Old 05-24-2006, 11:30 AM   #1 (permalink)
Member Number: 17276
Trader Rating: (41)
Default Livin Loud Sub Replacements
Since there have been a few threads about asking what subs fit into the stock kicker sub box, I thought I'd compile a list of some of the subs that other members have successfully implanted into the box. Now from what I've read in order for the aftermarket subs to fit they need to be a shallow mount 3-5" in depth. Also You will want to replace the stock Amp with an aftermarket amp that will have enough oopfhh to power your new sub.
One question that I have is would it be possible to add a spacer or something to mount a sub that is a bit deeper?
1) Memphis 15-MC104D 5 inch mounting depth, and just barely fits
2) Kicker 10" Comp VR Have to open the hole a little wider.
3) Audio SX 10" sub
4) MTX Blue Thunder
5) Pioneer TS-SW1041D
6) JL 10W3V2-D4
7) JBL gt100 10"
8) larion 10" shallow mount sub. 3inch mounting depth and has 600watts max 300rms
If you have any others just post them up and I'll edit the list.
SilverSerfer is offline   Reply With Quote
Old 05-24-2006, 12:08 PM   #2 (permalink)
Member Number: 29215
I am sure all of these options also require more power correct?
AZ05SRT4 is offline   Reply With Quote
Old 05-24-2006, 01:10 PM   #3 (permalink)
Trader Rating: (41)
Yes you will need to put an aftermarket amplifier to them.
Old 05-24-2006, 02:54 PM   #4 (permalink)
Member Number: 14212
clarion 10" shallow mount sub. it has a 3inch moutning depth and has 600watts max 300rms.
sounds awesome
Frosty is offline   Reply With Quote
Old 05-24-2006, 02:56 PM   #5 (permalink)
jbl gt100 10" fits aswell sounds awesome.
Old 05-30-2006, 02:47 AM   #6 (permalink)
jaycarneygiants's Avatar
Member Number: 25736
2) Kicker Comp VR Have to open the hole a little wider.
3) Audio SX 10" sub
4) MTX Blue Thunder
6) Kicker 10" CVR
7) JL 10W3V2-D4
8) JBL gt100 10"
9) larion 10" shallow mount sub. 3inch mounting depth and has 600watts max 300rms
I hope this will fit (DAYTON RSS265HO-4 10" HIGH OUTPUT SUBWOOFER) cause I just bought one and I am hoping to find someones kicker enclosure to buy. I need the trunk space.
http://www.partsexpress.com/pe/showd...number=295-462
jaycarneygiants is offline   Reply With Quote
Old 05-31-2006, 11:59 AM   #7 (permalink)
Jmhm17's Avatar
Member Number: 24437
Two part question..
A: how do you take the sub box apart?
B: how do you hook an aftermarket amp up to the stock amp harness?
* Disclaimer...The above post may or may not have misspelled words ...deal with it...
**Sold**
Best E/T 12.699 @ 108.97
Best MPH 12.856 @ 110.32
09 Legacy 2.5i DBM... I miss boost
Jmhm17 is offline   Reply With Quote
Old 06-01-2006, 08:51 PM   #8 (permalink)
1: you dont take the sub apart. u jsut take the sub out nad put a new one in.
2. you dont use the stock harness use your own amp!
Old 06-09-2006, 07:41 PM   #9 (permalink)
Jmhm17's Avatar
hmm yeah... maybe i wasent clear.. how do you take the subwoofer enclosure apart to take the stock subwoofer out of the enclosure to replace it with a new subwoofer............
and your saying i cant use my stock deck i have to use an aftermarket deck so i can hook up a gay amp kit...
how is this diferent and unique then just putting in a system? the whole idea i was going for was just to replace the sub and put a better amp on the stock harness, cause if i use an aftermarket deck i loose my 6 disk cd changer..
now answer questions..
Old 06-10-2006, 07:43 AM   #10 (permalink)
Jmhm17's Avatar
ok bumb for the morning crew...
Old 06-10-2006, 02:04 PM   #11 (permalink)
Jmhm17's Avatar
Bump!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Old 06-11-2006, 06:55 PM   #12 (permalink)
rojo's Avatar
Member Number: 11775
It's very easy.
Unplug the harness form the kicker box.
Remove the screw in the back of the box. The screw holds the box to the trunk, Also there's a nut behind the divers tail light holding the box. There's also a velcro piece under it.
Remove the whole thing. You will feel some resistance due o the velcro piece.
Remove the screws in the front of the box, these are the ones that hold the speaker.
Put the new speaker and a a new grille.
Put everything back.
You may want to use a real amp. If you dont' have a aftermarket HU, you can get a converter like this one to use your factory HU:
http://www.crutchfield.com/S-jV81EXp...rter&i=142SLC4
I don't recomend using the harness to power a different amp because:
The wires are not thick enough
It uses a amplified signal instead of a pre amp signal (AFAIK).
Don't ask me for the blue antenna wire.
In fact I don't know which cable is what or whre it goes inside the car.
Should look like this:
rojo is offline   Reply With Quote
Old 06-14-2006, 05:36 PM   #13 (permalink)
Jmhm17's Avatar
thanx man... looks awsome nice clean set up.. how dose it sound??
Old 06-19-2006, 11:25 AM   #14 (permalink)
BLKDOUTSRT4's Avatar
Member Number: 36285
HEY i have the ALPINE E-10 and it hits really great with a older kenwood amp a friend has a really nice 12 in his prelude with a expensive amp 500/1 and mine hits harder in the stock srt sub enclosure
BLKDOUTSRT4 is offline   Reply With Quote
Old 02-24-2008, 06:37 PM   #15 (permalink)
madneon's Avatar
Member Number: 1991
Has anyone tried the new Fosgate Shallow Subs Rockford Fosgate Punch P3SD410 10" 600 Watts Car Audio Subwoofer
Really thinking about swapping out my Memphis for this new sub
Stage II, AEM Shortram, LED tails, Fiber Images CF Hood, Solid MM, MOPAR Short Shifter, Booger bushings, DC Sports Front and Rear STB, 3" Thermal Research Exhaust, 17X7 Falken Rims, Fuzion tires, 180 thermostat, BC Racing Coilovers, JMB hard pipes, HKS BOV...http://www.louspiracy.com/
madneon is offline   Reply With Quote
Page generated in 0.20198 seconds with 13 queries
