Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Off-Topic Area > The Water Cooler
Old 07-23-2009, 06:38 PM   #1 (permalink)
JaySRT665's Avatar
Member Number: 64651
Default Hard drive?
Computer crashed awhile back (don't have time to post specs right now, but will in the morning) and I'm looking into buying a new hard drive.
It starts to boot, you can hear it warm up and then tick, then repeat.
I assume it's the hard drive.
Now I'm looking into buying a new one so I can get my personal pc back up and running and I want a decent hard drive, not one that's going to be junk.
So what's the word on reputable hard drives?
2004 Stage 2 SRT4 - Totaled
2005 SRT4 - Stock
JaySRT665 is offline   Reply With Quote
Old 07-23-2009, 06:58 PM   #2 (permalink)
Senior Moderator
Dojaman's Avatar
Member Number: 3804
Trader Rating: (38)
Western Digital.
All items for sale will use the following format & MUST include pictures:
Name: (FIRST & LAST)
Contact: (VALID EMAIL OR PHONE #)
Price:
Description:
If you have any questions please see here:
http://www.srtforums.com/forums/f27/...elines-352468/
Dojaman is offline   Reply With Quote
Old 07-23-2009, 08:00 PM   #3 (permalink)
JaySRT665's Avatar
See, I was thinking about that.
I just dono what the significance of HD cache is, RPM, etc.
Old 07-23-2009, 08:06 PM   #4 (permalink)
JaySRT665's Avatar
HP Pavilion a808x
AMD Athlon 64. 2.2GHz
512 ddr sdram
Integrated sis mirage2 128mb shared memory
1600mhz system bus
I wanna get plenty of memory and a dual screen setup.
I'd like to play games like fallout, aoe, etc without too much lag as well.
Ideas?
Old 07-23-2009, 08:52 PM   #5 (permalink)
Marcus Ryan's Avatar
Member Number: 42725
The faster the RPM of the drive the less read latency you get when data is read from the disk. The difference between a 10k drive and a 5k drive is huge. Makes the biggest difference when loading games but will also have an effect while playing, especially since your low on RAM, and while were on the subject, god damn, go get some ram! It's far too cheap and easy to install to be running on 512. In any case, with your system a 7200 RPM drive should be more than enough. The cache on the drive is a bucket of data that is stored, similarly to RAM so that if there is data that is being swapped out frequently the hard drive can output from there so that it can avoid having to read from the disk and being forced to endure latency.
Duma-chum? Diddy-chick?
Marcus Ryan is offline   Reply With Quote
Old 07-24-2009, 02:14 AM   #6 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
WD Raptor
I would settle for no less for my OS drive
Storage is another story
or 16 whatev
Adionik is online now   Reply With Quote
Old 07-24-2009, 06:52 AM   #7 (permalink)
JaySRT665's Avatar
Lol. The computer has been down for awhile, I've just been too cheap to do anything with it.
Thanks for helping out. Anything I should know about ram?
Old 07-24-2009, 07:00 AM   #8 (permalink)
SRTie4k's Avatar
Member Number: 45499
Trader Rating: (53)
This is an excellent HDD:
Newegg.com - Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drives - Internal Hard Drives
2008 Mazdaspeed 3
- Cobb SRI, Short Shift Plate, SU Solid Shifter Bushings, 18x8 Konig Runaway's
2008 Kawasaki Z1000
- Laser X-Treme Exhaust, -1 Front Sprocket, Speedohealer, Renthal Ultra-Low Bar, CRG Bar End Mirrors, Pazzo Levers, Motovation Frame Sliders, Targa Fender Eliminator, OEM Rear Cowl
2001 Kawasaki Ninja 250
- For sale soon...
Old 07-24-2009, 09:47 AM   #9 (permalink)
bLaCkZeSt's Avatar
Member Number: 66421
You'll be fine with a 7200RPM hard drive. As for your RAM, make sure you buy the same RAM as you currently have (SD/DDR RAM). Also, check inside your computer to ensure that you have an extra RAM slot available.
2004 Silver SRT4 - K&N Intake, Mopar STS, Mopar BOV
bLaCkZeSt is offline   Reply With Quote
Old 07-29-2009, 04:14 PM   #10 (permalink)
I'm a little late on this one but it's not just the same type of RAM but also the same RAM speed in hz.
Old 07-30-2009, 06:55 AM   #11 (permalink)
JaySRT665's Avatar
As in if there is an extra slot, get ram in the same hz as previous slotted ram?
Old 07-30-2009, 09:48 AM   #12 (permalink)
Senior Moderator
Dojaman's Avatar
Member Number: 3804
Trader Rating: (38)
yeah or go to crucial.com
Page generated in 0.19299 seconds with 13 queries
