are coming along compared to the untouched third opening on the right. At this point I'm about 2 hours into removing material. I'm slow... but it's really easy to take off a chunk that would be a disaster if you are not careful.
7. Progress picture..
8. More progress.. 6 hours now...lol. In the picture it looks rough, but its super smooth to the touch - I think it was my Dremol sanding that made it appear rough, I don't know. I took more pictures but they didn't turn out of the interior of the runners. I ported as far as my bits would go, I think they are about 6 inches, but most of the material was removed in the first 2 inches since it bottlenecks the most there anyways. It seems to open up more as it goes inside. Also ported the throttle body side just slightly for the spacer and the intake manifold to line up nicely.
9. Measurement. 1"7/8
10. Ok, on to the throttle body. this is in it's stock form.
11. Ported.. 1.5 hours after. It's really hard to see the difference, but believe me there is. The stock TB tapers in greatly right before the "flapper". You can see it better in person, and you can definately feel the raised restriction with your fingers. Now the opening is nearly straight through, but I left anything past the butterfly valve untouched so it seals proper.
12. Now, the clean up. I think I left about a 10 foot circle of aluminum shavings on the floor, the other half was in my clothes and hair. Fantastic!
13. After cleaning up and losing a pound of aluminum shavings in the shower, I sanded and took off the cast lines on the exterior, and painted the piece up!
14. Close up of my homemade Mopar emblem for a finishing touch...
15. Installed again...
Other side notes:
*I spent at least an hour cleaning the parts of any misc dust and shavings trapped inside with an air compressor and running cotton rags back and forth inside until all the junk was gone. Don't even think about doing this if you can't get it cleaned out after.
*I also discovered that WD40 is your friend since your bits will get full of aluminum chunks. Spray on some, and the chunks come out when you start grinding again. I even sprayed a bit on the area being ported and helped cut nice.
*Let the tool slowly cut, and do not force the material removal.
Thanks for taking a look! Was fun.
Update:
Took the car for a run, and did notice a difference. The car seems to spool up quicker and pulls harder than before. Not a HUGE difference but an improvement all the same. When I press into the pedal it responds quicker. I guess it worked for me!
Green Machine is offline   Reply With Quote
Old 08-15-2009, 01:39 PM   #2 (permalink)
kup@l's Avatar
Member Number: 53972
Trader Rating: (32)
great stufff...but I still wouldn't trust myself lol
Edited by Pete
Keep your signature clean from curses.
kup@l is offline   Reply With Quote
Old 08-15-2009, 01:42 PM   #3 (permalink)
CONROY's Avatar
Member Number: 46401
Trader Rating: (124)
looks pretty good... did you do the opening of the intake mani too?
Pittsburgh Penguins 41-23-5 87 points
CONROY is offline   Reply With Quote
Old 08-15-2009, 02:05 PM   #4 (permalink)
kevin2004's Avatar
Member Number: 66925
Trader Rating: (38)
Looks good. I already planned on doing this today but I like the length of your carbide bures better than mine. Thats the story of my life "my tool is to short and I cant get it deep enough".
kevin2004 is offline   Reply With Quote
Old 08-15-2009, 02:13 PM   #5 (permalink)
srtmitch's Avatar
Member Number: 73434
good write up man! i wouldnt do it myslef, cant trust myself lol
srtmitch is offline   Reply With Quote
Old 08-15-2009, 02:34 PM   #6 (permalink)
SRT-4runner's Avatar
Member Number: 68134
Trader Rating: (51)
Sweet shit might try this soon.
SRT-4runner is offline   Reply With Quote
Old 08-15-2009, 03:25 PM   #7 (permalink)
Haha, while like I said above, most of the action is in the first couple inches!
It wasn't hard to do, you just have to take your time with it I think and have the tools. Just study how some of the vendors do it and don't go crazy and remove to much. There are a few sites on the interwebs that have videos on how to do it as well. Or you can just get a vendor to do it too - LOL.
Old 08-15-2009, 03:27 PM   #8 (permalink)
You bet, nothing to drastic. Just enough to match the spacer and TB up nicely, and smooth it out...
Old 08-15-2009, 05:11 PM   #9 (permalink)
ziggo0's Avatar
Member Number: 63759
My only worry would be is if it would be effective...lots of people get shit for backyard port jobs...it does look very good, notice any differences??
Old 08-15-2009, 06:17 PM   #10 (permalink)
Havent tried yet honestly, raining like a bugger up here this weekend. I will let you know.
Old 08-15-2009, 07:21 PM   #11 (permalink)
Super Moderator
SRT of the Month
LilSparkPlug's Avatar
Member Number: 17636
Trader Rating: (73)
Wow! Nice job Scott!
Old 08-15-2009, 07:48 PM   #12 (permalink)
siberian57's Avatar
Member Number: 37918
Trader Rating: (40)
gotta give you credit for doing this on your own. I can't say I would be that brave lol
Nismo//JIC Magic//Recaro//Takata//Top Secret//Agency Power//Stillen
//Sparco
siberian57 is offline   Reply With Quote
Old 08-15-2009, 08:45 PM   #13 (permalink)
Update:
Old 08-15-2009, 09:03 PM   #14 (permalink)
Well, thanks for that! I was a little worried attempting this but it turned out good - car runs better actually. It would have been really shitty to have messed something up, since I would have to wait on a new intake manifold or something... Have a new Diablosport Predator coming in next week to replace my SCT handheld that I am super excited about! (So tired of not being able to do jack with that SCT handheld - ug) John from PTP is gonna hook me up with a tune.
Not bravery, just wanted to get my hands dirty. Thankyou!
Old 08-15-2009, 10:04 PM   #15 (permalink)
slyder's Avatar
Member Number: 36768
Trader Rating: (84)
sweet write up thanks for the information. Wish I had time to attempt this. I got all the tools just not the time
-Slyder
slyder is offline   Reply With Quote
