Old 04-13-2008, 03:27 AM   #1 (permalink)
CrEaTrE's Avatar
Member Number: 28234
Default *OFFICIAL* Big 3 Wiring Mod Thread
We’ll start out by explaining exactly why you’re doing this upgrade. As you should know, the bigger the power wire in your sound, video or lighting system, the better it will perform and you should experience less dimming and/or voltage drops. The Big 3 is..
1) Alternator Positive to Battery Positive (optional fuse)
2) Battery Negative to Chassis
3) Chassis to Engine Block
Replacing/adding larger wire to these three critical spots can reduce or rid your electrical system of dimming and voltage drops. Overall, giving your charging system a larger surface area to travel over, will stabilize power and relieve strain on the alternator and battery.
If you have little cash to spend on a High Output (HO) alternator at the moment.. and the thought of even buying a new/better battery is daunting to you, this is a cheap and quick solution for your voltage issues.
Each wire serves its own special purpose, so you need to upgrade/replace all three for maximum potential of this mod. The Alternator Positive to Battery Positive wire is pretty small on a stock electrical system, so quite obviously upgrading that particular wire will increase power flow from the alternator to the battery. In DC power systems, power flows negative to positive. So upgrading the main grounds is just as important as the main power wire is. And lastly, since the alternator is grounded to the engine block, you need a way to transfer that energy back into the system.
Items You Need
You’ll need a varying assortment of tools and supplies to successfully complete this job. Depending on how large your engine compartment is you’ll need between 5-10ft of wire. I recommend you use the absolute largest you can afford. 1/0awg is a very popular choice for completing this upgrade, although others have been known to use 4awg. Remember that anything over stock is still better, but while you’re under there... you might as well go big.
You’ll also need several crimps sized for whatever wire you use. A normal amount would be 6. If you upgrade your stock battery terminal to something with set screws, you’ll need one less crimp.
To get the crimps on the wire you can use several different methods. I prefer to use either a giant crimping tool or a table vice. Either one will work fine, and there are various other methods available as well. As long as the connection is secure and not moving about. Don’t fret it.
Also make sure that the whole thing is taped or covered with a rubber sleeve. To cut large wire, most wire cutters should be up to the task. If you don’t have a set, you can use a common hacksaw, a set of tin snips or a set of bolt cutters.
Again, however you cut it… just make sure that the wire has a clean edge.
If you decide to fuse the Alternator Positive to Battery Positive wire, you’ll need a fuse and fuse holder. Try to fuse for the maximum amperage of your wire.
Lastly, you’ll need an adjustable wrench, a good socket set or a few open-end wrenches to loosen any bolts or nuts that come your way.
Beginning the Project
1) Start out by disconnecting your Battery Negative. This will interrupt power through the whole system allowing you to safely work on the vehicle without danger to you or the cars more fragile electronic devices. Also push the brake pedal in a few times until it is hard to drain the remaining power in the system.
2) Sand down the potential grounding point for the new Chassis to Battery Negative point. This should be shiny metal when you’re done. You want as clean of a connection as possible. If you use the existing ground point you may not have to drill a new hole for a screw. Sand around it to ensure a good connection, you may also want to smear some anti-oxidation grease on the uncoated metal to prevent rust. This connection must be tight and secure when you’re done.
3) Screw the new ground wire in place but DO NOT reconnect it to the Battery Negative yet. Lay it down on a piece of cloth or paper and wait to connect it till after you finish the other elements of the project.
4) It’s time to add onto the existing Alternator Positive wire. This can be a bit tricky due to a small plastic collar around the positive lead coming off of the alt. It really only allows you to use one ring terminal terminated wire on the alt. That is perfectly fine though. Break off a little of the plastic if the extra wire refuses to fit. There should be a rubber gasket over the existing wire that will protect it.
Again, make sure that the wire is hooked snug on the terminal and not exposed to the elements.
5) Take the other end of the Alternator Positive wire and if you so choose, run it through the fuse holder. If you’ve decided to not get a fuse holder, then run it straight to the battery positive.
6) Attach the wire along the way to something that won’t get too hot and that won’t vibrate too terribly. Go ahead and connect the wire to the positive battery terminal.
7) The last step is the Chassis to Engine Block wire. Remember to sand both points well, just like the when you did the Battery Negative to Chassis. All you need to do for this step is to find a non-essential bolt on the engine block to attach the wire to. Non-essentials are those that don’t hold a liquid in. For example… using the Oil Drain plug as an attachment point probably isn’t the smartest place.
8) Take the other end leading off of the engine block and sand a smooth place on the chassis. If you want to do more than one lead off of the block that would be fine as well. The more the merrier.
