Old 06-21-2008, 08:27 PM   #1 (permalink)
muledoe's Avatar
Member Number: 57540
Default Help with a Zune install.
Ok, well im trying to do a custom Zune install with dock.
Problem - the dock has a power cable that comes attach to it already. The end of the connections is for USB.
Well i cut that end off leaving me with 4 wires
red - i know is power 5v
black - i know is ground
white
green
both white and green dont matter.
So i got some splice connections. Know i think i made a mistake by leaving the car on and forgot to turn it off. I 1st grounded the black to the cig lighter wire, and then red wire to cig lighter. I dont know if its me, but i think i smelt something. Think i burned it? or im not getting enough power?
any help cause its bugging the hell out of me. Should i of power 1st then ground or something. Does anyone know about USB and making the power supply work.
Thanks
Stone White '05 SRT4
muledoe is offline   Reply With Quote
Old 06-21-2008, 08:38 PM   #2 (permalink)
TenSix's Avatar
Member Number: 30687
white
green
Thanks
The power outlet is 12v. You would have to have something step down the voltage to 5v. You probably fried the dock already.
Here is one made by IME. It is $250
INTEGRATED MOBILE ELECTRONICS - IME Dock
TenSix is offline   Reply With Quote
Old 06-21-2008, 08:42 PM   #3 (permalink)
muledoe's Avatar
Quote: Originally Posted by TenSix View Post
The power outlet is 12v. You would have to have something step down the voltage to 5v. You probably fried the charger already.
damn.
i know the cig lighter works fine i tested it with my car charger and also with power checker, so i know its fine.
Well what on the car is 5v or how can i take it to 5v so it wont fry it?
Old 06-21-2008, 08:48 PM   #4 (permalink)
muledoe's Avatar
thats a nice dock, but it doesnt have a remote one i got has one lol
Old 06-21-2008, 08:50 PM   #5 (permalink)
TenSix's Avatar
damn.
I am sure that your cig lighter works fine because you probably fried the dock and not your cig lighter. You might be able to take a car charger for a PDA or iPod and cut the end (charger end) off and wire it to the dock wires. Then you would have to disassamble the end that plugs into the cig lighter socket and and hard wire it to the back of the cig lighter.
You might be able to pick one of these up and disassamble it and hard wire it.
Car Power Supply with USB Socket | Car Power Supply | USB Socket - Proporta
Old 06-21-2008, 08:55 PM   #6 (permalink)
muledoe's Avatar
i forgot the cig was 12v and the zune dock was 5v .. imma try that now i guess lol let u know how it works. thanks for helping me man
hm buying that and figure out if i can would be aswesome too. then i wont have to cut many wires. but how would u go about taking that apart and getting it to work with the cig lighter???
Old 06-21-2008, 09:04 PM   #7 (permalink)
TenSix's Avatar
It should be pretty simple. The hard part is opening it up (it might be held together with screws and that would be easy). Another option would be to get this because you could cut the part that plugs into the cig lighter off and hardwire it. Then you could just hide it and plug the usb from the dock directly into it.
ThinkGeek :: Smart AC 120 USB Power Inverter
Old 06-21-2008, 09:05 PM   #8 (permalink)
muledoe's Avatar
if i do that zune wire, and cut off my PDA cables and then wire the pda cables to the cig outlet, that will down it to 5v?
wont that just turn the pda cable or something?
Old 06-21-2008, 09:06 PM   #9 (permalink)
muledoe's Avatar
yeah that is awesome too..hmm
Old 06-21-2008, 09:17 PM   #10 (permalink)
TenSix's Avatar
Take a look at the iphone/pda charger and see if it says 5v. Amps are something else you might have to worry about. Going to sign off for the night. Check back tomorrow.
» Search Used Cars
Page generated in 0.25449 seconds with 11 queries
