Old 05-13-2008, 10:52 AM   #1 (permalink)
Member Number: 60625
Question volt meter??????????
ok stupid question but can u hook a volt meter up to the cigarette lighter and have it read the right voltage.
rocko is offline   Reply With Quote
Old 05-13-2008, 11:08 AM   #2 (permalink)
CrEaTrE's Avatar
Member Number: 28234
Don't know how it works, but found this:
Digital Voltmeter, Plugs into 12 volt Cigarette Lighter Socket
Old 05-13-2008, 01:56 PM   #3 (permalink)
Member Number: 12647
Yes. It won't be exactly the voltage at the battery due to wire resistance, but it should be within tenth or two. If you want to monitor the voltage, you can get what CrEaTrE linked; else if you just want to quickly measure it you can unplug the lighter socket (from behind) and check it with a regular DC voltmeter.
The three laws of thermodynamics, simply stated:
- You can't do any better than breaking even.
- You can't break even except at absolute zero.
- You can't reach absolute zero.
Jim Z is offline   Reply With Quote
Old 05-14-2008, 08:13 AM   #4 (permalink)
CrEaTrE's Avatar
Oops, I shouldn't read forums after driving for 35 hours.
Yeah, the resistance will make the voltage seem a little off, but you should be able to get a general idea from there.
Page generated in 0.19278 seconds with 11 queries
