I was looking to relocate my battery to the trunk so that I can free up some room under the hood. However, with the NHRA rules saying you have to have an external kill switch and all the decent track events at my local track (Las Vegas Motor Speedway) requiring NHRA tech inspection. I didn't want to have a kill switch on the outside of my daily driver.
A friend of mine mentioned a BattCap, and caught my interest.
Could I run an Odyssey PC680 (which seems to be the mini battery of choice) and a BattCap of some size in the trunk to supplement it?
Keeping the tire companies in business...
...one WOT shift at a time™ || Mod List Coming Soon|| ***Forum Rules***
i believe you only need that if you plan on actually racing in an nhra series. if you just go the track every now and then i don't think you need it. I know technically you need a 6 point cage if you go faster than 11.99 but there's plenty of tracks that don't really care unless you're in a series.
Not true at LVMS. We had to go through tech inspection to run at Mopar's At The Strip.
The cars that had batterys out back had to demonstrate that their kill switch worked.
This is true also. Anything under 13.99 requires a helmet, anything faster than a 12.99 requires a roll bar, 5 point harness, and helmet. Cage is after that
Towards your original question - Wire up the Big 3 mod, and use the mini battery and you should be fine running 2 amps. After the car starts the power is taken from the alternator anyways, and unless the amps run while the car is off you shouldn't have any problem.
what gauge wire do you recommend? i have some extra 4 gauge laying around.
you think i could run a Kinetik HC600 up front as a mini battery and thats it?
I'm thinking of going back to a small battery. I had the JMB Ultimate intake, with the small Odyssey, but it would die really fast here. Part of it was I had a good bit of power draw, I think, but I'm hoping to figure out what's doing it, rectify that, and go back to a small battery.
i want to go to one to free up some room under the hood. for the time being i have a pretty decent sized stereo in the car. maybe i'll go with two of these kinetiks, one in front and one in back, to power the stereo
