Old 05-08-2009, 04:07 PM   #46 (permalink)
Edgehold's Avatar
Member Number: 55411
Trader Rating: (35)
My revised and easier how to.
original fob
new fobs
Here is a quick HowTo on programming your own keyless entry:
As long as you have one working keyfob you can program more this way.
1. Using a functional key fob transmitter, unlock the vehicle and disarm the Vehicle Theft Security System.
2. With the doors closed and everything else off, especially turbo timers, Insert ignition key into the ignition switch.
3. Turn the ignition switch to RUN position without starting engine.
4. Using a functional key fob transmitter, press and hold the UNLOCK button for a minimum five seconds (maximum ten seconds).
5. While still holding UNLOCK button on the original fob, and before ten seconds passes, press the PANIC button on the original fob and release both buttons at the same time. A single chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
6. Within 30 seconds of the chime, press and release the “LOCK” and “UNLOCK” buttons on the original transmitter at the same time.
6.5 You must press the lock and unlock buttons on the original fob, then the 2nd, 3rd, and 4th key fobs. each time you click both buttons on each fob, a chime will sound letting you know that that specific fob is programed.
7. Repeat steps 5 and 6 for all transmitters that will be used with this vehicle (up to 4 total).
8. Turn ignition to the OFF position. Transmitter programming mode will discontinue after 60 seconds. All transmitter programming must be completed within time specified.
8.5 After you program all your key fobs, turn the ignition off, then back on, first check to make sure that your original fob works by clicking the unlock and then the lock buttons checking for the sound of the locks working. then check the other fobs, all should now be working.
Edgehold is offline   Reply With Quote
Old 05-18-2009, 08:48 PM   #47 (permalink)
JBag 05 SRT4's Avatar
Member Number: 62838
Quote: Originally Posted by LeckSRT4 View Post
When I got my fob from the factory programmed it came to 150! this sounds lame but I like new products! so I bought a new fob 90$ the rest was labor... But I am happy with my purchase so yep!
Quote: Originally Posted by Probaholic1 View Post
Stupid dealership. I went today. And they said it won't work they tried on some other car.
They also said they would charge me 45 bux working or not.
That really pissed me off
Bump
Just went to the dealer and purchased a new fob (car didnt come with any when i got it used in Febuary of 08) for $70. After sitting at home, trying to program it, to no avail, i looked here and saw that i had to have the dealer do it. So i went back to the dealer, hoping they would give me a discounted price. Nope. They said its $100 to have a tech program it and it takes about 45 minutes. Then he tells me they didnt have time so now i have to go back another day to have them do it.
Quote: Originally Posted by Ferndogg View Post
GTFO NOOB!!!!!!!!!!!!!!!!!!!!!!!!!!
JBag 05 SRT4 is offline   Reply With Quote
Old 05-20-2009, 09:33 PM   #48 (permalink)
Probaholic1's Avatar
Member Number: 69183
ohhh.....dude, you went the more expensive way.
The way I did it was I got a fob off ebay for 12 bux, it just took me a few days to find a used one.
Then I reread the how to and realized I needed the original which I didn't have. So when I went to the first dealer it was a not sure if it's going to work but it's 45 dollars anyway.
I said F that so I went to a different dealership and they were nicer said yup it can be done, real quick and only 15 bux. So I went that route 10 minutes later and 30 bux, I had a programmed working key fob.
So I say go ahead and try different dealers I'm sure you'll bound to find one.
Probaholic1 is offline   Reply With Quote
Old 06-04-2009, 05:46 PM   #49 (permalink)
boneriffic's Avatar
Member Number: 60776
finally got around to programing my new fob. egdehold's system took less than a minute to activate new fob and if i had another 2 i wouldn't doubt being able to get all done within a minute. this is very easy and if you mess up, i feel really bad for you LOL.
Fothermucker.
boneriffic is offline   Reply With Quote
Old 06-10-2009, 04:26 PM   #50 (permalink)
Member Number: 72921
Are the keys transponder type keys? Need to make a spare...
Cars:
2005 Dodge SRT-4
2002 Chevy Tahoe Z71
2006 Acura TSX
SRT-4 To Do List:
Fix rear rattling noise
BC Stage 2 bumpsticks
Walb fuel pump
nimo_253 is offline   Reply With Quote
Old 06-10-2009, 06:35 PM   #51 (permalink)
boneriffic's Avatar
this is only for the keyless entry fob...if you want to make a spare without using the dealership you need to have 2 operating keys currently. if not then you need to get a key and program from the dealer.
Old 10-29-2009, 12:52 PM   #52 (permalink)
juggalomm's Avatar
Member Number: 74032
My keyfob stopped working. Put new batteries in, still won't work. If I buy a new keyfob, will I be able to program it this way? Or since the original from my car is broken, I have to go to the dealership?
juggalomm is offline   Reply With Quote
Old 10-29-2009, 08:04 PM   #53 (permalink)
I believe you need to have a working keyless to program any additional one, otherwise you would need to go to the stealership.
Page generated in 0.14830 seconds with 13 queries
