can ya post pics of the surge valve? ptp says he fills that in, im curious to see what that look like
Thanks...It is already at FastTrac....If you go over today early you might get to see it....But I dont think the surge valve was filled...At least it did not look like it was....I just thought since I was pushing for this ASAP that John did not bother, which is o/k with me as I have the BOP ready to install and I would rather have the turbo then wait for the surge to be filled....Maybe if John see's this post he will comment....
this turbo spools around 3000rpm (with ported/polished mani) but really shines from 4000-7500rpm
Built by experts. Tested in the real world.-Mopar
For sound Install/Tuning assistance: 727-512-9684 Serving Florida's Neon & SRT4 community since 99/03
All of the above...Except I think this might be a little bit laggier than 3k...I think I will start at 7200 and see where that leads....28 psi and go from that point....cams are zero'd for break in...so we will see what adv/ret a few degrees does and then move a bit each way till we find the best results
Mods:
FastTrac built 2.6 Stroker with all DCR Important 2.6 components
FastTrac Race Built Head with Crane 16's and DCR Valves 1/2 over
PTP S3 Big 49lb Mouth
PTP Intimidator Exh. Mani with 36mm ext WG
PTP 3.5 " O2
PTP 4 inch dump exhaust
Fastrac PnP Intake mani
EMS
EMS Boost Sol.
5 bar MAP
Real Tune inj. 925cc
PTP Big Race FMIC
SB Stage 5x custom clutch modular
50mm TurboSmart BOV
70mm Boomba TB
Boomba fuel rail
FastTrac/PTP Return line and Reg.
Fuel Hot wire
DCR Big oil kit with PTP spacers/gasket
BC CO
Weight Reduction
6 point cage
Kirkey Pro racing seats
Koyo Rad
CF Hood Trunk
H Brace
All 3 Solid Mounts
Hurst Shifter/boogers
Hey guys, this is the race turbo for Jeff. This is the "G" clip on the exhaust side (no pictures jeff). This should give an additional 40 WHP up top and generate some much needed lag for his set up. The surge port is blocked by the press fit bell mouth.
We can do the bellmouth on any SRT4 turbo with or with out the surge port blocked. $225 for this option and its not some silly weld on unit. We machine them out for a press fit and then ceramic coat the cover. Its the only "true" way to make the bellmouth on center and its the only way you can get the bigger compressor wheels into the stock cover or the stage 3 mopar covers.
