» Tire Upgrade Garage
Old 05-05-2008, 12:52 PM   #1 (permalink)
Member Number: 54845
Default after market speakers
i got some 4 channel 6x9 and want to put them in my car . do i need to buy a wireing harness for them or anything like that. and how do i get the back dash cover off.
K&N FIPK, Mopar CatBack, MSD8.5 wires, NGK plugs, Mopar BOV, Oil press, Volt, EGT gauges. Autometer Ultralight Boost that works.
CootersSRT4 is offline   Reply With Quote
Old 05-05-2008, 01:18 PM   #2 (permalink)
my_little_srt's Avatar
Member Number: 41179
There should be a "How to" on this in the "How to" section...
my_little_srt is offline   Reply With Quote
Old 05-05-2008, 01:19 PM   #3 (permalink)
DJFahr11's Avatar
Member Number: 25197
Trader Rating: (19)
...or the audio section
DJFahr11 is online now   Reply With Quote
Old 05-05-2008, 02:39 PM   #4 (permalink)
k sorry
Old 05-05-2008, 02:53 PM   #5 (permalink)
packerfan43042's Avatar
Member Number: 45938
Trader Rating: (20)
I dont think you have to buy any harness to hook up just speakers.
packerfan43042 is offline   Reply With Quote
Old 05-05-2008, 03:05 PM   #6 (permalink)
CrEaTrE's Avatar
Member Number: 28234
Thanks for the plug man!
**** READ THIS BEFORE POSTING - Everything Car Audio ****
2004 Black Dodge SRT4 - AGP 50 Trim .63A/R @ 21psi, Crane 12s, .020" overbore, JE Forged Pistons, Eagle Rods, HKS SSQV BOV, JMB 3" ultimate intake, JMP Pressure Pipes, AGP IC, Stage 4 CM 6-puck Clutch, 3" BDJs Dump, RC 750cc's, Aeromotive FPR, -4an Teflon Fuel Line, Perrin Fuel Rail, Greddy Emanage and E-01.
Old 05-05-2008, 03:21 PM   #7 (permalink)
read that. how do you hook up the factory wires to the new speakers the connectors dont match
Old 05-05-2008, 07:05 PM   #8 (permalink)
Member Number: 60582
you have 2 options. buy a set of connectors that plug into the factory plug, then wire that to the speakers. cut the factory plug off and use the bare wires (preferably with terminal ends on them) to connect to the speakers.
Old 05-05-2008, 07:15 PM   #9 (permalink)
stage3matt's Avatar
Member Number: 54658
option 3: tap speaker wires onto the existing factory wiring without cutting off the plug, either by way of soldering or stripping a bit of the wire, poking a hole through, wrapping the bare end of new speaker wire through hole, and tape well.
stage3matt is offline   Reply With Quote
Old 05-06-2008, 08:28 AM   #10 (permalink)
so just match up the colors. And there are 4 wires on the factory harness now but only 2 are connected to the harness the other 2 look like they have been cut. is that normal
Old 05-11-2008, 09:54 PM   #11 (permalink)
Member Number: 29183
Not trying to be a dick, but you should either have someone who is experienced with the car do it or take it to a reputable shop and have it done.
the wires DO NOT match color for color and you will have to either get the plug adapter from a store and just plug them in or test the wires for polarity and then go from there with hooking them up...
either way, do it right and dont just start cutting plugs off, that is the dumbest thing that you can do.
escort_gtx is offline   Reply With Quote
Page generated in 0.15367 seconds with 11 queries
