Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > International Forums > Canadian
Old 08-20-2009, 07:51 AM   #1 (permalink)
4sefed's Avatar
Member Number: 3225
Trader Rating: (12)
Default Thoughts on using combustion chamber cleaner
Just been reading some various things around the forums and was wondering...
with the amount of oil we get through the PCV... and I know we all have a catch can, but what about the times we forget to drain the can when it's full...
What is your take on running a can of combustion chamber cleaner though to clean the intake and everything else?
.o0+Eric+0o.
Proud U.A. Local 46 Toronto Member
04 SRT-4
4sefed is offline   Reply With Quote
Old 08-20-2009, 08:37 AM   #2 (permalink)
GLH
GLH's Avatar
Member Number: 13115
Trader Rating: (38)
do it works wonders the best stuff i have used is the GM Cleans I like the pour bottle but you can get it in a spray if you like
2005 SRT4 ST Touring Car
2009 Mobile 1 Sprints GT3
Sponsored by Fast Trac / ftrac.org
GLH is offline   Reply With Quote
Old 08-20-2009, 03:19 PM   #3 (permalink)
nemisis's Avatar
Member Number: 7960
i found the Mopar spray works really well
nemisis is offline   Reply With Quote
Old 08-20-2009, 08:28 PM   #4 (permalink)
Member Number: 10107
Do they sell this at the dealership or what?
soon2bsrt is offline   Reply With Quote
Old 08-21-2009, 09:19 PM   #5 (permalink)
GLH
GLH's Avatar
Trader Rating: (38)
Yes
Old 08-22-2009, 09:41 AM   #6 (permalink)
Block Head's Avatar
Member Number: 47920
Install water/meth. Two birds, one very happy stone.
Quote: Originally Posted by SpeedEuphoria View Post
Lesson learned from this thread: Don't believe everything you see/hear/read. Investigate/research the topic at hand so next time you can make the judgment for yourself and not be as gullible. This is a benefit because then you can be informed and vendors cannot pull one over on you.
Block Head is offline   Reply With Quote
Old 08-22-2009, 05:51 PM   #7 (permalink)
Yes
Got a bottle of the liquid from the dealership. How do you use it? Dilute it with gas is what it says on the bottle. Do you feed it through a vaccum line like the brake booster or something? I tried to google it but all that came up was the sprays,
Old 08-22-2009, 07:09 PM   #8 (permalink)
GLH
GLH's Avatar
Trader Rating: (38)
yes siphon it thru a vacuum source try not to let it go in to fast as you want to coat the inside of everything then let it sit for 20 min and then start your car up and drive the shit out of it till the smoke clears thats the fun part
Old 08-22-2009, 07:11 PM   #9 (permalink)
BLKDOUTSRT4's Avatar
Member Number: 36285
just use lucas in the gas tank a few times.....seems to work pretty good
Quote: Originally Posted by Alpha-Omega View Post
....yeah, I'm gay and staying home this time
BLKDOUTSRT4 is offline   Reply With Quote
Old 08-22-2009, 08:07 PM   #10 (permalink)
And you dilute it with gas?
Old 08-22-2009, 08:17 PM   #11 (permalink)
Ragin_SRT's Avatar
Member Number: 42510
Trader Rating: (42)
you can also use seafoam
Crane 14's
Ragin_SRT is offline   Reply With Quote
Old 08-23-2009, 05:25 PM   #12 (permalink)
So I used this and came home and took out my plugs and looked down and still see black in there
Page generated in 0.17501 seconds with 13 queries
