Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > International Forums > Canadian
Old 11-05-2009, 05:52 PM   #1 (permalink)
Member Number: 14331
Default Tips on Winter Storage
I've done this before, but now with the car being 5 yrs old, are there more precautions I should take?
Is it best to fill up my tank and put fuel stabalizer?
Over-inflate the tires to avoid flat spots?
What about the hand brake, should I apply the handbrake, or do I risk it seizing up on me after a long period of time not using it?
I've started up my car from just 2 weeks of not driving it (stored in my non-heated garage), and it ran pretty rough for about a minute. Is this because of moisture in the tank? I do not have a lot of gas in my tank.
Help is appreciated.
Z24SRT9004 is offline   Reply With Quote
Old 11-05-2009, 06:41 PM   #2 (permalink)
Member Number: 42667
All i do is put stabilizer in the tank, pump the tires up to like 45-50PSI and park it in gear with no ebrake on and disconnect the battery.
I also put a bag of charcoal (the wood kind, not the briquettes kind) and some baking soda in the trunk so it doesnt smell "stale" in the spring.
If you put the ebrake on and it seizes it makes for an interesting spring.
05plsrt4 is offline   Reply With Quote
Old 11-05-2009, 06:49 PM   #3 (permalink)
HWY*'s Avatar
Member Number: 65076
I do stabil in about a half tank. Max tire pressure. Trickle charger on the battery and news paper in the cabin.
HWY* is offline   Reply With Quote
Old 11-05-2009, 06:53 PM   #4 (permalink)
HWY*'s Avatar
Oh, btw, I use the E-brake.
White lithium grease is your friend.
Old 11-05-2009, 10:07 PM   #5 (permalink)
Member Number: 75848
I have at least 1/2 a tank of gas with stabilizer. Inflate the tires 40-45psi and I do not use the ebrake. I start it every 2 weeks on Friday and let it run for 15 minutes. Sometimes i'll drive it back and forth on my driveway (depending on the ice and snow) so it has a chance to move.
I don't mind the smell in the spring, it's the smell of excitement when I can finally drive it again.
SRT2K4C is offline   Reply With Quote
Old 11-07-2009, 08:49 AM   #6 (permalink)
evilsrt4canada's Avatar
Member Number: 49138
Trader Rating: (29)
good tips..i put my car away and i just had to move it but now i just keep it in gear\
and should you start it once in a while?
You don’t WORK!
You don’t EAT!
You don’t GRIND!
You don’t SHINE!
Four Door Mafia
evilsrt4canada is offline   Reply With Quote
Old 11-09-2009, 09:58 AM   #7 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (65)
-full tank of gas + stabilizer.
-remove the battery from the car and keep it inside the house, if you re keeping it in the basement, keep it off the basement floor or put an inch of wood underneath the battery.
-e brake off
-slightly over inflate the tires, if you have another set of tires to put on rather than your good set of wheels.
-baking soda in the cabin and in the trunk.
-dont touch the car, leave it be till the spring.
http://www.SRTCanada.com <----- alternate site for canadians.
DiabloSport Trinity Beta Tester
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 11-09-2009, 10:53 PM   #8 (permalink)
joe440's Avatar
Member Number: 46289
Trader Rating: (13)
Move to Vancouver and drive your car all year long
joe440 is offline   Reply With Quote
Old 11-15-2009, 07:59 PM   #9 (permalink)
Trader Rating: (29)
dont for get it's not cheap to live in vancouver
Old 11-18-2009, 11:27 PM   #10 (permalink)
toasteroven's Avatar
Member Number: 7373
Yeah, cause that worked out so well for you guys last year.
Said before, but I'll say it again because here is what I'm doing:
1. 3/4-full tank + stabilizer.
2. Recent oil change (or decent oil).
3. Top up all critical fluids (wiper fluid doesn't count).
4. Inflate tires to 40-50psi. Check often for slow leaks, move 'er out into the drive way every month and get the tires resting on new spots.
5. Remove battery + store inside on cardboard.
6. Wood chips / charcoal in the trunk and small container of chips on the back floor.
7. Leave in gear, no e-brake.
"This car is 100% sh*ts and giggles."A car can be a tool but it can also be so much more. It can be a heart-starter, it can be a drug, it can be a piece of art and it can stir your soul.
"Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
toasteroven is offline   Reply With Quote
Old 11-19-2009, 12:07 AM   #11 (permalink)
Member Number: 59886
Yes, last year was godawful. So much so I now have a Jeep w/ nokians for the winter, but watch there be no snow this year! I certainly wouldnt miss having to dig out half of my residential street just to get onto the main roads
Mr_C is online now   Reply With Quote
Old 11-19-2009, 12:17 AM   #12 (permalink)
phs17's Avatar
Member Number: 67384
glad to see this thread. putting it away tommorow for the winter
phs17 is offline   Reply With Quote
Old 11-19-2009, 12:50 AM   #13 (permalink)
Member Number: 15708
I'm storing the car for the first time this winter because I'll have a winter car. I was thinking about putting this in the cabin and trunk. It pulls moisture out of the air and that just drips down into the cup.
D A M P R I D - The Original Non-Electric Moisture Absorber
Also do you guys crack the windows at all?
(JPG )
2003 SXT
2005 SRT-4
titansrt4 is offline   Reply With Quote
Page generated in 0.21613 seconds with 13 queries
