Old 10-24-2009, 11:37 AM   #1 (permalink)
Member Number: 57221
Default speakers turned off!
i have stock speakers. 2 10 inch subs with an amp for that and another amp for the speakers. i put it on full blast and it was playin for a while then it jus cut out and i checked the connections and the fuses does anyone know what happened?
KiNgPeRez is offline   Reply With Quote
Old 10-24-2009, 11:43 AM   #2 (permalink)
liv'n loud's Avatar
Member Number: 148
Check your wiring. You man be over loading the amp. The amp will go into protect and start clipping if you are running to low of an ohm load. Check and see how you have your speakers connected you may have them bridged
Oldtimer here!!
liv'n loud is offline   Reply With Quote
Old 10-24-2009, 02:05 PM   #3 (permalink)
how do i get it to work again
Old 10-24-2009, 10:42 PM   #4 (permalink)
CrEaTrE's Avatar
Member Number: 28234
Is your amp in protect? Have you checked all the connections to make sure they are getting an electrical load? Have you checked all the connections to make sure they are actually still connected? There are a ton of troubleshooting things you can do.
Old 10-25-2009, 06:23 AM   #5 (permalink)
jus noticed that the amp light isnt on. and also i have a flip out touch screen radio and it wont let me into the audio setup it has a lock next to it
Old 10-25-2009, 07:11 AM   #6 (permalink)
stage3matt's Avatar
Member Number: 54658
where/how did you ground your amps?
2009 1320x threads:
III
stage3matt is offline   Reply With Quote
Old 10-25-2009, 08:34 AM   #7 (permalink)
nineball's Avatar
Member Number: 60582
if the light is not on then you have 1 of 2 problems:
1. amp is blown
2. electrical connections are not secure
Old 11-01-2009, 06:22 PM   #8 (permalink)
Rhunter's Avatar
Member Number: 36794
Check the fuses on the power line coming from the battery.
Check the actual amp fuses.
No light means no power to the amps or like nine ball said, you blew em.
Rhunter is online now   Reply With Quote
Page generated in 0.13433 seconds with 13 queries
