Quote: Originally Posted by
aggballeralex
So I haven't had anything aftermarket audio wise since my last car. That has been a good 3 years ago so I am looking to get back into it but I am getting a bit confused on some things.First off I plan on running:
2 Memphis PR10D4's
Each is rated at
Dual 4 ohms
250W RMS
87dB
I have had nothing but good luck with Memphis in the past so I am going to stick with them. I have heard amazing things about Orion subs so if anyone has any suggestions on them(specifically the Orion HCCA 10.4) I'd be glad to hear them. I also plan on replacing door and deck speakers and wiring them to the amp also. I am more-so wondering what size amp you all would suggest? I haven't done this in so long the whole impedance part is confusing me so I don't know what amp to purchase. Should I match impedance on the subs?(4 ohms). Any help would be appreciated!
I am not that familiar with Memphis subs but the Orion model is a nice sub.
You first have to decide on what speakers you want to use and then get an amp that will properly power them. The subs mentioned are dual 4 ohm, so if you have a pair you can have a final ohm load of 1 or 8 when wiring them together. You are limited only by the fact that some amps cannot handle a 1 ohm load. Unfortunately for you this rules out most of the 5 channel amps on the market as they cannot handle a 1ohm on the sub channel.
