Old 04-24-2008, 01:21 PM   #1 (permalink)
Member Number: 55792
Default compustar alarm please help!!!
i have a compustar alarm it is the 2way one where i can start my car and stuff from the remote....well something happened and now i can still start my car and stuff but my remote says it has no signal and my car wont page the remote if something happens and it dont say if the car is locked or unlocked on the screen....can someone tell me why it says i have no signal on the remote?
m_srt4 is offline   Reply With Quote
Old 04-24-2008, 09:10 PM   #2 (permalink)
TenSix's Avatar
Member Number: 30687
Is the battery dead on the remote?
TenSix is offline   Reply With Quote
Old 04-30-2008, 05:18 AM   #3 (permalink)
Member Number: 29891
The remote control is bad. This has been a real PITA with these 2 way remotes from Compustar lately. I bet I have to deal with this about once a month these days in the shop.
ponchonutty is offline   Reply With Quote
Old 04-30-2008, 11:25 AM   #4 (permalink)
my_little_srt's Avatar
Member Number: 41179
Your remote is fbard....
my_little_srt is offline   Reply With Quote
Old 05-02-2008, 04:39 PM   #5 (permalink)
Chino7385's Avatar
Member Number: 30157
Trader Rating: (21)
Sorry to highjack the thread. I didnt want to start a new thread with the same topic.
Yesterday a problem started with my remotes. Both the small clicker and the pager wont comunicate with the alarm. The alarm still functions just fine, i just had to manually put it in valet mode because i couldnt deactivate the alarm with the remotes. Is this something a compustar installing shop would be able to help me with? The alarm is 3 years old and was install by a shop thats 2 states away.
Any info would be much appreciated.
-Luis
*98 Neon R/T:Too Many mods
*00 Celica GT-S:I/E,STS,S-Tech's,S2k Antenna
*04 SRT-4:AGP 50Trim Kit,S1,S2 Inj,S-AFC2,AEM Wideband,Turbo XS HPBC,PTP Direct Fit,PTP UHP-HKS SSQV,PTP 180 T-Stat,PTP CV,Maxxfab Magnaflow 3" TBE ,CoolingMist W/I 100% Methanol,DCR Oil Mod,AEM SRI,MSD Wires,Bwoody MM's,Maddog 72%,Aeroforce Pro,255 Pump and Rewire,S-Tech's,HID's
Not installed: B&G Flash, Redstar Return Line, K-Sport CO's
Chino7385 is offline   Reply With Quote
Old 05-03-2008, 07:07 PM   #6 (permalink)
-Luis
Yeah they can but I am sure they'll charge you something. Try to do this.... Click your ignition on and off 5 times with in 7 seconds. Right after the last time you click it off, you should hear/see the lights flash. If you do, press one of the buttons on one of the remotes then do the same on the other remote. Each time a button is pressed on either remote the lights should flash. If it responds everything should be fine. If not you are either not it learn mode or your antenna/cable is bad.
Old 05-04-2008, 04:47 PM   #7 (permalink)
Chino7385's Avatar
Trader Rating: (21)
I was about to go try this but i was able to communicate with the pager again. The small clicker has bad range though. You almost have to put it up to the alarm's antenna on the window to get it to communicate. You think its probably a problem with the antenna?
Old 05-12-2008, 05:42 AM   #8 (permalink)
No, my guess it's the remote itself. Compustar has been having serious issues with their remote controls lately. The Pro AM series and the 2ways (both regular and pro) are constantly coming in the shop with issues just like you've stated.
Old 05-12-2008, 05:46 AM   #9 (permalink)
Sota227990's Avatar
Member Number: 31159
Trader Rating: (10)
also check your remote battery. I find mine LOVES to eat through batteries
. . . . the Kid . . . . . . . . . . . the Car . . . . . . . . . . . the Bike . . . . . . . . . . the Toy . . . . . .
And my real name is George Carlin.
First to use the phrase Suicide by Toll Booth
sig limits SUCK!
Sota227990 is offline   Reply With Quote
Old 05-12-2008, 03:02 PM   #10 (permalink)
Hmm, out of the DEI, Compustar, and Scytek units we sell in the shop the Compustar usually do real well with battery consumption.
Old 05-12-2008, 09:19 PM   #11 (permalink)
Chino7385's Avatar
Trader Rating: (21)
Default 2w900fmr
My alarm is not that new. Its not a pro series. Its about 3 or 4 years old. The pager and clicker looks like this:
I think model number is 2W900FMR. Have you ran into any glitches with this alarm?
It hasn't tripped out again yet. The only problem i have now is that the siren wont sound when i activate and de-activate the alarm. Its not on mute mode either. The alarm will still go off though.
Old 05-15-2008, 05:12 AM   #12 (permalink)
That's the currant 900fm series and those seem to be pretty decent so far.
Old 05-15-2008, 09:24 AM   #13 (permalink)
muledoe's Avatar
Member Number: 57540
i really havnt had a problem with my pro. Only thing i can complain about is signal strength sucks. They say 3000 feet, but no, never. Other then that it does great. I have it set on sensitive so to slight touch of the car or something it will go off.
Stone White '05 SRT4
muledoe is offline   Reply With Quote
Old 05-15-2008, 07:50 PM   #14 (permalink)
I've only seen a real small amount have issues with range and it's usually an antenna problem.
Old 05-16-2008, 09:25 AM   #15 (permalink)
muledoe's Avatar
if ur in a building though so u lose the signal though?
Page generated in 0.31135 seconds with 11 queries
