is it the s12l7-2 or s12l7-4? knowing the voice coil configuration determines the final ohm load and affects which amps will work best for you. the sub itself can handle 750rms so anything 500 and over should work nicely. here are the box specs from kicker:
Min Rec Sealed Box Volume (CU. FT., Liters) .88, 24.9
Max Rec Sealed Box Volume (CU. FT., Liters) 2.0, 56.6
Min Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6
Max Rec Vented Box Volume (CU. Ft., Liters)** 3.25, 92.1
ok another good deal i cant pass up, my friend has a 1500w rockford amp hes going to sell to me. is this going to be ok as long as i dont go overboard with it?
