Old 11-01-2009, 04:56 PM   #16 (permalink)
Member Number: 515
Custom bracket has to be made. It has to run off (not controlled) of the ECM. The ECM needs to have some sort of bypass or trick in place so no codes are thrown. Just three I can think of.
You have to be angry at life to be creative
-John Leguizamo
"man is the measure of all things." - Protagoras
reason is the only proper guide to the most crucial problem of human existence- the question of good and evil. -socrates
04electricblue is offline   Reply With Quote
Old 11-01-2009, 08:35 PM   #17 (permalink)
BLKDOUTSRT4's Avatar
Member Number: 36285
pm nemo....how many times do i have to say it....
Quote: Originally Posted by Alpha-Omega View Post
....yeah, I'm gay and staying home this time
BLKDOUTSRT4 is offline   Reply With Quote
Old 11-02-2009, 05:18 AM   #18 (permalink)
Member Number: 515
You can say it until you're blue in the face. I pm'd him over a year ago when he spoke about having a crack to control the alternator and bringing its output to 14.4. He never responded. I don't doubt that he can do it with the dsp the problem is the feeble amperage the alternator puts out. I say feeble for most big system needs, general use the alternator is great. To upgrade the alternator is just not going to happen with a plug and play under a grand thing.
Old 11-05-2009, 09:57 AM   #19 (permalink)
Member Number: 39851
eBay Store ? Iraggi Alternator and Electronics: Search results for neon.
Iraggi has a few H/O alts that fit our cars. =D
Still doesnt solve the problem with the ECU controlling it though...
05 SRT-4 | Maxxfab 3" DP | Borla Catback w/ Resonators Removed | Mopar S1 | AGP CAI | Bwoody Catch Can | NGK Plugs | MSD Wires | AGP Hardpipes | MPX BFMIC | FM WGA | Greddy Type S BOV
aggballeralex is offline   Reply With Quote
Old 11-05-2009, 04:09 PM   #20 (permalink)
nineball's Avatar
Member Number: 60582
$500 for a large piece of metal that won't change a thing? no thanks.
Old 11-05-2009, 06:03 PM   #21 (permalink)
I'm currently trying to figure out how to solve my power needs. I'm looking to put 4krms+ in my car and without a H/O alt that seems almost impossible.
Old 11-05-2009, 06:46 PM   #22 (permalink)
Looking around it seems that installing a H/O alt would help. We would still be stuck at stock voltage but have much more current to work with. Anyone have any ideas on this?
Old 11-05-2009, 06:53 PM   #23 (permalink)
nineball's Avatar
i really don't see how you can properly power a true 4k+ system in a neon. i did my big3+ in 0g, stinger svp44 under the hood, kinetic hc600 in the trunk, 1500-1600rms total and i still get dimming when i near the top of my volume limit (35 is max, 31 is clipping limit, dimming starts at 27-28).
Old 11-05-2009, 07:07 PM   #24 (permalink)
That is what I'm afraid of. Either I have to go smaller or run way too many batteries to compensate. This is depressing =(
Old 11-05-2009, 08:48 PM   #25 (permalink)
has anyone pmed nemo yet.....i swear he has the fix for this
Old 11-06-2009, 02:26 PM   #26 (permalink)
Member Number: 515
PM him let him come in here and chime in.
Old 11-06-2009, 06:08 PM   #27 (permalink)
I may have found what we are needing:
Dodge Modules
Our modules can get you up in the 14.5-15v range or on average 1 full volt above stock voltage. Dcpowerinc is a dealer of MLA as well and we team up to offer good kit deals on alt/module combo sales.
I am going to email them to ask more about this module. From what I see they are able to basically trick the computer into thinking it is seeing stock voltage levels, much like how a MAP clamp works to an extent. I'll let you all know what I find out.
Old 11-08-2009, 07:57 AM   #28 (permalink)
you could just find alternator with a internal voltage regulator then hard wire it to the battery the pcm would lose the control it has over the alt....prob would get cel but it would work cause the internal voltage reg in the alternator would just do its job...pcm cant control anything if you take it out of the loop
Old 11-08-2009, 09:24 AM   #29 (permalink)
Member Number: 36825
Napa makes a 150 amp for our car.
SRT Jeff is offline   Reply With Quote
Old 11-08-2009, 09:30 AM   #30 (permalink)
Napa makes a 150 amp for our car.Do our alts cross reference with durango or dodge ram trucks? Because mean green.com makes them and they have a life of 300.000 miles my friend has one on his truck that wrks on my ride its 200amps!
Page generated in 0.15252 seconds with 13 queries
