Old 11-02-2006, 04:40 AM   #1 (permalink)
Member Number: 47657
Default What Amp?
i just bought two kicker cvx subwoofers with 600 rms each. I was wondering if i needed a 2 channel amp to power 2 subs?
2004srt4cl is offline   Reply With Quote
Old 11-02-2006, 05:46 AM   #2 (permalink)
Member Number: 4392
you could use a mono, 2 channel, or 4 channel amp. just make sure the power at the appropriate impedance works for your application. if you aren't sure, post the impedance (ohms) of the subs and the specs of your enclosure. if it's a sealed enclosure, you might want to get a higher powered amp. if its ported, you can go with the rated rms or a little less.
IASCA certified judge
got wake? is offline   Reply With Quote