9) You’re just about done. Re-check all of the new and old connections you just fiddled with to ensure stability, safe connection and good contact. After you’ve made sure everything is safe, you may re-attach the Battery Negative wire to the negative terminal on the battery.
Congratulations! You’ve just completed the cheapest and easiest upgrade to your electrical system that there is. If this doesn’t take care of your questions, please post them in this thread and we’ll try to answer them for you.
Picking out a fuse for the Bat to Alt (need 150a fuse so either 4awg or 0awg):
Real Car Audio Reviews
Source: Official CarAudio.com Big 3 Thread - Car Audio Forum - CarAudio.com
Old 04-15-2008, 08:03 PM   #2 (permalink)
NoisufnoC's Avatar
Member Number: 136
as far as the positive wire to the alt, do you replace the factory wire? or just add a new one to it?
what amp fuse would you get for that line?
omgz!! i haz mods!!
Old 04-15-2008, 08:11 PM   #3 (permalink)
CrEaTrE's Avatar
Since your car's fairly new, just add the power cable to your alternator. Leave your stock wiring in place and add onto it. Unless you're going to keep the car for awhile. Then by all means, replace everything. But either way, electricity will find the path with least resistance. So even if you add a bigger power cable and the stock wiring's still in place, the current will flow through the bigger gauge cable.
I'm changing my mind on the fuse. You do the fuse based on the wire thickness....so with 4awg you could go with a 150a fuse which is required in our car because of the size alternator we have (140a). After reviewing some things, I realized 0 awg would be best because it would handle the fuse a bit better than the 4awg, however it would be ok to run 4awg if 150a was the biggest fuse you used on it.
Old 04-15-2008, 09:27 PM   #4 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (30)
subscribing so i can read this when i get off work...
Old 04-15-2008, 09:32 PM   #5 (permalink)
CrEaTrE's Avatar
I'd like to add that any person that does this mod should gain drivability and electrical stability in their car. For instance, my cam lope makes the lights dim. I'm going to be doing this mod soon, and should smooth out the electrical system so it doesn't do that. Cams will lope, but electrical system won't suffer.
Old 04-15-2008, 09:42 PM   #6 (permalink)
Philth's Avatar
Member Number: 46647
Trader Rating: (24)
I want to do this...just not really inclined to do it. Now that there are 2 other Vegas area asshats wanting to do it, we can have a threesome of big 3's going on. We like to gang bang shit out here...
Old 04-15-2008, 10:00 PM   #7 (permalink)
CrEaTrE's Avatar
Added this to the How To section as well. I will hopefully be doing this mod soon and will take pictures when I do it. Have too much other stuff to worry about right now, but should have it complete with pictures in a month.
Old 04-15-2008, 10:04 PM   #8 (permalink)
Trader Rating: (30)
make that 4 dustin..
Old 04-15-2008, 10:11 PM   #9 (permalink)
Philth's Avatar
Trader Rating: (24)
Whos the fourth? You me Mike???
Old 04-15-2008, 10:13 PM   #10 (permalink)
Trader Rating: (30)
and now that im thinking about it, i have noticed my interior dash lights kinda dim when im cruising at about 80mph in 5th.. this has answered the question ive been asking myself " did DCX use crappy ground points or am i needing a better ground solution because of the extra electronics ive added. "
Old 04-15-2008, 10:15 PM   #11 (permalink)
CrEaTrE's Avatar
DCX used crappy ground points, and too thin of wiring to be of any use. Same reason why when I'm working underneath my car I get shocked like crazy.
Old 04-15-2008, 10:15 PM   #12 (permalink)
Trader Rating: (30)
my fault, didnt realize i was included. well someone else will wanna do it too lol.
Old 04-16-2008, 10:34 AM   #13 (permalink)
NoisufnoC's Avatar
Member Number: 136
My lights dim when i roll up my front windows, or when i have my headlights on and i use my turn signal
Old 04-16-2008, 10:42 AM   #14 (permalink)
Member Number: 515
doing these upgrades won't stop that.. That happens with all the SRT's it is the excess current draw I believe.
You have to be angry at life to be creative
-John Leguizamo
"man is the measure of all things." - Protagoras
reason is the only proper guide to the most crucial problem of human existence- the question of good and evil. -socrates
04electricblue is offline   Reply With Quote
Old 04-16-2008, 03:02 PM   #15 (permalink)
CrEaTrE's Avatar
I don't know about that, but it would make sense I suppose. The Big 3 should stop most light dimming. It's a really powerful cheapo mod for car electronics.
