Quote: Originally Posted by
nineball
It's got nothing to do with your amp although it might be fried now. The seal around the tail lights is a well known problem area and can let in a lot of water. You can try to seal it yourself with some silicon or similar or you can go to any dealer and get a new set of gaskets for under $20.
That is one thing I'm thankful of is that my amp is not fried nor did i do any damage anywhere else. So if it is due to a seal in the trunk area i do know that my spoiler has a lil leak; will that be causing this and I'll also check the tails. Thanks
