Old 03-11-2008, 01:00 PM   #1 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
Default Tweeter location?
Looking to get components (thinking PG RSD 6.5s if they will fit in the doors) and anyways I see a lot of people mount the tweeters in the door sail or kick panel. Although I am considering this Im wondering how much crappier it will sound to mount in the stock location and just aim them towards the rear of the car? (they wont be deflecting off the windshield this way)
Any pics of a similar setup?
Thanks
2.0L SOHC - 400whp 11/11/04 - still shooting for 450whp+
Check out my mods and pics here
Roach is offline   Reply With Quote
Old 03-11-2008, 01:17 PM   #2 (permalink)
Member Number: 51622
to be honest the stock location sucks its hard to work in and hard to mount them there compared to the door part if you want ill take a pic of them mounted on the door today...plus they sound way better on the door.
elykrk is offline   Reply With Quote
Old 03-11-2008, 01:29 PM   #3 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
yeh and how difficult was the install? as many pics as you can would be great. Im thinking the sails would be better in terms of sound than next to the mids or the kickpanels.
Also where did you mount the crossovers? Door pockets?
Old 03-11-2008, 09:22 PM   #4 (permalink)
nineball's Avatar
Member Number: 60582
for best sound, you should mount the tweeters near the mids. i think the rule of thumb is no more than 12" but i may be wrong. the factory location (dash) is terrible for a set of tweets. it is not hard to mount them into the door panels. i haven't done it to my neon yet due to the weather, but here is a shot of one of my old cars with them mounted to the door panel. just a simple hole (i actually did it with a dremmel).
this is a shot of my other car which came with a much better mounting setup.
as far as the crossover, you can mount it anywhere you like so long as it is protected from the elements (water).
Old 03-11-2008, 09:33 PM   #5 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
yeh cool, good pics. Just curious where you guys were mounting the crossovers and pics of it if possible. Thanks
Old 03-12-2008, 12:13 AM   #6 (permalink)
Here you go
The install is way easier to mount them there than to try to fit you're hand in there and trying to mount it... I think it looks good and looks stock if you don't know the car very well just make sure you disconnect the old ones... My crossover i believe was mounted right next to the speaker where the red is.
Old 03-12-2008, 07:41 AM   #7 (permalink)
Roach's Avatar
Member Number: 697
Trader Rating: (27)
yeh looks nice and clean. What comps are those? Also this is dumb but the crossover is mounted on the doorframe itself and is not pushed back in the little cubby, right?
Old 03-12-2008, 07:51 AM   #8 (permalink)
DPETRIE's Avatar
Member Number: 34835
Trader Rating: (21)
I'm running the Diamond Audio Hex comps and mounted them in the stock location. All I did was make a bracket to fit in the stock mounting holes. I tried a few locations to get the best imaging possible and for me it was the stock location. It really wasn't too difficult to get the sound stage that I wanted. It did however take a little more tweaking on the eq due to bouncing the sound off the wind sheild. It all just depends on what your ears tell ya. Just try the tweeter in a few locations and see what ya like best. As far as mounting the crossovers, I made a panel in the back left of the trunk. I'll take some pics later on today and post them up.
"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man"
-Elbert Hubbard
DPETRIE is offline   Reply With Quote
Old 03-14-2008, 02:09 AM   #9 (permalink)
Member Number: 25032
first off diamond hex's are amazing.. and i think the stock location sounds great.. ust go -1 or -2 db on the crossover for your tweeter. can make a simple bracket out of a piece of radio back strap took me like 10 min a lot less time then cutting holes in doors.
THEMANCALLEDDAX is offline   Reply With Quote
Old 04-16-2008, 01:06 PM   #10 (permalink)
Member Number: 14212
i put them in the stock location and just pointed the to the rear.
just a peice of aluminum to make the bracket.
sounds great to be honest. gets the job done.
Frosty is offline   Reply With Quote
Old 04-16-2008, 02:00 PM   #11 (permalink)
stage3matt's Avatar
Member Number: 54658
have mine in the stock location with (i believe) a -3dB on the crossover. That and a little t/c and they sound awesome.
2009 1320x threads:
III
stage3matt is offline   Reply With Quote
Page generated in 0.19608 seconds with 13 queries
