Closed Thread
Old 04-13-2008, 05:32 AM   #1 (permalink)
CrEaTrE's Avatar
Member Number: 28234
Default **** READ THIS BEFORE POSTING - Everything Car Audio ****
General SRT4 Car Audio Information:
Front Dash Speakers: 3.5"
- 1" Tweeter with 3.5" mounting bracket
- Recommendation: Remove and don't replace
Front Door Speakers: 6.5"
- 2 1/4" mounting depth max
Rear Deck Speakers: 6x9"
- Unlimited mounting space
Alternator:
- No aftermarket Alternators are available and it cannot be rebuilt.
- The output is controlled by the factory computer.
- 56029915AB 2003 factory alternator ALTERNATOR - 160 AMP (BAB)
- 56029701AB 2004 factory alternator ALTERNATOR - 136 AMP (BAZ)
- 56029701AB 2005 factory alternator ALTERNATOR - 136 AMP (BAZ)
Any Headunit that fits a regular neon fits the SRT4.
- Single DIN
- Double DINs require modification: How to: Double Din Navi
Kicker Livin' Loud Specifications:
- All speakers upgraded and are amplified by a 70 watt amplifier.
- 6 Disk CD Changer below HVAC controls.
- Subwoofer is 10" and is amplified by a 100 watt amp @ 1 ohm and the box is 0.68 cubic feet.
Have dimming lights? DO NOT USE CAPACITATORS!
- http://www.srtforums.com/forums/f40/...7/#post6024789
You CANNOT keep the Kicker factory 6-disk with an aftermarket headunit
You CAN however, keep the Kicker System (minus the 6 disk changer) with an aftermarket headunit.
- It's already tied into the stock wiring harness, so the aftermarket harness will hook it right up.
In order to use a MP3 player with stock Headunit
- You must buy the auxiliary input adapter.
In order to use the stock headunit with an aftermarket amplifier
- You must buy a LOC (Line Out Converter) which takes the signal used for a speaker and transfers it to RCA's for the amplifier to use.
- You do not have to give up rear speakers to do this, you are just tying into their signal.
There is NO single best Subwoofer combination!
- All subwoofers fit different needs, whether it be SQ or SPL.
- Feel free to PM me with ideas for setups.
Battery Information
Battery Information and Discussion
SRT4 Specific
Aftermarket Harness Wiring Chart Thread:
**aftermarket Harness Wiring Chart***
Headunit Install:
How To: Install Jensen Flip Up Head Unit
Front Speaker Install:
Front Speaker Install How-To
Front Speaker Wire Pass Through for Door Instructions:
new build log
Rear Speaker Install:
Rear Speaker Install-How To
SRT4 Big 3 Install:
**Big 3 Pictures**
Kicker Livin' Loud Subwoofer Replacements:
Livin Loud Sub Replacements
Installing Kicker Livin' Loud Subwoofer:
helllppp!! kicker sub
Installing Kicker Livin' Loud - All speakers and Subwoofer:
Kicker Installation Files
Auxiliary Input Adapter for Stock Headunit (cannot have kicker system):
PIE CHRY02-AUX DODGE AUXILIARY INPUT ADAPTER
HOW-TO Install the AUX Input Adapter:
How to Install an Ipod / mp3 adapter for the stock radio
Tweeter Locations:
Tweeter location?
How to Run the Power Wire for Amplifiers:
How do you run your Power wire.
Battery Information:
http://www.srtforums.com/forums/f40/...sticky-310179/
HOW-TO: Rear Battery Relocation (with cutoff switch)
HOW-TO: NHRA/ IHRA Approved Battery Relocation
Custom Enclosures in the SRT4:
http://www.srtforums.com/forums/f40/...bs-box-305285/
3.5" Dash Speaker and Tweeter Mounting Information:
3 1/2in speaker in the dash?
Sattellite Radio Antenna Mounting Locations:
Satellite Radio Antenna Mounting...
Subwoofer Review Thread:
How To: Remote Key FOB Programming
How-To: Remote Key Fob Programming!
Member Kicker Speaker Change
Upgrading my stock Kicker system
General Audio Threads:
Bass Song Thread:
Tips for bass songs
Big 3 Wiring Mod:
Woofer Wiring Wizard:
Rockford Fosgate® - Woofer WiringWizard
Enclosure Calculator:
RE Enclosure Calculator
Differences in Box Types:
http://www.srtforums.com/forums/f40/...9/#post6024796
Free Ported Box Plans:
http://www.srtforums.com/forums/f40/...56k-no-435910/
Stereo Tuning 101:
stereo tuning 101
Car Audio Terms (Don't understand a word? Look here!):
http://www.srtforums.com/forums/f40/...-terms-436368/
Do I need 2 Batteries? - Short Answer - NO:
http://www.srtforums.com/forums/f40/...2-amps-436151/
Speaker/Crossover FAQ and Sound Quality Discussion Thread:
http://www.srtforums.com/forums/f40/...ussion-439707/
Proper Electrical Grounds Guide:
http://www.srtforums.com/forums/f40/...thread-439706/
Engine Whine and Group Loop Fixes:
Antenna Options:
- Most shorty Antenna's do NOT provide as good as reception as stock, however some are better than others.
Internal Antenna - Allows you to shave external antenna!!:
New Antenna
Zzapp Motorsports Antenna:
Zzapp Motorsports Billet Antenna for Neon - ZM5-000
MPX Shorty Antenna:
Modern Performance Racing Products
The Oshawa Antenna:
eBay Seller: srt41320: Car Electronics, Consumer Electronics items on eBay.com
CrEaTrE is offline
Old 04-14-2008, 04:01 PM   #2 (permalink)
CrEaTrE's Avatar
Reserve for more space
CrEaTrE is offline
Closed Thread
Page generated in 0.25824 seconds with 13 queries
