I've been having problems with getting strong sound from my speakers. If i would turn it up past halfway the sound would get all muddy and actually get quieter. So i replaced the big 3 and got the kinks out of my door and deck speakers. The problem is my sub is still hitting pitifully. I have a couple small deep cycle's laying around but i think my biggest problem is voltage not amperage.
Heres what i got.
US Acoustics D1000(I have had this pushing 3 jl w7's in other cars 1ohm with 3/4 gain)
US Acoustics 4 channel 125 x 4 running doors and deck
polk components up front and polk 6x9s in the rear
trying to push a mtx 9500 15...Its 2 ohm because at some point i plan to run 2 and want that to run at 1ohm.
Has anyone heard an improvement by adding batteries to this type of scenario?
MODs - Mopar STS, Kinetic 60m tb, Buscher 3in Ex. Kinetic Wastegate, PTP 75psi mod, Quickwhips FMIC, Map Clamp, spike 23lbs hold 16lbs, Best E.T. 13.08@ 110 2.08 60FT(on snow tires bitches) and I still get 29 mpg...
If YOU didnt do the work, then I dont care how much hp your car makes!
You should not need a second battery with that setup. Something is wrong with the wiring or the tuning. Refer to the tuning and subwoofer wiring sticky's to make sure you have everything tuned correctly, and that you have everything wired like you want.
