Old 09-09-2009, 07:33 AM   #1 (permalink)
xSugarSports's Avatar
Member Number: 36740
Exclamation How to disable factory alarm? Going off randomly ...
My car: 2005 ACR with a factory alarm. No aftermarket what so ever.
I searched to see if anyone else has this problem and found nothing. If i lock my car which has a completely stock factory alarm ... it will start going off at various times. It will happen in ten minutes, or an hour, or in the middle of the night. I checked the door sensors and they seemed okay, plus i get no lights coming on or anything while driving. ( as if the door was opening ) . I disconnected the auto trunk switch to see if it was that. Battery voltage is fine.
I cant find a how to anywhere on turning this alarm off ... i am perfectly fine with locking and unlocking the car manually.This getting up at 3am thing sucks to turn off an alarm ... any help?
Im sure im missing a few things since im writing this quick at work but this is killing me, and before i go to a wiring diagram ... i figured someone on here would be able to chime in.
When in doubt, power out.
05 ACR.
xSugarSports is offline   Reply With Quote
Old 09-09-2009, 08:22 AM   #2 (permalink)
i also forgot to add that i swapped trunks from a 00 and the wiring/latch cable werent the same. i thought i figured it out, but the trunk light stayed on all the time. maybe its possible that the car thinks the trunk keeps popping open. i guess i should really search for a wiring diagram of a 00 and 05 and compare.
anyone know off hand?
Old 09-09-2009, 09:12 PM   #3 (permalink)
04ebluenb's Avatar
Member Number: 14802
Take it to the dealer and get them to turn off the factory alarm
04ebluenb is offline   Reply With Quote
Old 09-10-2009, 12:31 PM   #4 (permalink)
morgantj13's Avatar
Member Number: 47175
disable the alarm as the last resort...since you said the thing about the trunk, i would assume thats it(well at least test it first)...how did you re-attach the wiring on the new trunk?
Page generated in 0.13836 seconds with 13 queries
