» Tire Upgrade Garage
Old 05-10-2008, 12:33 AM   #1 (permalink)
Member Number: 57293
Default New Viper alarm with Turbo Timer?
Im booked in to get my new Viper alarm with command start. Only reason I want the command start is cause it carys a Turbo Timer function.
The Key Fob is the new slim Led design.
Guess my question is has anyone had any dealings with the new vipers? Or with the Turbo timer function?
It seems like a money savings instead of buying a alarm then a seperate TT.
Im also going to get 2 window modules put in. So when I arm the alarm my windows go up and sunroof closes. You can also open them from the fob.
My viper alarm in my Dakota is a few years old and has never given me a ounce of trouble. Command start for those nasty Canadian winters has never failed me.
Red05cdnnub is offline   Reply With Quote
Old 05-10-2008, 10:25 AM   #2 (permalink)
CrEaTrE's Avatar
Member Number: 28234
I have the Viper 791xv with all the features and its great. The turbo timer is nice to have built right into the alarm, and having all the windows roll up as you lock the car is extremely nice. I would definitely recommend the alarm.
2004 Black Dodge SRT4 - AGP 50 Trim .63A/R @ 21psi, Crane 12s, .020" overbore, JE Forged Pistons, Eagle Rods, HKS SSQV BOV, JMB 3" ultimate intake, JMP Pressure Pipes, AGP IC, Stage 4 CM 6-puck Clutch, 3" BDJs Dump, RC 750cc's, Aeromotive FPR, -4an Teflon Fuel Line, Perrin Fuel Rail, Greddy Emanage and E-01.
Old 05-11-2008, 09:38 AM   #3 (permalink)
Member Number: 50961
I have the new 5701 installed and it works great. To activate the turbo timer, with the remote start in manual transmition mode, all you have to do is put the car in remote start standy with the door open.
I have had only two problems with it so far, the buttons on the key fob are easily pressed while in my pocket, so you have to be carefull about what you put in your pocket with the keys, and if you drop the fob the batter cover can go flying off and the batteries fall out. Other than that, its been great.
realplat is offline   Reply With Quote
Old 05-12-2008, 05:37 AM   #4 (permalink)
Member Number: 29891
Make sure they use the manual tranny module to make it more safe to work on a manual tranny'd cars. The system isn't bad although I've had some issues with failing remote controls in the shop.
ponchonutty is offline   Reply With Quote
Page generated in 0.13588 seconds with 11 queries
