phone integration and CD changer control question
Hi all. I've been slowly working on getting my phone to play music in the car, and I'm almost done. I just have one more question.
First, here's what I've got so far. There's a mount just to the left of my boost gauge that holds the phone. It's just within reach of my finger with my hand on the wheel for easy GPS manipulation. But it's still far enough away that I don't have to worry about hitting it during quick hand motion around the wheel. It's right in my field of view, but it isn't high enough to block view of anything other than the windshield wiper. It also happens to be in a great spot if I ever decided to take some in-car video at a race or something. When I slide the phone into its dock, it gets plugged in to a cable that runs inside the dash down behind the head unit. That cable carries charge up and music down. I built a circuit that switches between the CD changer and the phone as inputs for the head unit. When I switch the head unit to that input, the CD changer plays like normal. Unless the circuit sees an audio signal from the phone, then it cuts off the CD changer audio and instead feeds the phone audio to the head unit. If I turn off the phone's music, it starts playing the CD changer music again.
It all works and sounds great, but there's one big annoyance left. While I'm listening to music from the phone, the CD changer is still playing. The sound isn't going anywhere, but it's still reading the disc. So whenever I switch back to listening to a CD, it's on a different song than when I left it. Whenever it plays to the end of a CD, it switches CDs just like it would normally. As you know, this is a pretty noisy and annoying process. To make matters worse, the head unit sees that it's changing CDs and cuts out the audio for a few seconds. I guess the CD changer would be sending some weird sounds during that time, so it just cuts them out. So here I am, listening to phone music, when all of a sudden it goes silent. Then I hear all these mechanical noises coming from the CD changer for a few seconds, then the music comes back in. It's bothersome, and it's keeps the job from seeming really professional.
So here's my question. How do I make the CD changer stop playing when I'm not listening to it? I assume that if I cut power to it, the head unit will refuse to select that input. That's what happens when the changer is unplugged. How do the auxiliary input kits do it? They somehow trick the head unit into thinking there's a changer plugged in, right? If I could do that, I could cut power to the changer and still select that input. Somebody help!
We always tell people to search, but searching is useless when nobody stays on topic.
Making or adapting parts for your car is NOT "rice" or "ghetto". If you think the only parts that belong on your car are ones you buy and bolt on, you don't belong under a hood.
