Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > International Forums > Canadian
Old 05-25-2008, 08:29 AM   #1 (permalink)
pduvert's Avatar
Member Number: 45438
Default TOB Fork Help!!!
About a month ago when the weather started getting warmer, I started having problems shifting. It was really hard to get it in 1st and reverse. It got to be so bad that I brought it to the dealership.They told me my clutch was done.They replaced the clutch,master cylinder,slave cylinder and TOB. I asked them about the TOB Fork since I read that these would wear out as well.They told me it was in good condition and did not need to be changed.$2700 and a month later my shifting issues are starting up again. It seems to only happen when its hot out and I've been driving a lot. When its cold out it shifts like butter.Does this sound like a TOB Fork issue ? If so how much should it cost to have a new one intalled (not at the stealership).
Mopar Stage 1, Stage 2 coilovers, Crane fire wires, SRI, AGP WGA w PTP spring 20-18 psi, Forge BOV, 180 thermo, hemi plugs, MM, polly bushing kit,17x7 in. Fast Wheels. B-Woody 85% STS w Booger Bushings and CNC shifter base bushings ,Lorenzo 60mm TB, Check Valve,Textilium eyelids, black depot tails, Boomba intake spacer, Mopar catback,Maxxfab 3 inch DP,PTP O2 Housing,PTP 75psi FPR, Dasmopar mapclamp, Aem Wideband ,ptp rewire.
pduvert is offline   Reply With Quote
Old 05-25-2008, 09:18 AM   #2 (permalink)
SRT4 FERG's Avatar
Member Number: 57561
Yea recently had the same problem, i replaced my TOB fork and night and day difference. I got mine from PTP for 179 or thay r 175 at the dealer. The PTP one gets a cyro treatment so they r better than the stocks ones, they r outta stock at ptp right now but they will prolly have some soon.
SRT4 FERG is online now   Reply With Quote
Old 05-25-2008, 09:21 AM   #3 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (17)
Try adjusting the clutch before going through all that.
HCCAFan is offline   Reply With Quote
Old 05-25-2008, 10:21 AM   #4 (permalink)
marc jones's Avatar
Member Number: 25923
I am having the same problem right now. I have the clutch adjusted all the way out right now. Worked great for about 6 months and now it is starting to do it again. I do have 90,000 miles on the stock clutch now so it's about time to change it.
Mods-mpx intercooler,maxfabb see w/cat,ptp wastegate,ptp checkvalve,das mapclamp,redstar motorsport fuel return line,aem uego,injen sri,ed hardpipes w/hks,dcr throttlebody,ftp motor mounts,eibach pro kit springs,driftz 17" rims
marc jones is offline   Reply With Quote
Old 05-25-2008, 11:28 AM   #5 (permalink)
SRToc Member
kaminarineon's Avatar
Member Number: 11151
Trader Rating: (12)
when i had my stock clutch i had this issue...1st and reverse...i had adjusted the pedal lower but once i put it back to stock position all was good
dude the only way ull beat a Stage 3 SRT is if u shoot the driver
post 38:
http://forums.bimmerforums.com/forum...ht=srt4&page=2
kaminarineon is offline   Reply With Quote
Old 05-25-2008, 12:54 PM   #6 (permalink)
GLH
GLH's Avatar
Member Number: 13115
Trader Rating: (34)
we have been seeing some of the pivots behind the fork wearing out and cracking
86 GLHS 315
05 SRT4 GT-A #166
2008 Mobile 1 GT Sprints
2007 Canadian Touring car Championship
sponsored by Fast Trac /ftrac.org
GLH is offline   Reply With Quote
Old 05-25-2008, 04:55 PM   #7 (permalink)
pduvert's Avatar
Default TOB Fork
Tried adjusting the pedal and crossover cable already . Didn't change anything. I might as well get the Ptperformance TOB Fork and change get the Pivot joint change at the same time.
Old 05-27-2008, 06:54 AM   #8 (permalink)
Rugger's Avatar
Member Number: 18657
What Steve said, The two "bumps" at the base of the fork were almost worn out on mine,and yeah mine shifts like melted butter!
Rugger is offline   Reply With Quote
Old 06-09-2008, 02:10 PM   #9 (permalink)
Member Number: 19287
i'm having same problem now too, so it's a good idea to change TOB for when i do the clutch?
S2 no toys+devilsOWN +AGP 50trim
294whp no tune
boosty is offline   Reply With Quote
Old 06-09-2008, 03:38 PM   #10 (permalink)
rasp's Avatar
Member Number: 56076
Trader Rating: (15)
TOB should ALWAYS be changed with the clutch. People also recommend changing the tob (clutch release) fork as well with every clutch swap.
I love turbo lag, it gives you a second to reflect about the poor decision you have just made.
Old 06-09-2008, 03:43 PM   #11 (permalink)
MASSSRT's Avatar
Member Number: 23778
I had a tough time shifting and a clutch adjustment helped, changing the tranny fluid helps too. My TOB fork was only maybe 1/2 way worn down after 137,000 miles. I think the little TOB tabs break off, causing the TOB to bounce around, they are pretty flimsy. I do know that a tiny adjustment on the pedal has made quite a difference
MASSSRT is online now   Reply With Quote
Old 06-10-2008, 12:53 AM   #12 (permalink)
joe440's Avatar
Member Number: 46289
Trader Rating: (13)
What do you have to do to change the TOB fork ? I am not planning to change the clutch at this time.
joe440 is offline   Reply With Quote
Old 06-10-2008, 12:54 AM   #13 (permalink)
MASSSRT's Avatar
drop the tranny
Old 06-10-2008, 06:17 AM   #14 (permalink)
rasp's Avatar
Trader Rating: (15)
My transmission with about 67k miles in it had an abundance of ware on the fork:
Notice the nice grooves on the new one by S&P. My old unit didn't have any. This was causing the TOB to be engaged unevenly, and it even ended up breaking one of the tabs off the TOB that I found rolling around at the bottom of the bellhousing when I did my clutch job. My pivot ball also just fell right out upon removing my clutch release fork. Doh! Good thing S&P sends you one with their forks!
Transmission must be taken out, clutch must be removed and then you can get to the fork. The fork is what the TOB sits on and slides in when the slave cylinder is engaged using the clutch.
I can say changing my clutch release fork made a world of difference in my shifts. Very smooth now, and no more 1st and 3rd gear bitch-fests trying to get it into gear.
Old 06-13-2008, 06:07 AM   #15 (permalink)
Boosted_SRT's Avatar
Member Number: 60014
I am having the exact same issues as well, only happens after driving for a while, and it is especially hard to get in to gear when the A/C is on. In fact its even hard to get OUT of gear and go in to neutral! I bought some GM Syncromesh tranny fluid so i will begin by replacing that, if that doesnt do anything i will try adjusting out the clutch pedal.
Boosted_SRT is offline   Reply With Quote
Page generated in 0.30629 seconds with 11 queries
