Old 05-05-2008, 03:13 PM   #1 (permalink)
Member Number: 54845
Default wire harness
gonna replace factory 6x9 , do after market speaker have a harness that plug up or do i have to splice the wires and cut the factory harness off. or do i have to buy a specific harness for a c ertain brand of speaker
K&N FIPK, Mopar CatBack, MSD8.5 wires, NGK plugs, Mopar BOV, Oil press, Volt, EGT gauges. Interceptor Scan Gauge, Autometer Ultralight Boost that works.
CootersSRT4 is offline   Reply With Quote
Old 05-05-2008, 03:25 PM   #2 (permalink)
CrEaTrE's Avatar
Member Number: 28234
Have you bought new front speakers yet? Because the front stage is more important than the rear unless you sit in the backseat a lot.
As for the wiring, all you have to do is buy these connectors that I am COMPLETELY blanking on the name (remembered!! T-taps!). Or you can do it ghetto style and just cut the stock plug off the wires and just use the wires into the speaker. Or you can splice into the harness at the headunit and run speaker wire if you are planning to amp them in the future. Or you can just buy an external amplifier which will make the speakers sound 10x better, and all you have to do is run speaker wire from the amp to the speaker.
Old 05-05-2008, 06:53 PM   #3 (permalink)
stage3matt's Avatar
Member Number: 54658
T Taps / Scotch Locks FTMFL!!!! I would NEVER suggest using them. Go to crutchfield or a local car audio shop and buy the correct speaker adapter plugs or poke/wrap/tape wires onto the factory leads.
EDIT: Speaker Clips
Metra p/n: 72-6514
Scosche and American International should make them as well, but I forget the p/n's.
RL+ Brown/Yellow
RL- Brown/Lt. Blue
RR+ Dk. Blue/White
RR- Dk. Blue/Orange
stage3matt is offline   Reply With Quote
Old 05-06-2008, 08:30 AM   #4 (permalink)
so the front are better to replace first?
Old 05-06-2008, 08:36 AM   #5 (permalink)
stage3matt's Avatar
yes absolutely. Being the driver, the majority of your sound is coming from the front speakers while the rears are just providing fill. Definitely do fronts first.
Old 05-06-2008, 11:20 AM   #6 (permalink)
ok cool are they 6 1/2. and do i just take the whole door panel
Old 05-06-2008, 11:43 AM   #7 (permalink)
tusamni's Avatar
Member Number: 35294
EDIT: Speaker Clips
Metra p/n: 72-6514
RL+ Brown/Yellow
RL- Brown/Lt. Blue
RR+ Dk. Blue/White
RR- Dk. Blue/Orange
Listen to this man, he knows of what he speaks.
Waiting on my v-band
tusamni is offline   Reply With Quote
Old 05-06-2008, 12:50 PM   #8 (permalink)
cool just ordered
Old 05-06-2008, 03:40 PM   #9 (permalink)
stage3matt's Avatar
thanks duder
yes the fronts are 6 1/2"s. The whole door panel comes off. Three screws if I remember correctly. One at the handle to open the door, one at the handle to close the door, and a third in the indent where the dash sits when the door is closed. Pop the switch plate up and unplug it, then the door panel itself pops out and up. Speakers are held in with 3 screws. You may or may not need chrysler speaker adapters because of the way the speakers mount in the door (its been a while since I've done em in this car), but you will need to do one of the aforementioned ways for attaching speaker wires (NOT T-taps/scotch locks). PM me if you have any other questions.
Old 05-07-2008, 11:30 AM   #10 (permalink)
k thanks man
Page generated in 0.24861 seconds with 11 queries
